Hi,
i got the ST-E3 and 2 x 600EX-RT.
how can i get the HSS to be set on these bugger permanently when these units are turn on? is it possible?
cheers,
Scott
MFG Senior Member 537 posts Likes: 7 Joined Sep 2008 Location: South Australia More info | Nov 01, 2012 00:40 | #1 Hi, AIPP Accredited (Australia), WPJA
CptTripps Senior Member 567 posts Likes: 1 Joined Mar 2011 Location: Anchorage, AK. More info | Nov 01, 2012 03:26 | #2 Is it not just automatic? I have never "enabled" HSS, it just turns on when over a certain shutter speed (250 on 60D). That said, I have no Mkiii or a 600EX so.... 60D - Sigma 30mm 1.4 - 50mm 1.8 ImkII - 18-135 IS - 70-200 2.8 mkII - 2x430ex II - 3xFlextt5+AC3 - Einstein 640 w/mc2 - Vagabond Mini
5W0L3 Senior Member 998 posts Likes: 14 Joined Mar 2012 More info | Nov 01, 2012 05:10 | #3 ^ you have to enable the HSS by going into the menu on your master flash (or ST-E3 in this case) and clicking the button which says "Sync" under it.. if you can't see it on the menu, then click on "menu 2" or "menu 3" or whatever it says on the furthest right button.. once you can see an option saying "Sync", click that button and HSS will turn on and it will stay on until you decide to switch it off. Manav
Nov 01, 2012 21:13 | #4 thanks for the input. mine seems to go off when its off and batteries are out for days. AIPP Accredited (Australia), WPJA
sempaidavid Senior Member 890 posts Joined Nov 2006 Location: Fresno CA More info | Dec 07, 2012 21:24 | #5 Set in in the camera. That will over-ride and it will be in HHS all the time. At least mine do with my 1d MKIV 5D mkIII, 1D mkIV, Tokina 16-28 f/2.8, EF 24-70L, EF 70-200 f/2.8L II IS, EF 100-400L, EF 85 f/1.8, Sigma 50 f/1.4, EF 24-105
| Latest registered member is EBiffany 957 guests, 110 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
