I'm still on a steep learning curve with the Canon 7D and Mk 2 70-200 'L' lens. Any helpful comments will be appreciated.
ChrisHall Member 98 posts Joined Oct 2012 More info | Nov 14, 2012 07:26 | #1 I'm still on a steep learning curve with the Canon 7D and Mk 2 70-200 'L' lens. Any helpful comments will be appreciated.
Lonnie Goldmember 1,606 posts Likes: 1 Joined Feb 2006 Location: Southern Louisiana More info | Nov 14, 2012 07:37 | #2 Hi Chris, My YouTube Vlog: https://www.youtube.com/c/GarageFlips
Nov 14, 2012 08:15 | #3 #1 looks good -- Image Editing OK --
Nov 14, 2012 08:20 | #4 Qbx wrote in post #15244225 #1 looks good #2 looks like it could be sharper - did you sharpen in post? #3 I agree with Lonnie. Thanks Qbx and Lonnie. I wish I hadn't posted the third pic as I agree with both of you! I did sharpen the robin in PP. I was using the 2x extender which affected picture quality.
Nov 14, 2012 08:26 | #5 Lonnie wrote in post #15244145 Hi Chris, #1 - Is ok, but does the bottom half of the photo seem dark or is it just me? Did you use a flash for this one? #2 - Really sharp! #3 - Not liking this one at all. There seems to be something, bar maybe, in the foreground on the left and right. The fountain water looks little underexposed and flat to me. I don't like taking pictures of people turned away unless I have a good reason. Thanks Lonnie. No flash used for any of these.
Flo Gimmie Some Lovin 44,987 posts Likes: 16 Joined Jul 2007 Location: Nanaimo,B.C. More info | Focus seems soft on all for me. Was it a high ISO you used? you're a great friend, but if Zombies chase us, I am tripping you.
Nov 14, 2012 12:34 | #7 Flo wrote in post #15244774 Focus seems soft on all for me. Was it a high ISO you used? ISO was 400 on the cat and the robin and 800 on the other photo. I probably should have lowered it. Thanks for your help.
Flo Gimmie Some Lovin 44,987 posts Likes: 16 Joined Jul 2007 Location: Nanaimo,B.C. More info | Nov 14, 2012 13:43 | #8 Chris Hall wrote in post #15245225 ISO was 400 on the cat and the robin and 800 on the other photo. I probably should have lowered it. Thanks for your help. ![]() The cat just shows to be oddly soft in areas.it may be motion blur.I am seeing quite alot of noise as well in these?Are they large crops? you're a great friend, but if Zombies chase us, I am tripping you.
Nov 14, 2012 13:52 | #9 Flo wrote in post #15245498 The cat just shows to be oddly soft in areas.it may be motion blur.I am seeing quite alot of noise as well in these?Are they large crops? Yes, they are quite large crops. I guess I just need to get closer to the subjects and crop less.
Titus213 Cream of the Crop More info | Nov 14, 2012 14:56 | #10 Flo wrote in post #15245498 The cat just shows to be oddly soft in areas.it may be motion blur.I am seeing quite alot of noise as well in these?Are they large crops? +1 - something just not quite right with the cat photo. Dave
Nov 14, 2012 15:04 | #11 Titus213 wrote in post #15245837 +1 - something just not quite right with the cat photo. The bird looks a bit odd too. I shoot a 7D, 70-200, and quite often a 2X. It will soften the images but that's not what I see here. Not sure what it is. Can you post the exif? And does the 70-200 have IS? Hi Dave. The lens does have IS and it was active. I'm new to all this but will try to find the exif data when I get home.
Nov 14, 2012 18:09 | #12 Titus213 wrote in post #15245837 +1 - something just not quite right with the cat photo. The bird looks a bit odd too. I shoot a 7D, 70-200, and quite often a 2X. It will soften the images but that's not what I see here. Not sure what it is. Can you post the exif? And does the 70-200 have IS? Here's the exif data Image hosted by forum (623691) © Chris Hall [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
Titus213 Cream of the Crop More info | Nov 14, 2012 18:53 | #13 Well, the exif isn't helping me. You were shooting wide open and appear to have had plenty of light. Shutter speed was sufficient to stop both camera shake and subject movement. Dave
Titus213 Cream of the Crop More info | Nov 14, 2012 19:43 | #14 Are you using single, user selected AF point, and single shot AF? Dave
Nov 15, 2012 04:30 | #15 Titus213 wrote in post #15246795 Are you using single, user selected AF point, and single shot AF? Yes to both.
| Latest registered member is IoDaLi Photography 1744 guests, 135 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
