as above - is there any method that can do so without compromise? right now i just use LR4.2 to fix the 'flattened sides', but the downside is that it sacrifices some of my corners.
suggestions welcome!
the.forumer Senior Member 415 posts Likes: 1 Joined Oct 2011 More info | Nov 11, 2012 08:55 | #1 as above - is there any method that can do so without compromise? right now i just use LR4.2 to fix the 'flattened sides', but the downside is that it sacrifices some of my corners.
Nov 11, 2012 09:06 | #2 leave a little margin when framing the shot, so you can afford to straighten the edges Check out my photos at http://dkoretz.smugmug.com
Nov 11, 2012 09:48 | #3 there are times when the room is really small and i'm doing group shots with ppl @ the edges. :/
Kolor-Pikker Goldmember 2,790 posts Likes: 59 Joined Aug 2009 Location: Moscow More info | Nov 11, 2012 09:57 | #4 ...umm shoot wider. Removing barrel distortion is mutually exclusive with keeping the edges in the frame. I suppose you can use the transform tool in Photoshop to do this, but I'm not sure if it'll give a satisfactory result. 5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | As long as we get rectangular sensors this will be a problem. I can see no solution to it other than framing slightly "looser" to allow for some cropping after attending to the distortion. If we are ever offered circular sensors, then the problem ceases. Sadly I believe thats highly unlikely to ever happen, even though it would bring other advantages with it. Richard
ArcticShooter Goldmember 1,828 posts Likes: 1 Joined Dec 2006 Location: Arctic Norway (Tromsø) More info | Nov 13, 2012 11:09 | #6 |
Nov 15, 2012 02:56 | #7 doesn't it do the same thing as correcting for barrel distortion in LR?
ArcticShooter Goldmember 1,828 posts Likes: 1 Joined Dec 2006 Location: Arctic Norway (Tromsø) More info | Nov 15, 2012 05:00 | #8 |
Nov 15, 2012 05:56 | #9 the.forumer wrote in post #15232618 as above - is there any method that can do so without compromise? No - it's a simple matter of geometry. Frank Hollis - Retired mass spectroscopist
| Latest registered member is semonsters 1504 guests, 134 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
