Hi
i got now for some days a 40d
and i would like to know how much time need to store/save a photo (raw+jpg high quality ) in the cf
i would appreciate , because looks slow and i guess maybe it's the cf that's slow
thanks
mantra Goldmember 1,617 posts Joined Nov 2006 Location: Italy, Rome More info | Nov 18, 2012 06:05 | #1 Hi canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
JamesP Goldmember More info | Nov 18, 2012 07:26 | #2 I never had any trouble with my 40D saving RAW and JPG to a SanDisc CF card in high burst mode. The files were small enough for the buffer to keep up. 1Dx - 5DIII - 40D - Canon 24-70LII, 100L macro, 135L, 16-35L, 70-200 f4 and 100-400L lenses
apersson850 Obviously it's a good thing More info | That depends upon which card you use. It's not possible to specify the write speed without also specifying the card. Anders
Jim_T Goldmember 3,312 posts Likes: 115 Joined Nov 2003 Location: Woodlands, MB, Canada More info | Nov 18, 2012 07:53 | #4 As apersson850 points out.. Precise measurements depend on the speed of the card.
Nov 18, 2012 08:19 | #5 It's been a while since I had a 40D, but I seem to recall that the camera couldn't write any faster than 20 MB/s. So any card faster than this (133x) isn't going to make any difference. Frank Hollis - Retired mass spectroscopist
James P wrote in post #15259453 I never had any trouble with my 40D saving RAW and JPG to a SanDisc CF card in high burst mode. The files were small enough for the buffer to keep up. apersson850 wrote in post #15259481 That depends upon which card you use. It's not possible to specify the write speed without also specifying the card. Jim_T wrote in post #15259508 As apersson850 points out.. Precise measurements depend on the speed of the card. To see how long it takes for your card/camera combination to save the data, just take a picture and watch the little red LED by the CF card cover. That LED is there to let you know that the camera is writing to the CF card. When the light is on, the camera is saving data. When it goes out, the process is over. i use lexmark pro 133x canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
hollis_f wrote in post #15259568 You also need to remember that the first set of shots will be written to the buffer - where ard speed will make no difference at all. do you mean if i take 1 or 2 shots they go in the buffer ? canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
apersson850 Obviously it's a good thing More info | All photos goes to the temporary buffer first. Then the camera flushes the buffer out to the memory card when it has the time to do that. So it's true that the max framerate of the camera is unaffected by the speed of the memory card. What changes is the time it takes the camera to again be ready for shooting, after filling the buffer up. Anders
PUREBRAD Senior Member 417 posts Likes: 1 Joined Nov 2009 Location: Lyndhurst, NJ More info | If it takes 2-3 seconds for a single image, then that is way too slow. 50D / 28-1.8 / 100-2.8L / 200-2.8L / YN565Ex
PUREBRAD Senior Member 417 posts Likes: 1 Joined Nov 2009 Location: Lyndhurst, NJ More info | Just checked. The 40D does have in camera noise-reduction. 50D / 28-1.8 / 100-2.8L / 200-2.8L / YN565Ex
Nov 19, 2012 00:49 | #11 PUREBRAD wrote in post #15261058 If it takes 2-3 seconds for a single image, then that is way too slow. This is just a shot in the dark...I had a 40D, but I cannot remember if the body allowed for "in-camera" noise reduction. If the 40D does allow for such, check to see if it is turned on. When it is turned on, it takes longer for the images to be written to the card because the camera processes out the noise before sending the data off to the card. PUREBRAD wrote in post #15261091 Just checked. The 40D does have in camera noise-reduction. From Canon 40D manual...check page 156. Then check the custom function menu in the camera to see if it is enabled. http://gdlp01.c-wss.com …08236/01/EOS40D_HG_EN.pdf I'm not positive this is it, but I would definitely take a look. noise is disabled canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
| Latest registered member is semonsters 1053 guests, 103 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
