Hello all .
I have , I belive an early 90s Canon 300mm 2.8L lens . It is obviously pre IS . Apart from this problem it is all in good condition .
Basically this is the easiest way to describe the problem.
When shooting a sequence of between 3-6 photos (Burst shooting ,1 after another) , the middle image and more frequently the last image will be randomly brighter and slightly out of focus . I presume this is a problem with my lens , as I have tested it on both of my 1d Mk2 N bodies and it does the same on both bodies .
Have any of you had this problem , and has anyone had one of these older lenses repaired recently ? Im worried that it is too old to be repaired .
Thanks Jamie
