Thread started 02 Nov 2012 (Friday) 10:02
question: using an older GPU with a new motherboard
zarray
Nov 02, 2012 10:02 |  #1
Hi guys,
I have an old MSI 9600GT 512mb DDR3 GPU card running on PCIe 2.0 that I have lying around and I thought of using it for a new PC setup running the Asustek P8Z77-V LGA 1155 Motherboard with an i7-3770k chip.
Problem is the the 9600GT has 2 DVI ports while the P8Z77-V motherboard has HDMI and displayport output. Im intending to buy a Dell U2412M monitor which has a DVI-D(no idea if its the same as DVI or not) input and a displayport input.
My question is: if I connect the motherboard's displayport output to the monitor's displayport input, would I be utilizing the GPU or simply bypassing it and using the inbuilt Intel HD4000 graphics?
This issue never occurred to me in my previous custom PC build...
5D Mark II | 5Dc |17-40 | 24-105 | 70-200 F2.8 IS | Sigma 50mm 1.4 | 580EX
JoeyC
Joined Jul 2011
Nov 02, 2012 10:05 |  #2
You'd be bypassing it. There is nothing wrong with HD4000 - it is quite capable for integrated graphics.
Joe - SE Pennsylvania
Site (external link)|Gear
Moppie
Moderator
Gallery: 19 photos
Joined Sep 2004
Nov 02, 2012 16:11 |  #3
Unless your gaming, the HD 4000 is more than capable, I use one to drive a pair of 2412s on a photography work station.
If you are gaming then the 9600 is slow and out dated.
Have you Calibrated your Monkey lately?
Now more than ever we need to be a community, working together and for each other, as photographers, as lovers of photography and as members of POTN.
BlankThis
Joined Jul 2011
Nov 02, 2012 16:37 |  #4
A graphics card disables the motherboard built in graphics unit, as well as the ports. The 9600GT is an older card but still capable of playing Valve engine-based games like Team Fortress 2, Half Life 2 etc. at max quality. On more graphically advanced games you're going to have to turn down the video quality settings.
DVI and DVI-D are the same
| 5Dc | Samyang 35mm f/1.4 | flickr (external link)
zarray
Nov 02, 2012 18:27 |  #5
BlankThis wrote in post #15199889 (external link)
That is good to hear. I will utilize the 9600GT then thru the DVI port then.
I'm not using my PC setup for gaming so there's no need for me to buy the lastest DDR5 GPU cards, I just need a basic GPU for occasional use of CAD software(specifically CATIA V5).
tkbslc
Nov 02, 2012 19:55 |  #6
If you used the lucidlogic virtu option, then you could use the 9600GT through the onboard HDMI.
Taylor
EOS Rp | iPhone 11 Pro Max
1,101 views & 0 likes for this thread
Latest registered member is jgt6
819 guests, 177 members online
