Thread started 01 Jan 2006 (Sunday) 13:55
Canon EF 70-200mm f/4L USM....
RUSS-D
Jan 01, 2006 13:55 |  #1
I am considering this lens. It would be for shooting Surf, and moto-x type stuff if I get it. Would this be a good choice. Most of the time when the surf is up around where I live, it is overcast. Will this lens work good in lower light? And also, will it work with a 1.4 or 2.0 TC? Thanks for the advice.
Canon 7D, Canon 30D, Canon 70-200mm f/[COLOR=black]4L USM, [COLOR=black]Canon EF 100-400mm f/4.5-5.6L USM (external link), Canon 50mm f/1.8 plastic fantastic, Tokina 12-24mm f:4 PRO-DX, Vivitar 383 zoom flash...
oh nooooo, the addiction has started to take over....... I need more, nay, BETTER Lenses!!!!!!
http://russ-dsphotography.com/ (external link)
Tyger
Jan 01, 2006 14:04 |  #2
It's a great lens with goos available light, personally i have no trouble in overcast days but it can hunt in dark shade or less than ideal lighting situations. I use the Kenko Pro 1.4 teleconverter with good results and very little loss of quality, but the AF isn't as fast. Again in good lighting it works well. Personally i think it might be a little slow for action shots on overcast days. Have you looked into the Sigma 70-200mm 2.8?
You create your reality.
jjonsalt
Jan 01, 2006 14:05 |  #3
Action, low light, you need a larger maximum aperture. Look at the 85 f/1.8, 100 f/2, 135 f/2, 200 f/2.8 and the 70-200 f/2.8.
DavidEB
Jan 01, 2006 15:09 |  #4
not remotely long enough for surfing (might work if you're out on a boat). I suggest you go try to shoot some surfers with your 75-300, and see if that focal length works for you. Unless the break is really close in, you're going to need more. I use a 300mm f4 with a 1.4x tcon, and crop down to 1/4 of each shot.
As for aperature, if you're shooting at dawn/dusk or on cloudy days, your surf photos will be dingy gray rather than bright colored, no matter what lens you use.
David
my stuff - [URL="http://www.pbase​.com/davideb"]my gallery - [URL="http://photograp​hy-on-the.net/forum/showpost​.php?p=3928125&postcou​nt=1"]go Rats!
ACDCROCKS
321 123 33
Jan 01, 2006 15:11 |  #5
A sigma 50-500MM might help. I'm not sure of it's price though.
canon weight ;)
RUSS-D
Jan 01, 2006 15:52 |  #6
I should have mentioned I live on Florida's Gulf Coast. The waves are only shorebreak realy. We don't have any breaks that are too far out. I have shot some surf shots with the 75-300 allready. It does an allright job. I have heard that putting a TC on the 75-300 doesn't work very well, any thoughts on this from y'all? I don't realy want to spend the money on a new lens right now, but I am doing research for the future.
Wrench
Jan 01, 2006 16:10 as a reply to  @ RUSS-D's post |  #7
I wouldn't go with the f/4, especially if you plan on using a tcon. If the f/2.8 is out of your range, look into the Sigma 70-200 f/2.8. Image quality is comparable and they can be had new for around $750 or used from $6-700. Add a 2x tcon and you have 400mm f/5.6
Tony
-60D. Sigma 10-20 EX, Sigma17-50 f/2.8 EX, Sigma 70-200 f/2.8 EX, Canon 100mm macro f/2.8, Canon 50mm f/1.8.
Wrench
Jan 01, 2006 16:12 as a reply to  @ RUSS-D's post |  #8
btw, you can see a head to head comparison of the two lenses on fstopjojo's Pbase website.
Tony
1,594 views & 0 likes for this thread, 6 members have posted to it.
1626 guests, 123 members online
