Thread started 20 Nov 2012 (Tuesday) 05:29
NIK or NDG?
russellsnr2
Nov 20, 2012 05:29 |  #1
Hi, Really a question for anyone who uses or has used the option of doing it in camera by the use of NDG filters and has used NIK software products.
What in your opinion is the better option?
Does NIK give all you would expect from say a LEE NDG in front of the lens or do you think software degrades your image?
Thank you for any and all input.
Russ
Many Thanks,
Russell.
rick_reno
Nov 20, 2012 09:40 |  #2
I don't think the NIK filters can do what a NDG filter can do.
NatDeroxL7
Nov 20, 2012 11:57 |  #3
Graduated ND filters are un-replicable in post processing in a single exposure. It compresses the dynamic range of the scene before it hits the sensor. Once you are on the computer, those parts of the dynamic range your camera didn't capture by not using a grad ND filter aren't going to exist.
If you want to use software to get the "grad ND effect" you need to be taking multiple exposures and combining via layers or HDR. This carries its own set of limitations.
Ultimately any scene which exceeds the range of the sensor will require an ND grad, or multiple exposures.
https://www.instagram.​com/nd14411 (external link)
https://natedphoto.myp​ortfolio.com/ (external link)
tonylong
...winded
Gallery: 60 photos
Nov 24, 2012 20:40 |  #4
Well, I'll offer an "alternative" viewpoint:
We have a degree of latitude with Raw "data" and post-processing that goes significantly beyond what jpegs can do, and with film without some real darkroom skills and such.
I also have a problem with GNDs in that they darken the image over a straight line -- so if parts of your scene are above this line they get darkened whether you want it or not...so in post-processing you are still "stuck" with having to boost those areas that are too dark.
In practice, well I have a couple Lee "kits" with GND filters and such, but honestly never use them. Around here there are many trees and hills that jutt up into a scene. That being said, we do have oceans in the area and I wouldn't be adverse to occasionally making a trip to the coast and playing with them, it's just not a habit I've gotten into!
As I've said, shooting Raw can make a big difference, since there is good data in the highlight areas that can be recovered, bright blue skies can be "tamed", and so on. I'm not saying that I'm an expert in such things, it's just my preferred approach.
Also, there is a Graduated Gradient tool in Camera Raw/lightroom that is pretty interesting to play with, something that would be interesting if someone who was skilled with a GND filter could work over an unfiltered shot with the Graduated Gradient in ACR/Lightroom!
As an added thought, a pretty established "Photo Safari" leader/photographer, Joseph Van Os, posted in his "gudelines" for people coming to one of his Safaris/workshops about GND filters:
He said that for a long time he just insisted that photogs bring/use GND lenses, but he changed this, telling film shooters to bring the filters, but leaving out that requirement for digital shooters. I thought that was interesting and a bit surprising, coming from a long-time nature shooter!
Tony
NatDeroxL7
Nov 24, 2012 22:28 |  #5
Those are definitely some good points, for example, guess which one of these was a GND filter and which one was a single, no filter exposure that was a merge of two different raw processings?
Probably not immediately easy to tell, but you can. The top one was a single non-filter exposure, hand-held. I made two raw conversions and merged into a single file using photoshop+NIK.
The bottom one was done with a GND.
This shows the straight line issue well actually. The top one, you can't identify a 'line' per say, it looks more natural. Undoubtedly a GND filter would have caused some issues with the darkening of the mountains and the top of the boat over the horizon. Look at the bottom one and you can clearly see that the mountain is very dark thanks to the straight line GND having to block it in order to get the whole horizon.
Ultimately I do use both techniques often. RAW gives you many options. If you have the budget, I'd get both filters and NIK. However if I could only get one, I would get the NIK suite. There are many ways to get good results in the RAW age. Regardless, looking forward to seeing some results from your choice!
watt100
Nov 25, 2012 04:42 |  #6
tonylong wrote in post #15285039 (external link)
I have used the OnOne Photo Tools filters for Photoshop. It includes graduated software filters that work with Photoshop, for example - Graduated Cool-Warm, Warm-Cool, graduated blue, etc. With RAW files and PS layers it can make a difference
reginalds
Joined Nov 2012
Nov 25, 2012 16:42 |  #7
NDG filters has better filters and will have a better result.
1,051 views & 0 likes for this thread, 6 members have posted to it.
NIK or NDG?
2178 guests, 136 members online
