Thread started 09 Nov 2012 (Friday) 12:54
Looking for D-lite 4 IT users to test their lights for me
TheLostVertex
Nov 09, 2012 12:54 |  #1
I am shopping around for inexpensive studio heads with good shot to shot power and color consistency. As I can not find information about power consistency online, I am hoping some D-lite users would be willing to test their equipment and post the results.
Ideally one would set their camera in manual, and test the highest and lowest power level each at about 5-10 shots at timed intervals from each shot. Then see how many stops the power level deviates between the series of shots. Testing either with a light meter or by pointing at a flat slightly out of focus surface and calculating in post should work well I would think. Also testing the amount of time between each.
I would guess off hand that the amount of variance will change with power level, and spacing between photos.
Look forward to any results people can come up with.
Steven R.
500px (external link)
hawk911
Nov 09, 2012 14:39 |  #2
so you want to make sure that each image is going to have the same meter reading? Elinchrom is one of the better strobes for this, from everything I've read.
HAWK Photography Gallery (external link) FB Fan page (external link)|_My gear: 5d3, 70D & 40D (all gripped), 580exII, 550ex, Canon 24-70 L & 85 f1.8, 50mm f1.4; Tamron 70-200 SP Di VC, Canon 18-55, Sigma 1.4xtc; Elinchrom Whore, Skyport triggers, Speedotron BD and Kacey Grid, Vagabond minis
TheLostVertex
Nov 09, 2012 15:22 |  #3
hawk911 wrote in post #15227280 (external link)
Yes, this is what I want. I am looking for each image to have as close to the same exposure as possible. Currently speed lights seem to have generally a bit too much variance between exposures, which causes some more work for the type of images I wish to use it for.
Steven R.
hawk911
Nov 09, 2012 15:38 |  #4
just about any light run from AC current is going to be better than a speedlight. You have a somewhat variable power source that can fluctuate depending on how fast you activate the flash.
hawk911
Nov 09, 2012 15:40 |  #5
did you try searching on strobe power consistency?
elinchrom consistency
TheLostVertex
Nov 09, 2012 16:24 |  #6
hawk911 wrote in post #15227453 (external link)
I have.
I have read that thread, and it did not provide any real insight into the information I am looking for, unfortunately. The only things stated are off the cuff remarks that seem a bit too much like guesstimations for my tastes :D
Steven R.
windpig
Chopped liver
Nov 09, 2012 17:05 |  #7
I wouldn't sweat it. The DLite4's consistency is so close it's not worth worrying about, and I'm pretty anal. I've got 2 of them, along with a BXRi500, Ranger and Quadra Packs.
Go ahead, spin the wheel.
TheLostVertex
Nov 09, 2012 23:09 |  #8
windpig wrote in post #15227714 (external link)
I am looking for test results. I am not asking a vague 'is it good' question, but rather looking for some actual data about its performance.
Steven R.
Csae
Nov 10, 2012 04:52 |  #9
TheLostVertex wrote in post #15227404 (external link)
This answers your question perfectly and is one of the first posts in the thread you were linked.
TMR Design wrote in post #11989676 (external link)
I've owned Elinchrom's from D-Lite's to the RX's and have never found any of them to have no more than 1/10 or possibly 2/10 stop variation, and if there was a 2/10 stop variation it was 1 out of every 20 or so. Most often, Elicnhrom's don't show more than 1/10 stop variation, and this applies to all power levels. The Elinchrom's don't exhibit greater variation at low power.
If you're experiencing anything more than that then you might have a defective strobe.
Feel free to call me Case.
CasePhoto.ca (external link) - FanPage (external link)
-Montreal based Photography.
windpig
Chopped liver
Nov 10, 2012 07:34 |  #10
TheLostVertex wrote in post #15228657 (external link)
I understood your question, and vague is a pretty generalized word. The problem with what you're trying to do if you had the light to test yourself, is that you may not get perfect exposure when going from one power setting to another based on the fact that lenses are necessarily perfect with aperture changes.
I did something similar, but not over the complete power range, when I was calibrating my meter and bodies. This is when I realized how fruitless measurbating this sort of stuff was to the extent you want to do it.
TheLostVertex
Nov 10, 2012 10:05 |  #11
Csae wrote in post #15229144 (external link)
It does not. He does not state this is from actual testing, so I can only assume it is a winged guess unless I am told otherwise. Guesses have very variable accuracy and are not sufficient to my purposes.
Steven R.
TheLostVertex
Nov 10, 2012 10:09 |  #12
windpig wrote in post #15229353 (external link)
This is true, however I shoot with locked apertures when I need shot to shot accuracy. Even then, lights will generally vary the exposure more than the electronic apertures in modern canon lenses.
And it may be fruitless for your purposes, however I do need as consistent lighting as I can afford to get.
Steven R.
windpig
Chopped liver
Nov 10, 2012 13:00 |  #13
Hmm, I may be up for this if I get some time. What are you shooting?
Csae
Nov 10, 2012 14:26 |  #14
So you ASSUME he didn't test or didn't test it correctly and just gave some random numericals....
Ok.
Why are you encouraging him windpig?
Just for the record, i did go out and test it myself, but i will assume that you will assume that i somehow ****ed it up, so i won't bother posting the results. I was however surprised to see that i did indeed get 2/10ths variation on my 580EX.
windpig
Chopped liver
Nov 10, 2012 14:32 |  #15
Hi Case:)
2,245 views & 0 likes for this thread, 5 members have posted to it.
1461 guests, 143 members online
