I usually find something like this using search, but having a hard time now.
Can someone tell me how they mount their Speedlites parallel to the umbrella rod and as close as possible to it (i.e. center of umbrella) ? DIY is fine too.
Nov 19, 2012 20:18 | #1 I usually find something like this using search, but having a hard time now.
Tiberius Goldmember 2,556 posts Likes: 11 Joined Apr 2008 More info | Nov 19, 2012 20:56 | #2 There are little holders that look like an elbow joint. My photography website!PHOCAL PHOTOGRAPHY
Nov 19, 2012 21:48 | #3 Tiberius47 wrote in post #15266155 There are little holders that look like an elbow joint. The bottom part attaches to a light stand. The top part has a hole for the brolly, and the top has a cold shoe to sit the flash in. The hole for the brolly should be at a bit of an angle so the brolly is tilted upwards, raising the venter of it so that when the flash fires straight ahead, the center of the light hits the center of the brolly. David Hobby talks about this over at Strobist. LINK Thanks for the info. I'm sorry, but I think I was unclear in describing it. What I want is a method to have the flash and umbrella rod essentially touching: Image hosted by forum (624508) © frugivore [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff.
catalyst412 Senior Member More info | This should work 7Dii | G7Xii | 24-105 L | Sigma 17-50 2.8 | 55-250stm | 60mm macro | 50 1.8 | 15-85 | 70-200 L is f4 | 85 f1.8
windpig Chopped liver More info | Nov 19, 2012 22:04 | #5 I use a mini ball head made specifically for speedlights. It allows you to rotate the flash down parallel with the umbrella shaft. Would you like to buy a vowel?
catalyst412 Senior Member More info | Nov 19, 2012 22:11 | #6 Is this what you are using (or similar) windpig wrote in post #15266391 I use a mini ball head made specifically for speedlights. It allows you to rotate the flash down parallel with the umbrella shaft. 7Dii | G7Xii | 24-105 L | Sigma 17-50 2.8 | 55-250stm | 60mm macro | 50 1.8 | 15-85 | 70-200 L is f4 | 85 f1.8
windpig Chopped liver More info | Nov 19, 2012 22:14 | #7 Exactamundo. It works most excellent, just need a cold shoe. Would you like to buy a vowel?
catalyst412 Senior Member More info | Nov 19, 2012 22:15 | #8 windpig wrote in post #15266423 Exactamundo. It works most excellent, just need a cold shoe.
catalyst412 wrote in post #15266341 This should work http://www.lightenupandshoot.com …07-the-gordon-flash-strap
Nov 19, 2012 22:35 | #10 windpig wrote in post #15266423 Exactamundo. It works most excellent, just need a cold shoe. Just so I have it straight, I need an umbrella bracket, the mini ball and a cold shoe right?
catalyst412 Senior Member More info | Nov 19, 2012 22:42 | #11 There should be a video, on that site, showing the use of it. frugivore wrote in post #15266487 This looks promising. I can't find a picture of the product mounted on an umbrella bracket on that site however. Do you have this? If so, can you show what it looks like? 7Dii | G7Xii | 24-105 L | Sigma 17-50 2.8 | 55-250stm | 60mm macro | 50 1.8 | 15-85 | 70-200 L is f4 | 85 f1.8
windpig Chopped liver More info | Nov 19, 2012 22:44 | #12 frugivore wrote in post #15266496 Just so I have it straight, I need an umbrella bracket, the mini ball and a cold shoe right? yes. Would you like to buy a vowel?
dmward Cream of the Crop More info | Nov 19, 2012 22:47 | #13 I have several of these; David | Sharing my Insights, Knowledge & Experience
Whortleberry Goldmember 1,719 posts Likes: 53 Joined Dec 2011 Location: Yorkshire, England More info | Nov 20, 2012 06:34 | #14 I made a couple of these which solve the problem perfectly. Sourced the angle adapter in the UK for under £5 each (US$7.50) then just removed the coldshoe and attached the 3/16" thick aluminium bar using domed stainless 4mm bolts into the existing holes. Slotted upright allows adjustment for with/without radio trigger and the L-bracket allows external power pack attachment if required. The umbrella shaft goes in the hole directly beneath the aluminium bar. Easy and cheap! Image hosted by forum (624569) © Whortleberry [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Image hosted by forum (624570) © Whortleberry [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. Phil ǁ Kershaw Soho Reflex: 4¼" Ross Xpres, 6½" Aldis, Super XX/ABC Pyro in 24 DDS, HP3/Meritol Metol in RFH, Johnson 'Scales' brand flash powder. Kodak Duo Six-20/Verichrome Pan. Other odd bits over the decades, simply to get the job done - not merely to polish and brag about cos I'm too mean to buy the polish!
windpig Chopped liver More info | Nov 20, 2012 06:56 | #15 I'll bet you got top honors in shop class when you were in school Would you like to buy a vowel?
| Latest registered member is Niagara Wedding Photographer 1306 guests, 121 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
