When shooting a video project with a lot of video files, particularly weddings, what process do you use to import and batch rename your video files?
Sync cameras times, Adobe Bridge, file structure, etc.
ChadAndreo Goldmember 1,879 posts Likes: 15 Joined Nov 2006 Location: WPB, FL More info | Nov 03, 2012 17:16 | #1 When shooting a video project with a lot of video files, particularly weddings, what process do you use to import and batch rename your video files? Photographer + Cinematographer
JohnSims Goldmember 1,437 posts Likes: 1 Joined Sep 2006 Location: Essex & Gower UK More info | Nov 05, 2012 03:40 | #2 I don't bother renaming files but try to ensure all media , including music, animations, titling etc. is all in one directory exclusive to the project. I may then move, or import, elements into sub directories of that directory. This ensures all the media is together and can be easily backed up. Also, if the project file goes pear shaped you know where everything is. John Sims
Nov 05, 2012 03:57 | #3 I ran into an issue once where two cameras were using the same file names/number sequence and the footage got mixed up when I had to re-link the media in premiere. I figure if I can find a solution to rename all of the files from multiple cameras from a single job, I will avoid this happening again in the future. Photographer + Cinematographer
Moppie Moderator 15,102 posts Gallery: 24 photos Best ofs: 1 Likes: 451 Joined Sep 2004 Location: Akarana, Aotearoa. (Kiwiland) More info | Nov 05, 2012 04:30 | #4 I believe adobe bridge will do it. flickr
NorseHorse Member 105 posts Likes: 1 Joined Jun 2011 Location: Washington, DC More info | I do not rename files. I do not want to CHANGE the files or the file structure in any way. I import the top directory folder from the camera/card and rename it (just the top folder) according to the project. If I have six cameras and three recorders, I'll have nine folders total. Easy to organize and easy to import. Full-time freelancer.
mjkubba Senior Member 270 posts Joined Oct 2012 Location: Chicagoland More info | Nov 08, 2012 19:52 | #6 I use ACDSee for batch renaming even if it's not media related files it have great built-in tool. Canon AE-1, Canon 60D, Fujifilm JX400
| Latest registered member is semonsters 1682 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
