5dii. Manual mode. Should this be happening and could the transmitter be to blame since it was a Cactus 4 that I used on my Pentax system?
Since its not ettl...I'm pretty sure they use the same connection.
I'll post an image to clarify.
ganginwood Senior Member ![]() 379 posts Likes: 9 Joined Apr 2009 More info | Nov 09, 2012 06:53 | #1 5dii. Manual mode. Should this be happening and could the transmitter be to blame since it was a Cactus 4 that I used on my Pentax system?
Nov 09, 2012 07:04 | #2 Also...at or below 1/125th it's fine which makes me question the speculation of a fault transmitter.
Lowner "I'm the original idiot" ![]() 12,924 posts Likes: 14 Joined Jul 2007 Location: Salisbury, UK. More info | Nov 09, 2012 07:06 | #3 Sorry, but I don't understand what you are asking? Richard
lazer-jock Don't mess ![]() 1,557 posts Joined Jan 2009 Location: Lincoln, Nebraska More info | Nov 09, 2012 07:12 | #4 It is likely the radio trigger. If it was a fault of the body, it would be splashed all over the internet by now. I'm off lining my cage with newspaper.
dedsen Goldmember ![]() 2,580 posts Likes: 27 Joined Aug 2006 More info | Nov 09, 2012 07:31 | #5 When was the last time you changed the batteries in the wireless triggers? This is usually the cause of slow sync speed.
I'll check the batteries. I can change them in the receivers but not the transmitter. I'll have to look it up. I've been wondering how to do that for 2 years. Again...they are Cactus V4's.
Nov 09, 2012 07:42 | #7 I just want to make sure this is not the body itself as the wireless system was flawless at 1/180th with my other system. 1/180th was max SS.
dedsen Goldmember ![]() 2,580 posts Likes: 27 Joined Aug 2006 More info | Nov 09, 2012 08:07 | #8 It looks like the transmitter takes a L1028 Battery. From your statement that you do not know how to change it, I would bet this is your problem.
shooterman village idiot, actually a genius! ![]() More info | Nov 09, 2012 08:49 | #9 ganginwood wrote in post #15225712 ![]() I'll check the batteries. I can change them in the receivers but not the transmitter. I'll have to look it up. I've been wondering how to do that for 2 years. Again...they are Cactus V4's. ??? 5 seconds to type in "how to change batteries in cactus v4" in Google pulls up this Flickr discussion with pics: Changing Cactus V4 Transmitter Batteries Randy
Nov 09, 2012 08:55 | #10 To be fair....you should've done this if you were looking for style points!
shooterman village idiot, actually a genius! ![]() More info | Nov 09, 2012 09:05 | #11 ganginwood wrote in post #15225980 ![]() To be fair....you should've done this if you were looking for style points! http://lmgtfy.com …ge+batteries+in+cactus+v4 ![]() Thanks though. It should solve my problems
Randy
doidinho Goldmember ![]() 3,352 posts Likes: 19 Joined Aug 2007 Location: Kenmore, Washington More info | Nov 09, 2012 09:26 | #12 ganginwood wrote in post #15225628 ![]() Also...at or below 1/125th it's fine which makes me question the speculation of a fault transmitter. This, drop your shutter speed down to 1/125; that's the real sync speed for a 5dmk2 when using wireless triggers. Robert McCadden
doidinho Goldmember ![]() 3,352 posts Likes: 19 Joined Aug 2007 Location: Kenmore, Washington More info | Nov 09, 2012 19:38 | #14 BrandonSi wrote in post #15228109 ![]() 1/160 is rock solid for my 5D2 + cybersyncs, so if you're stuck below that, it's definitely your transmitter / receivers. It's fairly well documented that due to latency the working sync speed with radio triggers is 1/125 for the 5dmk2. It's likely that you may not be noticing the exposure falloff toward the edge of the frame, but it's likely there. If you shoot outdoor w strobes you probably won't notice it. Depending on the lighting and composition it is sometimes hard to see even in studio situations. Robert McCadden
BrandonSi Nevermind.. I'm silly. ![]() More info | Nov 09, 2012 19:44 | #15 doidinho wrote in post #15228141 ![]() It's fairly well documented that due to latency the working sync speed with radio triggers is 1/125 for the 5dmk2. It's likely that you may not be noticing the exposure falloff toward the edge of the frame, but it's likely there. If you shoot outdoor w strobes you probably won't notice it. Depending on the lighting and composition it is sometimes hard to see even in studio situations. Shoot enough studio shots above 1/125 though and you will see the exposure falloff sooner or later. I've got thousands of studio images in LR, and plenty online with EXIF intact saying otherwise, so we'll just have to agree to disagree there.
y 1600 |
Log in Not a member yet?
Registered members may log in to forums and access all the features: full search, image upload, follow forums, own gear list and ratings, likes, more forums, private messaging, thread follow, notifications, own gallery, all settings, view hosted photos, own reviews, see more and do more... and all is free. Don't be a stranger - register now and start posting! |
Latest registered member is RRRAlaskan 654 guests, 247 members online Simultaneous users record so far is 15144, that happened on Nov 22, 2018 |
