Thread started 31 Dec 2005 (Saturday) 01:19
self: comparing flashes
berrylish
Dec 31, 2005 01:19 |  #1
welp, i finally got my 580ex today :D . the one on the left was using the built in flash. the one on the right was using the 580ex pointed up towards the ceiling. look better? i'm still trying to understand everything. its all kind of confusing.
Canon 20D
5D Mark II
50mm/1.4
70-200mm/2.8
580EX
drisley
"What a Tool I am"
Joined Nov 2002
Dec 31, 2005 01:29 |  #2
Definately, the bounced 580ex shot looks much better to me.
EOS R6 Mark II - Sigma 50/1.4 Art - Sigma 14-24/2.8 Art - Canon EF 70-200/2.8L Mark III - Godox Xpro-C - Godox TT685C x2
Wildewinds
Dec 31, 2005 01:33 |  #3
Amazing! The 580ex makes you look so much happier! ;)
- 20D - Tamron 28-75mm f/2.8 - Tokina 11-16mm f/2.8 - Canon EF 50mm f/1.4 -
Jerrytrebec33
Dec 31, 2005 01:33 |  #4
it looks 100% better, nice job
mykroid
Dec 31, 2005 02:02 as a reply to  @ Jerrytrebec33's post |  #5
as opposed to the regular flash where "the flash" makes her look all boring and sad !!! lol
davidfig
we over look the simplest things
Dec 31, 2005 02:25 |  #6
The bounce will look better as long as there is enough power and the color of the ceiling is close to white. Oh the model is cute too. Oh, that's you. [Sheepish grin]
5D | 17-40L | Tammy 28-75 2.8 | 28-135 | 50/1.8 | 85/1.8 | Sony A6000 2-Lens Kit | SEL35 1.8 | EF 50 1.8 on NEX as my 75mm 1.8
Feihung08
Dec 31, 2005 03:14 as a reply to  @ davidfig's post |  #7
How about aiming the 580 "directly" at you and comparing it to the onboard flash? Because I'm sure if the onboard flash could rotate it would also produce a (happier) better shot as well.
Canon 80D | Tamron 28-75mm | Canon 50mm 1.8 | Canon 430 EX | LensBaby 2.0
berrylish
Dec 31, 2005 03:49 as a reply to  @ Feihung08's post |  #8
then i guess theyd look pretty much the same. i suppose im making a dramatic before and after.....just like those before and after makeovers on tv hehe.
Canon 20D
5D Mark II
50mm/1.4
70-200mm/2.8
580EX
Maureen ­ Souza
Dec 31, 2005 04:08 |  #9
The 580 looks much better. I just spent this evening playing with mine too.... still trying to figure it all out. Maybe we'll learn together.
5DMK4
7DMK2
Adrian
Gallery: 17 photos
Joined Sep 2003
Dec 31, 2005 08:07 as a reply to  @ Maureen Souza's post |  #10
See if you can beg, borrow, make a device similar to Gary Fong's LightSphere II. It makes photographing with the 580 amazing.
Check out: http://secure.mycart.n​et/catalogs/catalog.as​p?prodid=4684316&showp​revnext=1 (external link)
I use the older version. IMHO it is the best one I have come across.
This is a photo of my version.
IMAGE: http://www.pop-eu.com/gallery/pics/LightSphereII.gif
I recommend it wholeheartedly (No i'm not on a commision! :lol: ), the only drawback is the shipping cost to the UK (OUCH!) I believe that I paid around $50.00 shipping which was more than the item. :evil:
Happy New Year!
All the best,
Adrian...
Do not deprive me of solitude without providing me with company. (Alexander Pope 1711)
Equipment list
vjack
Dec 31, 2005 08:23 as a reply to  @ Adrian's post |  #11
The shot with the 580 looks so much more natural. This is the kind of comparison that would be of great interest to anyone asking whether or not they need an external flash. I'm adding the 430 to my "to buy" list right now.
Canon 20D
Canon EF-S 10-22mm f/3.5-4.5 USM
Sigma 18-125mm f/3.5-5.6 DC
Tamron 28-75mm f/2.8 XR Di LD
Canon EF 50mm f/1.8 II
Canon EF 70-200mm f/4L
Canon EF 100-400mm f/4.5-5.6
L IS
Canon Speedlite 430EX
Manfrotto 3021BPRO; Kirk BH-1 ballhead
Canon Pixma 4200
< see my gallery (external link) >
JohnCollins
Joined Nov 2005
Dec 31, 2005 08:27 |  #12
You can get great results with something like this to play around with bounce. I'm not opposed to buying bounce devices from Fong, or Lumiquest, or others, but I find I get results just as good with homemade stuff, and it avoids my having a collection of a dozen of these things, which would definitely happen, if I started. ;)
You'll notice the shadow under your chin is thinner, but much sharper with the on-camera flash. When you bounce, your face does look much better, and the shadow is not as well-defined, but it is much larger.
If you use a bounce card, you can throw a little light forward when bouncing to reduce that shadow under your chin, while retaining the softer lighting quality of the bounce. Why I like my homemade device so much is I can leave it pretty far back (straight up) and get just a touch of forward light with most of it bounced. . .or I can tilt it forward more and more to increase the amount of light thrown forward and decrease the bounce.
If I'm shooting a large group or in a room with a two-story ceiling, and I'm worried about bounce providing enough light, I'll push this thing all the way forward and point the flash absolutely straight up. Now I'm reflecting all the light forward and not getting any ceiling bounce. I get a lot of light that way, but it looks softer than aiming the flash at the subjects. The effect isn't as dramatic as you see in your camera flash, bounce comparison, but the light is a little better. Direct flash is just harsher.
I made this according to a post I read somewhere and a photo of a device on Sigma's website, here:
http://www.sigmaphoto.​com …ashes_details.a​sp?id=3262 (external link)
I made mine out of two sheets of 8X10 photo paper with a sheet of aluminum foil sandwiched between. The foil prevents light loss because the paper is translucent, and the three layers give it durability. Fold the paper around the flash and mark the front sides, then cut to width. I cut a slit in the back corners, then tape both sides of the slit so it will lay flat, but bend around the flash nicely. Then I make the two folds from the top of the slits to the edge, and finally, trim to desired height. It sits flat on top of my camera gear in the bag, and slips on easily.
The control I get with this by tilting it forward/back is tremendous. I don't feel the need to start a collection of "professional" bounce gear, but hey, try it if you want. Folks seem to rave about lots of different products! I just know I couldn't stop myself once I started and this works just great.
Have fun!
John
neil_r
Cream of the Proverbial Crop
Joined Jan 2003
Dec 31, 2005 08:35 as a reply to  @ JohnCollins's post |  #13
You see the 580 was a bargain, not only did it give you a better photograph it also gave you cheek bones.
You will love it and curse it in equal measure for a while then eventually just love it.
N
Neil - © NHR Photography
grego
Dec 31, 2005 08:47 |  #14
So much better results. You'll defintely see it in your work with couples, even just for fill flash reasons.
Bouncing is fun, just need something within reasonable distance.
Omni bounce is nice too. Very simple, can of course can be homemade. :)
Oh and another good thing about a speedlight, is you won't have light fall off from longer lens.
Go UCLA (external link)!! |Gear|http://gregburmann.com (external link)SportsShooter (external link)|Flickr (external link)|
KaplanMultimedia
Dec 31, 2005 10:14 as a reply to  @ grego's post |  #15
Congratulations on the new flash. It's a wonderful tool that should serve you well for many years.
Certainly the picture with the 580EX looks much better. I also have and highly recommend the LSII, but I like John's homemade bound diffuser. I'm sure it will give very good results as well.
Keep practicing and experimenting and above all else, have fun. :D
Website: www.kaplanmultimedia.c​om (external link)
EOS 5D MIII - EOS 7D - 70-200 f2.8L IS - EF 1.4X - [COLOR=#333333]24-105mm f/4L IS - Bowens Gemini 400 2-Light Kit - Canon EF 50mm f/1.4 USM - Rokinon 85mm f/1.4 Aspherical Lens - Tokina 11-16 f2.8mm - (2) Canon 580EX flashes
4,593 views & 0 likes for this thread, 25 members have posted to it.
2439 guests, 127 members online
