kirkt wrote in post #15239951
It sounds like you want to create a new layer that has the background plus all of the adjustments burned into it for further editing. You want to Stamp the layer stack, select the layer on the top of the stack and - CMD-SHIFT-OPTION-E (CTRL-SHIFT-ALT-E). THe stamped version will be a layer with all of the adjustments burned into it, and it will appear at the top of the stack.
kirk
i think that this is it. I will give it a go.
Thank you all that replied. I know I may not have described it just right.
I do use adjustment layers often. But, for example..........
Start:
Background layer
Copy
Make minor edits
Copy again......adjust color, tone whatever.
Then, i work on skin....this one has very pale skin with some acne and redness around the nose.
I created new layers, not copies of anything, to fix each area and adjust the opacity as i like.
After these layers are done, I see that i need to remove a hair near his eye.....I can't perform the action on top of the added layers. I need to do the action using the background layer, i think. does this make any more sense?
And I want to save the PSD work flow. I cant merge all the layers and save the flow can I?
