mike3767 wrote in post #15192577
RAW, I'd gladly explain. It's because I have money to blow! I do real estate photography part time and am very busy with that. It's not my full time job so any money I make with real estate photography, I blow on camera equipment. Like I said, I'm just getting into taking people pics and am trying to figure this whole new area out. I'm not happy with the 24-105 inside. I take candids for a bunch of women that have weekly meetings. I have flash but it seems that when I take group photos, the center is nicely light but the edges are dark so I was thinking this is where I'd benefit with the 70-200.
Mike, sadly the problem with taking pictures inside of people is that in order to NOT use flash, you have to either bump up your ISO or(sometimes and) lower your fstop. Your camera should allow you to use 3200 ISO easily, you might even be happy with 6400 ISO. However, while a fast lens with a wide aperture will allow you to expose properly indoors, you're going to have shallow depth of field with these candids. This might work out well for you, but you could end up with things out of focus due to shallow depth of field that you would want in focus. If I were you I would look up "bouncing flash" and start practicing with that.
I think that better use of flash will solve your problem rather than buying a new lens.
