Thread started 02 Nov 2012 (Friday) 22:15
European alternative to Paul C Buff (cheap+portable)
TijmenDal
Nov 02, 2012 22:15 |  #1
Hi,
I'm living in the US right now and I'm considering picking up an Alienbee and Vagabond Mini because I've heard nothing but great stuff about 'em and I would really like a portable lighting kit.
I'll be heading back in a couple months to Europe and was wondering if it would be better to pick up a kit here than back in Yurp, where everything is generally more expensive.
Is there an alternative to the Vagabond Mini and AB400/AB800?
Thanks in advance
//Tijmen
http://www.flickr.com/​photos/tijmendalexternal link
Gear
______________
flickrexternal link
_____________
Sklar
Joined May 2012
Nov 02, 2012 23:42 |  #2
sorry i can't help specifically, i love my new b800 and VML though
but, do you by any chance know how to get to chad's gap?
alyson
Nov 03, 2012 00:32 |  #3
How about Elinchrom lights? They are currently releasing new models (DRX ONE) and they are offering this "try before you buy" option. For the battery pack, why not consider Tronix Explorers (www.innovatronix.com)​?
:cool: honesty is easy, fiction is where true genius lies :cool:
tongki
Nov 03, 2012 03:00 |  #4
if you go to europe, voltage probably a problems with AB,
unless you get Einsteins, VML will also be a problems
there are several nive strobes in europe,
you can visit Calumet, www.calumet.de (external link),
I've been there and they have lots of nice products,
like Gemini, etc, I think the cost would be similar to AB products
I get promotionals Profoto D1 when I visit Calumet in Germany,
just try
EOS 70D x 2 units + EOS 7D mark II x3 units
Newton FR3, Newton modified bracket, EF 17-40mm x4,EF 24-70mm f/2.8 x2, EF 70-200mm f/2.8 x2
Quantum Trio x2, T5D-R x1 + FW7Q x1, CoPilot x2, Godox AD-180 x5
Propac PB960 head x12, PB960 battery x10
sorry, no stupid speedlite from Canon !
soundsk
Nov 03, 2012 03:34 |  #5
Hi!
Paul C Buff gear is now for sale in Europe through a distributor in the UK - http://paulcbuff.eu.co​m/ (external link).
It sells both 110V and 230V versions of the strobes.
I know this because I'm looking for the same thing. Right now I'm considering either PCB or Elinchrom.
Cheers!
http://blissphoto.eu/b​log (external link)
kokakaste2
Nov 03, 2012 12:12 |  #6
Take a look at Calumet Genesis lights, they make 300Ws battery powered lights.
http://www.calumetphot​o.nl …accuvoeding/cal​cf0510kit1 (external link)
If not take a look at Innovatronix batteries and any of the strobes they are compatible with (the list is quite long). :)
soundsk wrote in post #15201442 (external link)
Hi!
Cheers!
PCB in Europe is quite silly idea, because the price is ridiculously high when you compare to how much the same things cost in the US. :rolleyes:
Oskar (Oscar) - stuff I use- Flickr (external link) - My Facebook page (external link) :)
dmward
Gallery: 29 photos
Nov 03, 2012 12:31 |  #7
kokakaste2 wrote in post #15202352 (external link)
That could be said about a lot of things. It the nature of the import rules, and the PCB business model.
Your suggested Genesis 300B is 405 Euros for a 300 Ws light that has a very poor power control system. Not at all consistent. it would take two of them to get the same Ws power available from an Einstein.
Even though I have Einsteins and like them, if I lived in Europe I would probably buy and use Elinchrom lights. Along with the inverter mentioned.
TijmenDal
Nov 03, 2012 12:44 |  #8
Thanks for all the input everyone!
I'll go dig through the info you guys posted.
Couldn't I use AB's and VML's with 220V-110V adapters though?
Sklar wrote in post #15201047 (external link)
Didn't you hear? Ski patrol blew it up after some retard tried a switch 9! He broke both his ankles, can you believe it?
//Tijmen
Gear
______________
flickrexternal link
_____________
kokakaste2
Nov 03, 2012 12:44 |  #9
dmward wrote in post #15202404 (external link)
I understand that. It is normal that things cost here more. The big selling point of AB in the US is the price, while in Europe that kinda doesn't work. :)
Einsteins sound really amazing, but the price is not cheap. But the OP asked for cheap and portable which means adding battery to already expensive strobe. :)
TijmenDal
Nov 03, 2012 12:55 |  #10
I figured I could get a VML+AB for around 500$/400€ and that's about as much as I want to spend
Also, I couldn't find the t.1 for the Genesis lights. I would like something fast so I can also use it for action sports. 1/1000 minimum.
The Tronix Explorer Mini is ok, but quite heavy (11.2 lbs) compared to the VML (3.5lbs) as well as 200€ more expensive.
Are there any disadvantages of using a 110V Alienbees kit with adapters in 220V/240V countries?
//Tijmen
Gear
______________
flickrexternal link
_____________
Trailboy
Nov 03, 2012 13:19 |  #11
AB are not really an option outside of the US, unfortunately.
Discussed here:
http://www.flickr.com …discuss/7215763​1791004649 (external link)
While the excellent Calumet genesis guns are not linear in the power control, they are at least consistent from one to the other. I have four to go with other Eli stuff, am very pleased with them indeed, and all are:
300b 200
1/1 60 60
1/2 45 45
1/4 30 30
1/8 22 21
1/16 14 13
1/24 10 10
The 300b and battery pack is to be recommended, but Calumet are changing and refreshing the genesis range at the minute.
dmward
Gallery: 29 photos
Nov 03, 2012 14:17 |  #12
There are really not any voltage controlled monolights that have sufficiently short t.1 to stop action.
That is in the purview of the Einstein. Unfortunately, voltage controlled monolights increase flash duration when the power is reduced. On the other hand, speedlites and Einstein the flash duration gets shorter as the power is reduced.
TijmenDal
Nov 03, 2012 14:40 |  #13
Trailboy wrote in post #15202515 (external link)
Discussed here:
300b 200
1/1 60 60
1/2 45 45
1/4 30 30
1/8 22 21
1/16 14 13
1/24 10 10
What do those numbers mean?
And as far as that topic goes: that's just saying it's not worth it to buy the importer versions. I'm strictly talking about using the US 110V version. I don't see a reason why it wouldn't work.
dmward wrote in post #15202654 (external link)
t.1 for the AB400 is 1/2000, the AB800 is 1/1000. That's sufficiently fast for most uses.
//Tijmen
Gear
______________
flickrexternal link
_____________
Trailboy
Nov 03, 2012 15:19 |  #14
My answer was in response to dmwards criticism:
"Your suggested Genesis 300B is 405 Euros for a 300 Ws light that has a very poor power control system."
Yes, it isn't linear, but it is consistent. The numbers I quoted are for the power control on the genesis monolights. The formatting was cocked up by the forum formatting.
You can buy whatever you want, but in your circumstances I would opt for an einstein and pay the extra. Multi voltage, you said "I would like something fast so I can also use it for action sports", and the ABs are notoriously slow in flash duration, while the einstein is notoriously fast.
dmward
Gallery: 29 photos
Nov 03, 2012 15:42 |  #15
TijmenDal wrote in post #15202708 (external link)
That's at full power. As you reduce power the times get longer.
Also, you'd be surprised about those durations being fast enough. That's good, better than others for the most part.
Here is a link to an ad Buff put out that shows the relative difference in t.1 speeds at max and min power. http://www.paulcbuff.c​om …ads/e640_specsm​anship.jpg (external link)
10,952 views & 0 likes for this thread, 11 members have posted to it.
1059 guests, 104 members online
