Thread started 31 Dec 2005 (Saturday) 17:40
I want to upgrade my lens...
RUSS-D
Dec 31, 2005 17:40 |  #1
But I am still a little unsure of what direction to go. If I understand correctly, the lower the f number on the lens, the quicker it is? I am thinking of getting the Canon EF 70-200MM F/4.0 L USM LENS , I will be shooting mostly Surf, and Moto-X with it. I have the Canon 75-300f4-5.6 III, but I so far am unhappy with the results of this lens. I get good shots with it, but I think they should be crisper than what I get out of it. Or do I just need to learn to use PS. At the moment I am using Jasc paint shop pro. Any and all help is much apreciated.
Canon 7D, Canon 30D, Canon 70-200mm f/[COLOR=black]4L USM, [COLOR=black]Canon EF 100-400mm f/4.5-5.6L USM (external link), Canon 50mm f/1.8 plastic fantastic, Tokina 12-24mm f:4 PRO-DX, Vivitar 383 zoom flash...
oh nooooo, the addiction has started to take over....... I need more, nay, BETTER Lenses!!!!!!
http://russ-dsphotography.com/ (external link)
Mitcon
Joined Jun 2005
Dec 31, 2005 17:57 |  #2
The F number relates to the size/speed of the aperture, so yes the lower the F number the faster the aperture it has. This helps in lower light situations, but if you think it means the lens will focus faster then no it wont. How fast a lens can focus depends on a couple of things but mostly the type and speed of it's focussing motors and the focal range of the lens.
The EF75-300 lens you have that your unhappy with has a fairly slow aperture and needs alot of light, it's also quite soft image wise and slow to focus but it's a consumer grade lens. If you want something faster focussing you need to look at a lens with USM or HSM etc.. depending on the brand.
The EF70-200L F4 is an ok lens but it maybe a little short in focal length for the type of shooting you do. Also do you shoot handheld or with a tripod as slight camera shake will make you images look softer also. I would think the EF100-400L or if the 300mm focal length is enough but your just after better images to look at the Sigma 100-300 f4 or maybe if you want a really fast aperture also look at the Sigma 120-300 f2.8 and both have HSM (Sigma's faster focussing system)
Cheers Wayne :D
EOS 30D+350Dx2+BG-E2+BG-E3+18-55MkII+EF 70-300IS/USM+EF 75-300IIusm+Sigma 50-500DG+Tamron SP90 f2.8Di+Sigma 17-70+Kenco MC7 2x+580EX+430EX
POTN Aussie club
grego
Dec 31, 2005 18:18 |  #3
Canon's ef 100-400 IS would be a good choice
or
Sigma's 120-300 2.8, but that is pretty pricey
Your best value under 1k for distance in my mind is Sigma's 100-300 f/4.
Go UCLA (external link)!! |Gear|http://gregburmann.com (external link)SportsShooter (external link)|Flickr (external link)|
818 views & 0 likes for this thread, 3 members have posted to it.
1650 guests, 123 members online
