Thread started 01 Nov 2012 (Thursday) 17:00
Continuous light for white muslin backdrop
firme
Joined Mar 2012
Nov 01, 2012 17:00 |  #1
I have been trying to find additional used flash heads for my speedotron d1604 (m11). No luck yet. I want to light my white muslin backdrop to avoid showing the wrinkles for longer pp and to get a white background. I have read other posts here which suggest two other flash heads, but as mentioned have not found any more speedotron m11 lights. Also searched to get non speedotron lights but they are not cheap either.
I searched on you tube to see what people use other than two flash lights. I found one who used one lamp (continuous light) which was placed on the floor but did not mentioned name of lamp. Now I have also read these are good for non moving objects. Although I am aware they get hot, they burn, from what I read, I still want to get one as will only use to light my backdrop to get that white look whether I shoot people or objects.
Can you recommend one that can be used for my purpose? Does home depot/menards have one that works well or should I stay away from those stores? Thanks in advanced.
I am trying to stay under $100 if this can be a reasonable price. The most I am willing to spend is $150.
Sittingshooter
Nov 01, 2012 20:22 |  #2
Check out Adorama Camera Supply. You can get two Flashpoint Budget 60 monolights for less than $150.00.
www.adorama.com (external link)
Brad "AKA" Sittingshooter
T4i and kit lenses
dmward
Gallery: 29 photos
Nov 02, 2012 16:02 |  #3
If you are using strobes for the main lights and hot lights for background you are going to have to color correct one or the other.
And, to get the white muslin white will take quite a bit of light.
(BTW, I see you're in East Chicago. I have 3 used Savage 150Ws strobes I'm willing to sell.)
gonzogolf
dumb remark memorialized
Gallery: 33 photos
Nov 02, 2012 16:06 |  #4
Between the color disparity, the power disparity, and the discomfort caused by bright continuous lights its a bad idea all around. You should check out David's strobes.
Hopelessdfilms
Nov 02, 2012 16:24 |  #5
Is that a brown line pack? or black line?
either way, check your local and surrounding cities craigslist pages... in chicago, there's almost always speedo gear on CL, though we do have speedo headquarters in the city, so that may be apart of the following.
Ebay is also a great place to find used heads.
Regarding using hotlights, to keep it short and add to previous replies, its just a bad idea.
I would recommend getting two packs, one pack for your background and the second for your subject.
I run a speedo 1200w pack for my background and have ample power, I usually have to split channels for least amount of power to each head and then pull to the minimum output.
My second pack is for the subject only.
If you love your speedo gear, stick with it and just add to what you currently have. Its great, will take a beating, and is ultimately a super workhorse. Speedo is great!
Keep an eye out on ebay and you should be able to scoop a kit of pack and probably a couple heads for fairly cheap.
good luck with the hunt.
just my .02c
dmward
Gallery: 29 photos
Nov 02, 2012 17:41 |  #6
^^^ That's good advice.
Its likely Helix has some used Speedo stuff. If I recall they are owned by the same company. At least they are in the same building on Racine.
firme
Joined Mar 2012
Nov 05, 2012 11:15 |  #7
Thanks all for the replies... sorry for responding late.
Hopeless, yes I do own the brown line and yes have been searching on ebay and cl. I just have to keep on looking for another pack with the flash heads.
971 views & 0 likes for this thread
Latest registered member is Birdie760
598 guests, 289 members online
