Can anyone assist with some ideas for diffusing my ringflash? I like the convenience of the ringflash for handheld macro work, but am not a fan of the reflections and highlights.
Photos of your diffusion masterpieces welcome.
dodgyexposure Goldmember More info | Nov 19, 2012 18:38 | #1 Can anyone assist with some ideas for diffusing my ringflash? I like the convenience of the ringflash for handheld macro work, but am not a fan of the reflections and highlights. Cheers, Damien
Nov 20, 2012 07:14 | #2 as a ring flash user i also wonder if there is a solution about it
orionmystery Cream of the Crop 12,078 posts Likes: 771 Joined Apr 2008 Location: Malaysia More info | Nov 20, 2012 08:27 | #3 A friend of mine does it this way....very effective and no more weird circular catchlights...and much better light overall. More info here: http://orionmystery.blogspot.com …11/hishams-macro-rig.html Kurt
Nov 20, 2012 09:07 | #4 is that a sheet of paper in front of the flash? i was thinking of getting one of these ring flashes.
Gatorboy Goldmember 2,483 posts Likes: 2 Joined May 2005 Location: Bel Air, MD More info | Nov 20, 2012 09:33 | #6 Sort of defeats the purpose of having a ring flash if you are using it above the lens. Dave Hoffmann
Nov 20, 2012 11:39 | #7 Gatorboy wrote in post #15267874 Sort of defeats the purpose of having a ring flash if you are using it above the lens. I was wondering about that, most of them I've seen are on the lens, except for a Nikon setup that has two of them, one on each side
alquimista Cream of the Crop More info | Nov 20, 2012 12:09 | #8 Gatorboy wrote in post #15267874 Sort of defeats the purpose of having a ring flash if you are using it above the lens. If you already have a ring flash and want to get better light quality for macro, mounting it and diffusing is the way to go la costura de Dios
racketman Cream of the Crop More info | Nov 20, 2012 15:36 | #9 I just sellotaped strips of white cloth cut to the shape of the bulbs, works fine. If shooting ants or Jumping spider eyes then you still get the circular highlights but not a problem for most subjects. Toby
mandokid1 Cream of the Crop 13,679 posts Gallery: 718 photos Best ofs: 4 Likes: 1109 Joined Nov 2010 Location: scarborough ontario canada More info | Nov 20, 2012 19:10 | #10 i put vellum paper and packing foam on mine,that ish is using now,and it certainly helps. DENIS
Nov 20, 2012 19:48 | #11 mandokid1 wrote in post #15269965 i put vellum paper and packing foam on mine,that ish is using now,and it certainly helps. Can you show us your set up? Cheers, Damien
Dec 04, 2012 11:41 | #12 mandokid1 wrote in post #15269965 i put vellum paper and packing foam on mine,that ish is using now,and it certainly helps. Yes can you show your setup please? orionmystery wrote in post #15267622 A friend of mine does it this way....very effective and no more weird circular catchlights...and much better light overall. ![]() More info here: http://orionmystery.blogspot.com …11/hishams-macro-rig.html Canon MR14 ex has slightly different shape, so i can`t attach ruler
mandokid1 Cream of the Crop 13,679 posts Gallery: 718 photos Best ofs: 4 Likes: 1109 Joined Nov 2010 Location: scarborough ontario canada More info | Dec 05, 2012 20:20 | #13 havent got any pics of the set-up,but will post my 3 different set-ups i use after the holidays when i have more time.i,m a courier and going nuts at work right now! DENIS
Dec 05, 2012 22:35 | #14 mandokid1 wrote in post #15331534 havent got any pics of the set-up,but will post my 3 different set-ups i use after the holidays when i have more time.i,m a courier and going nuts at work right now! Thanks, Denis. Much appreciated. Cheers, Damien
| Latest registered member is Niagara Wedding Photographer 1315 guests, 128 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
