Thread started 13 Nov 2012 (Tuesday) 12:35
70-200mm f2.8 IS II Image shift when IS engages?
Dorian7
Gallery: 20 photos
Joined Nov 2012
Nov 13, 2012 12:35 |  #1
Hi all,
This quesiton is for owners of the 70-200mm 2.8 IS II. I recently noticed something a little different than I have experienced in the past. I noticed that when you look through the viewfinder, press the shutter button half way to focus the image "shifts" a little when the IS engages. Is that normal? It only happens right when it starts and then it proceeds to stabilize like normal.
Just wanted to see if this is something I should be concerned about.
Thanks in advance.
A7II - FE 55 F1.8, FE 70-200 F4, Batis 85mm F1.8, Canon FD 24mm F2.8
Follow me on Instagram (external link)
Invertalon
Nov 13, 2012 13:02 |  #2
Yes, the IS has to 'spool up' and it takes a second or two before it is ready to go.
-Steve
Facebook (external link)
dexy101
Gallery: 93 photos
Nov 13, 2012 13:03 |  #3
I never knew this and ill have to look out for it.
Dorian7
Gallery: 20 photos
Joined Nov 2012
Nov 13, 2012 22:23 |  #4
Thanks Invertalon,
I just thought it was weird that the viewfinder kind of jumps on start-up. Glad to know it's normal.
lostinwv
Nov 13, 2012 23:10 as a reply to  @ Dorian7's post |  #5
Mine does what you describe, which I have assumed to be normal behavior. The one thing that mine does that I'm not sure about is: it makes some weird rubbing sounds when spooling up/down when I'm being physically spastic with the lens (meaning, when I'm lowering and raising the lens while the IS motor is in various states of starting/stopping). When I hold the thing level, no weird rubbing sounds...
Very curious what others think of this...
Dave
lux.sit
Joined Mar 2012
Nov 13, 2012 23:33 |  #6
Yes it does. Also, if the object you are trying to focus doesn't have a clear contrast with the background it will shift quite a bit. I believe this is call lens hunting.
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Nov 13, 2012 23:55 |  #7
lostinwv wrote in post #15243290 (external link)
Dave
Perfectly normal; it's the IS system having to work harder to try and keep up when you're moving the lens around.
kawi_200
Gallery: 10 photos
Joined Jul 2011
Nov 14, 2012 00:45 |  #8
It happens on all my IS lenses. It is a normal function, nothing to be worried about.
5D4 | 8-15L | 28-135mm f/3.5-5.6 IS | 24L II | 40mm pancake | 100L IS | 70-200mm f/2.8L IS mk2 | 400mm f/4 DO IS
Stone ­ 13
Nov 14, 2012 01:27 |  #9
happens to my 70-200 also, I thought something was wrong since alot of people said their IS was completely silent while mine was clearly audible. I even sent it to Canon and it checked out fine. It wasn't until I tested a couple of copies at my local shop that I was confident the IS noise was normal.
Ken
Fujifilm X100T | 5D III gripped |35L | 24-70 2.8L II | 70-200 2.8L IS II | 85 1.8 | 430 EX II | Yongnuo YN-568EX | Billingham 445 | Think Tank UD 60 |
FrayAdjacent
Joined Aug 2012
Nov 14, 2012 03:59 |  #10
Sounds like what happens with my 17-55 2.8. I just got it, and can see the image really move sometimes. If you're moving a bit while looking through the viewfinder, it can actually get a little dizzying!
I guess on the good side, you KNOW the IS is working!
Fray: a usually disorderly or protracted fight, struggle, or dispute
Adjacent: not distant, immediately preceding or following
Canon 7D gripped | Canon EF-S 17-55mm f/2.8 IS USM | Canon 70-200mm f/4 L | Sigma 18-250mm f/3.5-6.3 DC HSM Macro | Canon 50mm f1/8 II
1,699 views & 0 likes for this thread, 9 members have posted to it.
1673 guests, 138 members online
