Can anyone tell me how to remove the CF Door on my 1dMkIII ?
I just picked up a new replacement from Canon......Thanks !
alexxn Senior Member 396 posts Likes: 9 Joined Nov 2011 Location: S Florida More info | Oct 30, 2012 20:25 | #1 Can anyone tell me how to remove the CF Door on my 1dMkIII ? Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
joeseph "smells like turd" More info | Oct 31, 2012 03:24 | #2 you'll have to remove some stuck-on grip bits & the back cover from the camera (12 screws) to get the pivot pin out - not a huge problem, but you'll have to be careful not to damage the ribboncable connecting the back cover to the main electronics. There's a link to the service manual on this page (thanks Lannes!) some fairly old canon camera stuff, canon lenses, Manfrotto "thingy", and an M5, also an M6 that has had a 720nm filter bolted onto the sensor:
CanonBob Goldmember 2,063 posts Likes: 52 Joined May 2007 Location: Poitou-Charentes, France More info | Oct 31, 2012 03:44 | #3 I believe that you have to remove the back cover from the body first and then the hinge pin will slide out in an upwards direction. Removing the rear cover will probably necessitate buying some new grip surface panels as they are fixed using double sided tape. 1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
joeseph "smells like turd" More info | Oct 31, 2012 04:15 | #4 Canon Bob wrote in post #15189698 Removing the rear cover will probably necessitate buying some new grip surface panels as they are fixed using double sided tape. Bob carefully removing the grip bits can result in their re-use... some fairly old canon camera stuff, canon lenses, Manfrotto "thingy", and an M5, also an M6 that has had a 720nm filter bolted onto the sensor:
Oct 31, 2012 06:27 | #5 joeseph wrote in post #15189674 you'll have to remove some stuck-on grip bits & the back cover from the camera (12 screws) to get the pivot pin out - not a huge problem, but you'll have to be careful not to damage the ribboncable connecting the back cover to the main electronics. There's a link to the service manual on this page (thanks Lannes!) how on earth did you break one? they built like proverbial brick faecal-houses... This is a classic case of "research before you buy" Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
JohnfromPA Cream of the Crop 11,257 posts Likes: 1526 Joined May 2003 Location: Southeast Pennsylvania More info | Oct 31, 2012 06:42 | #6 As an engineer, I would have attempted to use some of the RTV (Room Temperature Vulcanizing) adhesive sealants that are readily available in hardware stores to repair the covering. I have done similiar type repairs over the years and many have held up better than what was originally supplied. These sealants come in black and clear, just make sure they also state adhesive on the tube. Acetic acid is often the curing agent so use sparingly but coat all problem surfaces with a thin coat and hold in place with some duct tape.
Oct 31, 2012 07:26 | #7 John from PA wrote in post #15189952 As an engineer, I would have attempted to use some of the RTV (Room Temperature Vulcanizing) adhesive sealants that are readily available in hardware stores to repair the covering. I have done similiar type repairs over the years and many have held up better than what was originally supplied. These sealants come in black and clear, just make sure they also state adhesive on the tube. Acetic acid is often the curing agent so use sparingly but coat all problem surfaces with a thin coat and hold in place with some duct tape. As to the spring, just knowing about the shortcoming, is it a situation that one can live with? Perhaps start using the intended cable transfer of images? If not, and I say this not knowing what the spring looks like or even if accessible, but can it be stretched a bit while in place to restore its "springiness"? Thanks for the response, definitely something I can live with on both issues, if the door doesn't "spring" open I just grab it with a fingernail while opening the door release. Nikon D4S, D3, Nikkor AF-S 50 f/1.4G, Nikkor AF-S 85 f/1.8G, Nikon AF-S 24-70mm f/2.8 G ED, Nikkor AF-S 70-200 f/2.8G E VR II
joeseph "smells like turd" More info | Oct 31, 2012 16:23 | #8 alexxn wrote in post #15189929 The rubber grip is starting to come off of the CF Door I have now and also most of the time it won't "spring" open when you release it. ahh see... the grip material is just stuck on with double-sided tape so not too difficult to sort out. The spring open thing seems common with these doors - my 1D MK II has the same problem (and I had it in bits at one stage to convert to IR, so should really have spent 5 minutes looking at that while it was apart!) some fairly old canon camera stuff, canon lenses, Manfrotto "thingy", and an M5, also an M6 that has had a 720nm filter bolted onto the sensor:
| Latest registered member is MWCarlsson 1264 guests, 172 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
