Thread started 30 Oct 2012 (Tuesday) 10:09
Wedding photographers...
5W0L3
Joined Mar 2012
Oct 30, 2012 10:09 |  #1
Which wide angle lens do you use the most to capture couple shots / portraits involving the scenery / sky etc.
my 35L isn't wide enough, and at times i wish i had something ultra wide for those kind of shots.
Manav
5D III x 2 (gripped) | 35L | 85L II | 100L | 24-70mm IIL | 70-200mm IIL | Some strobes & some speedlights.
Charlie
Guess What! I'm Pregnant!
Oct 30, 2012 10:14 |  #2
might as well look at the 24-70... 24 is borderline ultrawide IMO.
Sony A7siii/A7iv/ZV-1 - FE 24/1.4 - SY 24/2.8 - FE 35/2.8 - FE 50/1.8 - FE 85/1.8 - F 600/5.6 - CZ 100-300 - Tamron 17-28/2.8 - 28-75/2.8 - 28-200 RXD
Panasonic GH6 - Laowa 7.5/2 - PL 15/1.7 - P 42.5/1.8 - OM 75/1.8 - PL 10-25/1.7 - P 12-32 - P 14-140
Invertalon
Oct 30, 2012 10:19 |  #3
I think for weddings, the new 24-70 II will be the new gold standard.
-Steve
Facebook (external link)
HiepBuiPhotography
Joined Mar 2012
Oct 30, 2012 10:22 |  #4
I use the 24mm L II.
Hiep Bui Photography | Harrisburg Wedding Photographer (external link)
dmward
Gallery: 29 photos
Oct 30, 2012 17:29 |  #5
I have the 16-35 in my bag but rarely take it out. Too likely to get some ugly distortion toward the edges with people. 24-70 is good option. I used the V1 for a couple of years and now the V2. Outside I also use 24-105 The extra 35mm is nice to have for portraits. 70mm is just a tad short for my taste.
frugivore
Gallery: 11 photos
Oct 30, 2012 17:39 |  #6
HiepBuiPhotography wrote in post #15186438 (external link)
Me too. I use it whenever I get the chance. There is no lens like it, IMO. It is the widest f/1.4 lens you can get. It gives you sufficient shallow DOF and a great expansive angle of view.
5W0L3
Joined Mar 2012
Oct 30, 2012 22:43 |  #7
so does 24-70 II have much distortion towards the edges?.. because i'd be happy to invest in that sometime in future..
Manav
Rittrato
Oct 30, 2012 22:54 |  #8
Agree with majority here. 24 1.4L II on FF is just magical. That 1.4 brings a lot of creativity when shallow DOF is needed.
Pearlallica
Oct 31, 2012 10:20 |  #9
another 24mm guy here too. I find any wider and the subjects get lost in an overly dominant background.
16-35 only comes out to play with large family shots or indoors in tight spaces.
the 24 1.4 is wonderful for dimly lit receptions too.
jonathan @ tlcphoto.com (external link) - pro wedding and portrait photog
5d2 5d3 50L 16-35 70-200 ElinchromRX600 580EX 600EX VIV285
coryparris
Oct 31, 2012 10:27 as a reply to  @ Pearlallica's post |  #10
I generally shoot 24-50-85-135. The 24 is wide enough most of the time, but if we are going to be in the forest, I choose the 16-35 to emphasize the height of the trees.
IMAGE: http://www.coryparris.com/wordpress/wp-content/uploads/2011/09/300_thumb.jpg
Seattle wedding photographer Cory Parris (external link)
Blog of said Seattle wedding photographer (external link)
jblaschke
Gallery: 6 photos
Oct 31, 2012 13:25 |  #11
The Wife uses her 24-70 mk I very heavily during weddings, switching between that and the 70-200 2.8 IS, with a handful of other lenses thrown in for specialty shots. For FF versatility, there's a reason Canon's 24-70L is the go-to lens for wedding photographers.
Canon 7D | Canon 50D IR modified | Canon EF 70-200mm 2.8 IS L | Canon FD 500mm 8.0 Reflex | Canon EF 85mm 1.8 | Canon EF 50mm 1.8 mk I | Canon EF-S 10-22mm | Tamron 28-75mm f/2.8 | Meade 645 (762mm f/5)
Model Mayhem (external link) | DeviantArt (external link) | Lisa On Location: New Braunfels Photography (external link)
jra
Oct 31, 2012 18:17 |  #12
24-70 here also.....IMO, it's usually the best "go to" lens for weddings :)
behindtheglass
Joined Aug 2012
Oct 31, 2012 18:19 |  #13
I personally use the 16-35 paired with a 70-200. So for wide angles I use the 16-35... :X
|Gear list// 500PX (external link)// FlickR (external link)// G+ (external link) //Facebook (external link)// Site (external link)|
"I bet you have an idea for a single photo or a photography series or a behind the scenes video that you have been thinking about for literally years. Turn off your computer and your TV and actually do it." -Lee Morris (FStoppers)
Pearlallica
Nov 01, 2012 08:03 |  #14
i would just like to add that the main reason that I ditched the 24-70 (beside how I found the focal range awkward/limiting) was the aperture. Being locked at F/2.8 either meant flash or high ISO because of the poor lighting I constantly found myself shooting in. The extra stops that primes gave me were life saving. I'm at the point where I don't settle for second best when it comes to my work. I tried that for several years and while bounced flash produced better results under some conditions, not all rooms had low/white ceilings to help me get around those impossible conditions that would always pop up.
At this point I usually get told how primes and lens changing cost shots. I believed this to be a solid point of debate when I was a zoom guy. Experience has told me this is not true. I work with a think tank lens changer messenger style bag which holds my 3 main primes, facing down, lens hoods on, and all lens caps off. I wear a lowepro belt with a two lens cases, each housing my two zooms. I can turn the camera off, pull off a lens, put a new one on, turn camera back on in about 7 seconds if need be. After years of trying out cumbersome, bulky walkaround-with-gear combinations, I've found this to be the most efficient, light and convenient method to shooting weddings without being weighed or slowed down. (yes I've even ditched the 2 camera technique) In this approach I can grab a 24mm prime or 16-35mm zoom depending on how I want to tackle a particular shot.
behindtheglass
Joined Aug 2012
Nov 01, 2012 12:15 |  #15
Pearlallica wrote in post #15194035 (external link)
That's an interesting style Pearlallica, I don't know if I'm able to do that kind of thing lol. I lamost have to have two cameras all the time, unless ofcourse I'm shooting street, then it's just me a mark II and a 35L :P
5,309 views & 0 likes for this thread, 20 members have posted to it.
1057 guests, 103 members online
