Hi All
I got this lens as Xmas gift (it was on my requested list).
My initial shots made me think it was suffering from front focus but the LCD preview is not the place to judge that.
I have now done some chart image test shots and have come to a conclusion ~ none of which surprises me ~ at f1.4 the DoF @ 1 to 1.5 metres is razor thin and as such even repeat shots of the chart show some small (10mm to 14mm) back / front focus variation I put this mostly down to the AF shifting ever so slightly between shots (NB This tripod mounted and using the countdown timer). Closing down to f2.8 and f4.0 I get a noticable bias to back focus but is this just the DoF 1/3 to 2/3 split showing up.
So, how have you found your 50mm f1.4 of absolute sharpness? Is there much copy to copy variation such that by getting it exchanged I will see an improvement?
I will examine the test shots more critically but would welcome any feedback. But having said that even with razor thin DoF at f1.4 with this lens I should at least expect the point of prime focus to be sharp, shouldn't I?
TIA
