mutau052 wrote in post #15202159
I have a late 2009 Mac Mini w/ 2.54ghz and i'm getting ready to add the 8GB ram and a new hard drive. I know this isn't the best computer, but for about $150 I should be able to get a new HD and 8GB ram. I'm getting the RAM at OWC for $49.95.
Do you guys have any recommendations on what I should get
OTHER THAN A SSD? I'm looking for more storage and a faster responsive hard drive. It uses a typical mac laptop hard drive (2.5" i think).
Is the cost of an SSD the reason? If so, skip to the next paragraph. If not, then you ought to consider putting in an SSD in the optical bay, if you don't need the DVD drive. That way you could have two drives in the Mini with OWC's Data Doubler. You should then be able to make your own fusion drive, provided you have Mountain Lion. I'm doing this right now in my 2010 MacBook Pro. I've already initialized the fusion drive and am using Carbon Copy Cloner to restore the files and OS from an external drive. Did it for my 2012 Mini, too (see Mini thread started by me a few days ago).
Rotational speed is one component of hard drive speed, but not the only component. The drive's platter density (all 750gb and 1 tb 2.5" drives have two platters), cache and bus speed all contribute to it. Your Mini has a 3 GB/s SATA bus that supports two drives. The current crop of 750 gb and 1 tb notebook drives are faster than past drives, so I wouldn't worry too much about rotational speed. Max out your RAM and you should be ok.
BlankThis wrote in post #15202240
http://www.newegg.com …aspx?Item=N82E16822148837
This drive has existed long before Apple's Fusion drive. Same concept though. 8GBs of flash memory paired with a traditional 7200RPM platter drive. The drive's firmware figures out which files you use most frequently (Like the boot files, and your favorite programs) and puts them in the flash memory portion, so they load like an SSD.
It appears that the disk management software of Mountain Lion really is what makes the difference in "hybrid/fusion" drive performance. From all accounts so far, fusion drives perform much better than hybrid drives.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
