Thread started 12 Nov 2012 (Monday) 13:58
How can i correct this "effect" and avoid it in the future?
imranali
Joined Jan 2012
Nov 12, 2012 13:58 |  #1
Hi folks,
I did a shoot for a friend and whilst i had a blast experimenting i noticed a undesired effect on a few of the pics
5184
x
3456
TOO LARGE!
EMBED PREVENTED, IMAGE TOO LARGE:
http://img593.imagesha​ck.us/img593/1566/img0​114ec.jpg
Click here to see our image rules.
on the right cheek of the model (the left cheek on the picture) the peach skin effect going dark
it seems not quite right. its hard to explain why i'm unhappy with that but it just seems as if the the colours werent picked up right - i'd assume it would have to do with the fact that side wasnt lit up
would it be a case of popping a reflector to light that side up slightly or is it more technical on the camera side of things
http://www.facebook.co​m/ialiphotography (external link)
Full website to come soon!!
sandpiper
Nov 12, 2012 14:16 |  #2
Looks like you just need to pay more attention to your lighting ratios. Adding a little more light to fill that shadow a bit more would sort you out. A reflector would do nicely, or another light (set lower in power to your main light).
dmward
Gallery: 29 photos
Nov 12, 2012 14:33 |  #3
Generally, if one wants to get smooth lighting for a closeup like this, place the light above the camera and then use a reflector under the camera to reflect up filling the shadow under the nose.
Care has to be taken that the light does not end up looking spooky.
For this image, try using Lightroom shadow slider to lighten the right side of the model's face.
Or leave it like it is, I like it.
imranali
Joined Jan 2012
Nov 12, 2012 20:35 |  #4
this is what i did to it...
yay? nay?
5184
x
3456
TOO LARGE!
http://img33.imageshac​k.us/img33/9025/img011​42g.jpg
dmward
Gallery: 29 photos
Nov 13, 2012 10:40 |  #5
Not sure how you feel about someone doing adjustments to your image(s) and then posting them so I'll just tell you what I did.
Took your image into Lightroom 4.2 and worked with the basic develop panel. Using those sliders its possible to get the the look you are interested in without too much trouble.
imranali
Joined Jan 2012
Nov 14, 2012 10:52 |  #6
dmward wrote in post #15240601 (external link)
no its fine i dont mind seeing the result if at all possible!
tonylong
...winded
Gallery: 60 photos
Nov 14, 2012 15:13 |  #7
imranali wrote in post #15244781 (external link)
Go to your user profile and turn on "IMAGE EDITING OK"!
Tony
jeppoy
Joined Sep 2009
Nov 14, 2012 15:16 |  #8
the right cheek is over exposed and you can need color correction, your white balance is way off and yellow is bleeding off on the skin. buy a lightmeter it really is a great tool for studio lighting
No I'm not a photographer, I just shoot with Canon DSLR with those lenses with red thingy...;)
www.digital-xpression.com (external link)
windpig
Chopped liver
Nov 14, 2012 15:48 |  #9
I'd feather the SB more across her face.
Go ahead, spin the wheel.
dmward
Gallery: 29 photos
Nov 15, 2012 13:28 |  #10
Here is your file with the adjustments I made in Lightroom develop module.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/11/3/LQ_623795.jpg
Image hosted by forum (623795) © dmward [SHARE LINK]
Kolor-Pikker
Nov 22, 2012 06:04 |  #11
dmward wrote in post #15249486 (external link)
The problem now is color artifacts where the shadow used to be, it's not that easy to lift shadows unless you have the raw file, because the jpeg compression threw out the color and detail information in the shadow. If you upload the raw I might take a crack at it for kicks.
It's certainly something one could even out in post, but you may want to try a lightmeter out, it definitely helped me get into the groove of using flash.
5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
I acquired an expensive camera so I can hang out in forums, annoy wedding photographers during formals and look down on P&S users... all the while telling people it's the photographer, not the camera.
dmward
Gallery: 29 photos
Nov 22, 2012 09:35 |  #12
Kolor-Pikker wrote in post #15275438 (external link)
There may have been some color tweaking that could have been done in the HSL panel, but yes, this really needs to be done on a raw file with all the data available from the camera.
Getting the lighting right when shooting certainly is the preferred approach.
For what the OP is looking for I'd probably start with a large source right above the camera.
2,711 views & 0 likes for this thread, 7 members have posted to it.
1344 guests, 166 members online
