Thread started 05 Nov 2012 (Monday) 16:31
Noise reduction w/ 5DMk2
RyanM
Nov 05, 2012 16:31 |  #1
I find that if I shoot ISO 800 or higher indoor I get a bunch of noise in my photos.
What do you guys recommend for noise reduction? Is there a good plugin for photoshop etc?
Canon 5DMKII w/grip // Canon 40D w/grip // 70-200mm f/2.8L IS // 16-35mm f/2.8L II // 50mm f/1.4 // 85mm f/1.8 // 430 EX ll
My Website (external link)
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Nov 05, 2012 16:34 |  #2
That doesnt sound right. Are you certain you are getting your exposure nailed, as underexposure pushed in post accentuates noise. Can you post a sample?
Numenorean
Nov 05, 2012 16:35 |  #3
ISO 800 on the 5D II is fairly clean when exposed properly.
L.J.G.
"Not brigth enough"
Nov 05, 2012 16:36 |  #4
Try shooting slightly over exposed and you'll find the noise will be a lot less. You can drag exposure down slightly in post without it showing noise up, but if you under expose even slightly you'll make more noise appear. As above says though, at ISO800 there should be virtually no noise at all.
Lloyd
Never make the same mistake twice, there are so many new ones, try a different one each day
Gear Flick (external link)r
RyanM
Nov 05, 2012 17:35 |  #5
Must be underexposed a tad and pushing it. Will try slight overexposure and bringing it down and see what happens
-Are there good noise reductions programs available though?
windpig
Chopped liver
Nov 05, 2012 17:39 |  #6
Never push
You should have at least 2/3 stops of overhead in exposure to recover in post.
Go ahead, spin the wheel.
René ­ Damkot
Nov 06, 2012 06:46 |  #7
LR4/ACR7 does a good job in NR. DPP has good chroma NR.
IMO, that's all you will need. The 5D2 should produce fine prints on A3 even at ISO 3200 without any additional NR.
If you think you need more NR, have a look at NoiseNinja (external link), NeatImage (external link) or Noiseware (external link).
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Picture ­ North ­ Carolina
Gaaaaa! DOH!! Oops!
Nov 06, 2012 10:01 as a reply to  @ René Damkot's post |  #8
I've run the gamut with NR tools: TLR, Noise Ninja, others.... I now use Nik dFine because, at least for me, it is far better.
Website (external link) |
1,252 views & 0 likes for this thread, 7 members have posted to it.
640 guests, 122 members online
