Thread started 18 Nov 2012 (Sunday) 18:55
Need Help with Lens choice! new Camera Body!
Cflaisch
Joined Nov 2012
Nov 18, 2012 18:55 |  #1
So I'm pretty disappointed by the photos from my last show. I play in a touring band so i get a lot of time to mess around with live band photography. my last camera body was horrible in low light so now that i have a decent body i want to get more in depth with it. I recently picked up a Canon 7d. which lens would you recommend for live stuff? I'm almost always either on stage or right in front. Right now i have a canon 50mm 1.8 and a sigma 10-20 in my bag. here are some examples from the other night. Again, it was my first night messing around with it haha.
IMAGE: http://farm9.staticflickr.com/8340/8197322851_1e2f5b5461.jpg
IMAGE LINK: http://www.flickr.com …/90219788@N03/8​197322851/  (external link)
Untitled (external link) by Cameron Flaisch (external link), on Flickr
IMAGE: http://farm9.staticflickr.com/8341/8198496262_0cd1e1fbf7.jpg
IMAGE LINK: http://www.flickr.com …/90219788@N03/8​198496262/  (external link)
IMAGE: http://farm9.staticflickr.com/8066/8197364845_58720f4d47.jpg
IMAGE LINK: http://www.flickr.com …/90219788@N03/8​197364845/  (external link)
IMAGE: http://farm9.staticflickr.com/8064/8198454192_ed2d3d2f7c.jpg
IMAGE LINK: http://www.flickr.com …/90219788@N03/8​198454192/  (external link)
IMAGE: http://farm9.staticflickr.com/8350/8198452810_1820ea1187.jpg
IMAGE LINK: http://www.flickr.com …/90219788@N03/8​198452810/  (external link)
IMAGE: http://farm9.staticflickr.com/8345/8198419968_ff15930a2f.jpg
IMAGE LINK: http://www.flickr.com …/90219788@N03/8​198419968/  (external link)
IMAGE: http://farm9.staticflickr.com/8069/8198418276_20924ec81b.jpg
IMAGE LINK: http://www.flickr.com …/90219788@N03/8​198418276/  (external link)
IMAGE: http://farm9.staticflickr.com/8344/8198422828_a569d8bf24.jpg
IMAGE LINK: http://www.flickr.com …/90219788@N03/8​198422828/  (external link)
www.cameronflaischphot​ography.com (external link)
Instagram: cameron_flaisch_photo
boogada
Nov 18, 2012 19:02 |  #2
What exactly are you feeling disappointed about? What should a new lens do better? Focal lengths? Aperture? Image quality? Focus accuracy? Focus speed?
My website (external link)
I also publish a Photo Zine (external link)
Cflaisch
Joined Nov 2012
Nov 18, 2012 19:13 |  #3
Image quality mainly. Id like a small zoom if possible. sometimes i don't have time to swap lenses.
RichSoansPhotos
Nov 18, 2012 19:27 |  #4
Cflaisch wrote in post #15261509 (external link)
I can't see where you are going wrong with the lenses you already got
Cflaisch
Joined Nov 2012
Nov 18, 2012 19:40 |  #5
maybe I'm just my worst critic
boogada
Nov 18, 2012 20:52 |  #6
Well, between the 10-20 and the 50, you should look into one of the 17-50/2.8 lenses that are around. The best one is probably the Canon one. Also the most expensive. I've been happy with the Tamron I've been using for years. (Its the older version of the 17-50/2.8 without the image stabilization). If you consider upgrading to a full frame an option, you could also look into the 24/28-70 ones. In any case you should select a fast one with 2.8 and not bother with anything slower. If you just want to fill the gap between the 20 and 50, a prime around 30mm could also be an option. The Sigma 30/1.4 is a popular choice.
BushWacker
Joined Dec 2011
Nov 19, 2012 01:54 as a reply to  @ boogada's post |  #7
I find the 24-70m f2.8 the one I use the most if you can get close and the 70-200m f2.8 if you are back a way. Add the 1.4x extender and your good for a pretty large range of focal distance but you lose a lot of light when you add the extender.
"When I shoot something I use a Canon!"
-------------- Gear List | flickr (external link) --------------
RichSoansPhotos
Nov 19, 2012 03:13 |  #8
Cflaisch wrote in post #15261608 (external link)
Personally I find that if you did have the lenses in my sig, you're more or less covered, but that is pushing up the amount of money spent on a hobby too high, but that isn't covering all focal lengths. Because its depends on how the stage is set up at venues. Some can be too close to the pit. Since you have a crop body, it complicates things because you have add in the crop factor
René ­ Damkot
Nov 19, 2012 04:28 |  #9
boogada wrote in post #15261868 (external link)
^^^ This.
But I also don't see much wrong with the shots that would change by using a different lens…
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
chris.dg
Joined May 2012
Nov 19, 2012 10:56 |  #10
I agree... for the 7D, I highly recommend the Canon 17-55 2.8 (or 3rd party equivalent if budget is an issue), since it is usually wide enough even on a crop body when up close and gives you some range versatility ...couple that with your ultra-wide 10-20 and you are all set for your up-close/in-your-face style.
There are also some good deals to be had on a used 17-55...
lastly, if concert photography is in your future, it's a good idea to avoid buying any glass slower than f2.8 from this point forward - you'll likely only be disappointed.
-Chris
5DmIII: 50 f1.2L, 16-35 f2.8L, 17-40 f4L, 24-70 MarkII f2.8L, 70-200 f2.8L
http://www.facebook.co​m/cdgimagery (external link)
http://www.cdgimagery.​com/ (external link)
http://bammagazine.com (external link)
bubbygator
I can't tell the difference
Location: Sarasota, sunlight, butterflies, fish, Gators, and Seminoles
Nov 19, 2012 11:24 as a reply to  @ chris.dg's post |  #11
You might look at the Canon 16-35/2.8 <link (external link)> .
Or a 24 or 28mm prime. I use the Canon 28/1.8 for low-light close shots - it has excellent image quality, fast AF, and is affordable. I can usually crop to 4x with little loss of quality.
The avatar is my middle grandson. (the TF can't tell the difference, but the fish is frowning and the kid is grinning)
Cflaisch
Joined Nov 2012
Nov 19, 2012 13:10 |  #12
Thanks for all of the advice folks! ill def check into them!
RichSoansPhotos
Nov 20, 2012 06:51 |  #13
bubbygator wrote in post #15263964 (external link)
The 16-35mm is not a cheap alternative, I would go for a third party alternative, cheap, but good enough to get a portfolio going
narlus
Nov 20, 2012 08:41 |  #14
the 16-35 is an expensive lens, but i am not aware of any 3rd party ultrawide lenses that are f/2.8.
www.tinnitus-photography.com (external link)
Facebook link (external link)
gear list
RichSoansPhotos
Nov 20, 2012 12:32 |  #15
Relatively cheap third party Sigma f/2.8 lens wide angle 17-50 (external link)
6,714 views & 0 likes for this thread, 8 members have posted to it.
1338 guests, 175 members online
