Thread started 07 Nov 2012 (Wednesday) 20:29
Gun safe to store camera gear?
Pigtures
Joined Mar 2012
Nov 07, 2012 20:29 |  #1
I currently store my cameras, lenses and flashes in pelican cases and various camera bags. I use one bag for my daily gear and the rest stays home. I'm thinking that I've made it easy for a thief to carry all my gear out to their car by having it neatly packed for them.
A safe with shelves seems like a better way to store the gear I'm not using that day. Gun safes look large enough to display everything in easy sight and reach but still protected from unauthorized access.
Does anyone have suggestions on favorite safes? I'm in the USA and would hope to spend less than the price of another "L" zoom.
ocabj
Nov 07, 2012 23:54 |  #2
Cannon Safes are pretty popular in my region since they're in Southern California, but they are carried by a few Nation-wide retailers.
http://www.cannonsafe.​com/retailers.html (external link)
Jonathan Ocab - https://www.ocabj.net (external link) - http://jocabphoto.com (external link)
Pigtures
Joined Mar 2012
Nov 07, 2012 23:58 |  #3
Thanks, I was researching these earlier. Even Amazon carries them and offers free delivery to my house here in Florida. I sort of like the brand name too.
P51Mstg
Nov 08, 2012 06:05 as a reply to  @ Pigtures's post |  #4
Great idea... Started that some years ago when I got out of guns and into cameras. If nothing else it keeps everything together and the kids out....
Liberty is fine.... I have FT KNOX which is about the best on the market.... I'd say if you get something in the 800lb range you should be OK no matter what the brand.
If you know how to move it, they are easy to move.... Videos on UTUBE or PM me and I can explain. Similarly if THEY know how to move it its easy to move So you need at least one bolt into the floor. Place it in a closet if its smaller... Or somewhere out of casual sight where visitors to the house can't see it..... Also a SIGN on the front that says NO GUNS INSIDE CAMERAS only may discourage theft.....
Last, looker at the bargain shopper newspapers for a used one.... They don't wear out and sell pretty darn cheap used. $1000 should get you a very good lifetime used safe. BTW, no matter what they say, they are NOT and FAR FROM FIREPROOF. (they are ways to inprove that if you want, pretty easy too...
Also before you install, there are things to prepare. If its on a carpet, cut a piece of chairmat to fit under it (slightly smaller than safe so it doesn't show) to protect carpet from rust). If its on concrete, you need a rubber mat under it to protect from cold and hence moisture. Need an outlet installed NEXT TO THE SAFE (not behind it) to plus the dehumidifier and lights into... There are probably a few other things to mention but can't think of them now....
Immediate solution.... Tether your Pelican cases (I do it in the car).... Attach a bolt to something solid.... Go to HOME DEPOT and buy a couple of decent padlocks and a security cable (next to padlocks)..... Attach locks to cases and string cable through the locks.... Makes it hard to run off with cases bolted to the floor or door frame, etc......
Best wishes..
Mark H
Too Much Camera Stuff......
LowriderS10
Nov 08, 2012 06:22 |  #5
If you're going to be bolting stuff to the floor (which seems like a decent idea), why not get a lockable climate controlled cabinet for your cameras and bolt that to the floor.
Alternately...why not just insure your gear? For the price of one of these massive gun cabinets (and moving/installing it), you could add your cameras to your home insurance for a hundred years...and then you'll be covered while you travel, drop your camera into the water on a boating trip, etc...Just a thought.
-=Facebook=- (external link)
-=Flickr=- (external link)
-=Gear=-
BufordFZ1
Joined Oct 2011
Nov 08, 2012 08:53 as a reply to  @ LowriderS10's post |  #6
Liberty safes are a economical solution if you can find one in your area. Bass Pro and other outdoor stores usually carry a small selection to choose from and usually have sales quite frequently.
My recommendation is to buy one that weighs @ 800 - 1000 lbs. Getting a smaller, lighter safe runs the same risk as you current Pelican storage solution. If it weighs 200 - 400 lbs, 2 people could push it over and slide it out of the house down stairs causing even more damage to the house than the equipment inside might be worth.
A2, 60D, 5DII
Canon EF 17-40mm L
EF 100mm L
Canon EF 70-200mm f/2.8L
Canon EF 400mm f/5.6L USM,Canon 50 1.4, 430 EXII,580 EXII
OneJZsupra
Nov 08, 2012 11:59 |  #7
I don't see why this wouldn't be a bad idea IF you have the space for it and the extra scratch for it as well.
Gear List | Feed Back | My Site (external link)
YN RF-603 O-ring solution
marchboom
Nov 08, 2012 13:18 as a reply to  @ OneJZsupra's post |  #8
Keep in mind that you will be putting other valuables in the safe so get one larger than what you think you'll need. Some insurance companies might even give you a discount because you have a safe.
I use the large silica bags (in boxes) to soak up any moisture rather than an electrical device. In 25 yrs I've not had any moisture damage problems. When the indicator turns pink (instead of blue) you put the bags in the oven for a few hours and that drys it out and it's good for another 3-4 months. Got mine at Cabela's.
NU27D
Nov 08, 2012 13:36 as a reply to  @ marchboom's post |  #9
A gun safe is a great way to go!
Costco has a couple of great gun safes available.
Also gun shows are a great source for safes and in many cases those vendors deliver at a fair prices.
Bolting it to the floor is a must.
A"Goldenrod" can be had for around $20.00 which is a low temp electrical warming rod for humidity concerns.
http://www.goldenrodde​humidifiers.com …and_locker_prot​ection.htm (external link)
Desiccant (silicon) can also be used to control humidity.
Lighting is easy with "stick up" appliances.
silvrr
Gallery: 13 photos
Nov 08, 2012 13:53 |  #10
LowriderS10 wrote in post #15221399 (external link)
This seems like a much better idea. Its cheap to insure your gear and protects it when its not at home and from a variety of issues.
I trashed a 7D and 70-200 awhile back and it was Friday when I got my gear from B&H and I called in the claim on Monday so you wouldn't even be out of your gear for very long if the worst case happens.
Past Sale Feedback
dawgfan
Nov 09, 2012 07:34 as a reply to  @ silvrr's post |  #11
I like the idea of a gun safe for my camera gear as well. Matter of fact, I use a Stack On brand safe. They make a wide variety of sizes and protection levels (thickness, fire,drilling, etc.).
My thought is that if it can't be stolen, then I don't have to file a claim :)
Insuring gear for outside use and travel is obviously a good idea too.
Husband, Father, Brother, Son, Friend
Feedback
Gizmo1137
Nov 09, 2012 09:03 as a reply to  @ dawgfan's post |  #12
I used an idea posted on this forum when the topic of safes came up. A lockable tool cabinet. I have bolted mine to a wall, organizes my gear well, less expensive than a safe and still offers a measure of security... that and insurance.
Best, Bruce
rick_reno
Nov 09, 2012 09:49 |  #13
I have a Ft Knox safe, it's roughly 72"H x 41"W and 29"D and weighs almost 1800 lbs. and is rated to do well in a fire (I don't recall the details). I store rare books in it. The only thing I don't like about gun safes is they're an obvious target for a thief.
gjl711
"spouting off stupid things"
Nov 09, 2012 09:58 |  #14
I'm with Lowrider, why not just insure your gear. It's cheaper, easier, and your covered both inside and outside the house. Also, it's covered in case of fire.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
ocabj
Nov 09, 2012 14:18 |  #15
I prefer the gun safe idea along with insurance. Plus, you should have a gun safe anyway for your guns.
17,908 views & 0 likes for this thread, 32 members have posted to it.
Latest registered member is Vinz_Evo
844 guests, 173 members online
