Thread started 19 Nov 2012 (Monday) 10:30
Refresh rate to match burst rate
Ito
Joined Apr 2012
Nov 19, 2012 10:30 |  #1
I have a question that I was wonder if you guys could help me answer.
I am looking to get a strobe that can keep up with the burst rate of the 7D. Obviously this isn't going to be possible unless I buy a a super expensive strobe, but I am not looking to be able to do this at a super high power.
Why? I am trying to do some sequence shots while using a strobe. This will mostly be used for extreme sports (skiing/snowboarding/s​kating) and in lower light situations. My ambient lighting will most likely be similar to what I took in this shot (if not even less).
HTTP response: 403 | MIME changed to 'text/plain'
I most likly won't be able to plug in to a wall,s o I will probably need to get a power pack as well.
Is this idea even feasible on a budget or is it just a pipe dream for me?
Gear: Canon 6D | Canon 7D | Sigma 18-50mm f/2.8 | Sigma 35mm f/1.4 | Sigma 50-150mm f/2.8 OS | Canon 70-300mm f/4-5.6 OS | Neewer TT850 Flash x4
René ­ Damkot
Nov 19, 2012 11:03 |  #2
Leaving the EXIF in the image, or mentioning the settings for ISO, aperture and shutterspeed would have given quite useful info…
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
munzzzzzzz
Nov 19, 2012 11:43 |  #3
I'm thinking an Einstein plus a Vagabond Mini Lithium would be the perfect setup. Cost for just the strobe and VML would be about $740.
According to this recent PCB literature, you can shoot 8FPS at 40 WS:
http://www.paulcbuff.c​om …ads/e640_specsm​anship.jpg (external link)
Combine it with their $30 Long Throw Reflector and at 14' you could shoot ISO 200, f/10.
6D | 40mm f/2.8 | 50mm f/1.4 | 70-200mm f/4L IS | 580EXII | 2x PCB Einstein | Various Modifiers
PhotographersWorldWide
Nov 19, 2012 11:48 |  #4
You could use multiple flash units and use a trigger system like the Quantum FreeXwire in sequence mode to trigger them.. in sequence. Setting (say) 100Ws on a 400Ws pack will give you 3 shots per pack without recharge. 4 packs.. easily 12fps, you might get to 16.
Ito
Joined Apr 2012
Nov 19, 2012 12:16 |  #5
René Damkot wrote in post #15263868 (external link)
Shutter Speed: 1/250 sec
Aperture: f/4.5
ISO: 800
Aressem
Gallery: 39 photos
Nov 19, 2012 13:22 |  #6
Funny you ask... I was trying to do the same 2 years ago and still am. All I can say.... is good luck ;). You would have to turn the power of the strobe down so much in order to get it to recycle fast enough that there's no way you'd still be able to effectively light your subject, long-throw reflector or not.
Ryan Mackay WEBSITE (external link) | FACEBOOK (external link) | GEAR LIST | Buy & Sell Feedback: 1, 2, 3, 4, 5
Aressem
Gallery: 39 photos
Nov 19, 2012 13:23 |  #7
PS: What type of light did you use in the shot above? Do you remember the power settings?
canonphotog
Joined Nov 2005
Nov 19, 2012 13:49 |  #8
PhotographersWorldWide wrote in post #15264040 (external link)
Quantum FreeXwire in Sequence Mode? You have a link to the directions on how to do that? :wink:
-Ken
Gear List|Kenny D. Photography (external link)
Ito
Joined Apr 2012
Nov 19, 2012 13:51 as a reply to  @ Aressem's post |  #9
That was a 580EX II, no idea the power, I was probably shooting in ETTL...my knowledge of off camera flash has grown a lot since I took this shot :D
canonphotog
Joined Nov 2005
Nov 19, 2012 14:02 |  #10
Never mind. Found it here. (external link)
"Studio or location versatility. In the studio or on location, use FreeXwire to trigger power packs, monolights or your camera manufacturer's flash, and avoid all those messy sync cables. Additionally, a Flash Sequencer function in the FW10W transceiver can sequentially trigger up to four remote power packs for action sports or fast fashion shoots, as fast as 13 frames per second."
I use my Quantums with FW7Q's and FW9T's. Was totally unaware that the FW10W had that capability. I'll have to look further into this.
-Ken
cking2
Nov 19, 2012 14:07 |  #11
Ito wrote in post #15263732 (external link)
Why use strobes?
I think you might want to explore a continuous light system that can be powered by DC. Most of the new color balanced LED light (external link)banks would work, but you would need to find a 12 volt power source for it...
and then again there is that budget thing you mentioned:)
good luck...
Rick King
Gear List Here
Ito
Joined Apr 2012
Nov 19, 2012 14:25 as a reply to  @ cking2's post |  #12
Continous lights wouldn't work. I am relying on the flash duration to stop the motion.
redrocket
Gallery: 15 photos
Nov 19, 2012 15:06 |  #13
broncolor $$$$$ bu the results are nice
http://blog.chasejarvi​s.com …-strobed-photo-sequences/ (external link)
I have G.A.S.
Aressem
Gallery: 39 photos
Nov 19, 2012 15:23 |  #14
redrocket wrote in post #15264836 (external link)
I guess you neglected to read the operative word: BUDGET :P
munzzzzzzz
Nov 19, 2012 15:39 |  #15
Aressem wrote in post #15264375 (external link)
I'll admit I've never tried it, and my assumption is based largely on published specifications, but I'm curious as to why you don't think you could make it work.
PCB's specs indicate 8 FPS @ 40 WS achieving f/11 at ISO 200, 14'. The shot the OP posted was at f/4.5, ISO 800. I agree that 40 WS isn't much power, but if the OP is using the settings he mentioned, why would it not work? It would seem he's happy with the shot he posted, which if he was using a speedlite couldn't have been more than 50-60 WS max, he just obviously wasn't getting anywhere near the frame rate his 7D was capable of. The Einstein is obviously a lot more powerful than a speedlite and still provides the short flash durations necessary for this type of shot, along with a high enough frame rate.
OP, where in WI are you located?
10,648 views & 0 likes for this thread
Latest registered member is Nippon245
1189 guests, 262 members online
