Hi I have a Powershot SX40 HS, can you please tell me how I can take a photo, where I can focus on one particular item and blur the surrounding area.
Lillie
Lillie Hatchling 1 post Joined Nov 2012 More info | Nov 04, 2012 13:37 | #1 Hi I have a Powershot SX40 HS, can you please tell me how I can take a photo, where I can focus on one particular item and blur the surrounding area.
colintf Senior Member 319 posts Likes: 8 Joined Apr 2012 Location: Bristol, UK More info | Nov 04, 2012 13:46 | #2 I guess using Av mode and the lowest aperture number that you can (f2,8, f4 etc etc)
TooManyShots Cream of the Crop 10,203 posts Likes: 532 Joined Jan 2008 Location: NYC More info | Nov 04, 2012 13:58 | #3 Permanent banLook up under "panning shot." There are hundreds of ways to pan too. One Imaging Photography
imjason Goldmember 1,667 posts Likes: 3 Joined Nov 2010 Location: Bay Area, CA More info | Nov 04, 2012 14:13 | #4 are you looking for images with thin depth of field? http://en.wikipedia.org/wiki/Depth_of_field Canon gear: EOS M, Canonet QL17, SX230HS, S95, SD1200IS
Nov 04, 2012 14:19 | #5 You're going to be pretty limited by that camera. To maximize the effect you're after:
whuband Goldmember 1,433 posts Likes: 84 Joined Jul 2007 Location: Jacksonville, Florida More info | Do what Mike says. 1D4, 6D, 7D2, Sony a6000 with Sony16-70, Rokinon 12mmf2, Canon lenses: 17-40L, 17-55 f2.8, 10-22, 50mm 1.4, 85mm 1.8, 70-200mm IS 2.8, 300mm 2.8 IS, 580EXII (3), 430EX, Alien Bees.
TomReichner "That's what I do." 17,636 posts Gallery: 213 photos Best ofs: 2 Likes: 8390 Joined Dec 2008 Location: from Pennsylvania, USA, now in Washington state, USA, road trip back and forth a lot More info | Nov 04, 2012 16:25 | #7 What is it you are trying to shoot? Each subject has it's challenges, so it would be helpful if you could tell us what it is you are wanting to photograph. "Your" and "you're" are different words with completely different meanings - please use the correct one.
DanMarchant Do people actually believe in the Title Fairy? 5,635 posts Gallery: 19 photos Likes: 2059 Joined Oct 2011 Location: Where I'm from is unimportant, it's where I'm going that counts. More info | Nov 04, 2012 16:53 | #8 TooManyShots wrote in post #15206134 Look up under "panning shot." There are hundreds of ways to pan too. None of which will work if his subject is stationary. Dan Marchant
KhanhD "I need a grip . . . on my life" 1,523 posts Likes: 5 Joined Jun 2009 Location: Boston, MA More info | Nov 05, 2012 02:00 | #9 TooManyShots wrote in post #15206134 Look up under "panning shot." There are hundreds of ways to pan too. Dan Marchant wrote in post #15206722 None of which will work if his subject is stationary. Isnt panning itself a technique, and therefore, only ONE "way to pan"? Khanh Duong | KHDPhoto.com
Sorarse Goldmember 2,193 posts Likes: 25 Joined Jan 2008 Location: Kent, UK More info | Nov 05, 2012 06:39 | #10 Whether to pan or not will depend on whether the OP is referring to the effect of a shallow depth of field on a static subject, or is trying to capture a moving subject and wants to convey that impression of movement. At the beginning of time there was absolutely nothing. And then it exploded! Terry Pratchett
watt100 Cream of the Crop 14,021 posts Likes: 34 Joined Jun 2008 More info | Nov 05, 2012 16:57 | #11 colintf wrote in post #15206103 I guess using Av mode and the lowest aperture number that you can (f2,8, f4 etc etc) ![]() the best way if you can do that with the Powershot SX40 HS
Canajun Goldmember 2,881 posts Likes: 3 Joined Dec 2008 Location: Sector ZZ9 Plural Z Alpha More info | Nov 06, 2012 07:47 | #12 colintf wrote in post #15206103 I guess using Av mode and the lowest aperture number that you can (f2,8, f4 etc etc) ![]() using Av mode. So at 24mm @ f2.8, what is the best distance to the object to achieve the best results? *Excluding closeup and macro shots. Jun.Roberto.Dizon.Gregorio
SMP_Homer Cream of the Crop More info | Nov 06, 2012 07:51 | #13 As close as possible, but you might want something longer than 24mm if you want to blur out the background EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
stsva Cream of the Crop More info | Nov 06, 2012 08:22 | #14 Canajun wrote in post #15213295 using Av mode. So at 24mm @ f2.8, what is the best distance to the object to achieve the best results? *Excluding closeup and macro shots. Take a look here to see the approximate result you'll get (choose the correct sensor size) with different focal lengths, f-stops, and distances to the subject - http://www.dofmaster.com/dofjs.html Some Canon stuff and a little bit of Yongnuo.
| Latest registered member was a spammer, and banned as such! 2129 guests, 126 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
