Thread started 31 Oct 2012 (Wednesday) 10:40
Need advice about flashes and macro photography.
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
Oct 31, 2012 10:40 |  #1
Hi fellow photographers,
My dilemma is finding a flash that will work with my purpose (macro photography), but also for general usage (in dark lit surroundings, and a one or two portraits here and there).
There are so many too choose from, i thought i should ask for honest opinions in here.. anyway.
These are the ones i've been looking at:
Canon 430 EX II
YN-460 II
Nissin Di622 II
Sigma DG 610
I will use the flash with either a cord or a transmitter.
I've read that both nissin and sigma have firmware options to work with later canon models, the sigma and nissin have higher led count than the canon 430.
All 4 seem to work as optical slaves (off camera with built-in flash).
I dont know if i need the high led count, highspeed sync(when do you use this?), slave mode and other features, but it would be much appreciated to hear from all of you how you use them and what features you missed when buying the other option.
For me, personally, i have no problems buying the cheapest flash as long as it does the job.
Thanks in advance.
"High life on low budget"
bent photos (external link)Portfoliobox (external link)
X-Pro1 XF 35 f/1.4
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
Oct 31, 2012 12:16 |  #2
No one?
I'm used to get alot of replies, you guys are usually very fast with info and what to do.
X-Pro1 XF 35 f/1.4
Jarhed27
Joined Feb 2012
Oct 31, 2012 12:22 |  #3
The 430 exii, and 460ii will both work as optical slaves w / popup. However, for macro I don't think the popup route would be practical. So some yn 603c transceivers would probably help for all applications ( macro, portrait, etc). As far as flash brightness, both of these flashes will more than likely be more than enough for macro. All 3 items Ive mentioned are compatible w/ a 60d. I have 1- 430exii, 2-460ii, and 4-603c's, and all play nicely together at the same time.
I haven't figured out what I'm missing feature wise, having a lot of fun with this setup.
Hope that helps some.
Canon 60D, Gripped, a bunch of consumer glass, and a really cheap tripod.....
dedsen
Oct 31, 2012 13:54 |  #4
Be careful throwing around the phrase "work as optical slaves w / popup". The 430ex and the 460ii are completely different animals when you want to talk about "slave".
The Canon flash will work as a slave with the Canon proprietary master/slave system. It does not have a simple optical slave that will fire when it sees any flash.
The YN 460ii only has a simple optical slave that reacts to any flash going off. It will not work in the Canon master/slave arrangement.
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
Oct 31, 2012 14:31 |  #5
Jarhed27 wrote in post #15191081 (external link)
Thanks for the input.. do you use any wires or transmitters between the flashes?
Have you shot alot of macro with the flashes? good/bad?
X-Pro1 XF 35 f/1.4
botw
Oct 31, 2012 15:11 |  #6
I've used the 320ex (handheld) as a slave to the onboard of my 60d for some macro work. You'll need to diffuse the flash output somehow to get good light, but the system will work that way, albeit somewhat awkwardly. I'd go for that or the 430ex. The others are ok, but are significantly larger. I would avoid the YN because (I think) it is manual only.
www.gc5photography.com (external link)
Green ­ Li
Gallery: 15 photos
Oct 31, 2012 17:19 |  #7
if you are not buying a ring flash, than there is nothing special about the macro application. virtually any flash can be used for macro when on a cord. radio and optical triggering are also the options, but that, again, has nothing to do with macro. sounds ike you simply need to get a decent general purpose flash.
I've only had experience with the Nissin and Canon units from your list. Here is a comparision:
Nissin Di622 II vs Canon 430EX II (external link)
IMAGE: http://photo-tips-online.com/review/nissin-di622-mark-ii-vs-canon-speedlite-430ex-ii/images/small/nissin-di622-mark-ii-vs-canon-speedlite-430ex-ii-front-angle.jpg
IMAGE: http://photo-tips-online.com/review/nissin-di622-mark-ii-vs-canon-speedlite-430ex-ii/images/small/nissin-di622-mark-ii-vs-canon-speedlite-430ex-ii-controls.jpg
hope this helps a bit ;)
PHOTO-TIPS-ONLINE.com – photo tips, photography reviews (external link)
Facebook (external link) | Twitter (external link) | Google (external link)+
Jarhed27
Joined Feb 2012
Oct 31, 2012 18:38 |  #8
bent toe wrote in post #15191518 (external link)
I use the Yongnuo yn603c transceivers. I haven't tried any macro w/ any flash, although a macro style ring flash is probably in my future.
Jarhed27
Joined Feb 2012
Oct 31, 2012 18:46 |  #9
dedsen wrote in post #15191383 (external link)
Agreed, but, the user actions, and end result are basically the same.
bent ­ toe
Gallery: 106 photos
Best ofs: 5
Joined Jul 2012
Nov 01, 2012 04:11 |  #10
Green Li wrote in post #15192090 (external link)
Good comparision, thanks for the link.
X-Pro1 XF 35 f/1.4
watt100
Nov 01, 2012 05:07 |  #11
I've been using a YN460 and RF-602 wireless trigger for macro shots, it's a goood inexpensive setup. But if you don't have any other flashes get one with ETTL
2,493 views & 0 likes for this thread, 6 members have posted to it.
1456 guests, 128 members online
