Thread started 20 Nov 2012 (Tuesday) 12:36
Is this flash setup a good start for real estate?
aparis99
Nov 20, 2012 12:36 |  #1
I've been experimenting in the Real Estate photo thing for a few months, and I've taken some for a local realtor to experiment. Well, I'm really trying, but around here they all use HORRIBLE point-n-shoot, and cell phone pics so she's still happy with them. Some can be seen here: http://apimagery.zenfo​lio.com/re (external link)
Anyway, I'm tired of HDR and the bad color casting with it so I'm ready to get a few flashes and get better quality shots. I currently have: 580exII, Cactus V5 radio trigger (just 1 set). What else do I really need to start? (and I'm getting married in a few months so $ is def a factor here!)
1. A couple cheap stands?
2. I'm thinking of getting (2 or 3?) Yongnuo 560II's since they seem to have decent optical triggers. I suppose I could use the radio trigger if a flash is hidden but I plan on relying on the optical sensor.
3. Should I just bounce off walls or get some sort of reflector/small umbrella, or flash diffuser?
I'll take any advice if you disagree. Thanks in advance.
My Site - www.apimagery.com (external link)
Canon R5 (x2), Canon RF 15-35 f/2.8L IS, Canon RF 24-70 f/2.8L, Canon RF 70-200 f/2.8L, Canon RF 100-500L, Sigma Art 35 f/1.4, Canon 85 f/1.8, Canon 100 f/2.8L Macro
ZXDrew
Nov 20, 2012 12:51 |  #2
I'd pick up a few gels if you plan on blending in the ambient light.
PhotoWolfe.com (external link)
Facebook.com/PhotoWolfe (external link)
Gear / My flickr (external link)
aparis99
Nov 20, 2012 12:58 |  #3
daylight and/or tungsten and flourescent gels?
Aressem
Gallery: 39 photos
Nov 20, 2012 13:00 |  #4
They look great from what I can see.
Ryan Mackay WEBSITE (external link) | FACEBOOK (external link) | GEAR LIST | Buy & Sell Feedback: 1, 2, 3, 4, 5
ZXDrew
Nov 20, 2012 14:47 |  #5
Yes, tungsten and flourescent gels if you're planning on using the room's lighting balanced with flash.
alintx
Nov 20, 2012 14:48 |  #6
Elope. Spend the $$$ on gear. :-)
But seriously, the photos look great. Are you shooing in RAW and using Lightroom to process them?
I think bouncing off the wall might give you more color casts.
I would make sure the stands are very sturdy, but also as light as possible. It gets to be an ordeal to haul bags of stands and umbrellas and associated junk around.
Al
5DIII, 5DII, T2i, TS-E 24mm f3.5L II, 17-40 f/4L, 24-70mm f2.8L, 50 f/1.4, 85 f/1.8, 70-200 f/2.8 L II, 135mm f/2L, 180mm f/3.5L, Canon 40mm f/2.8, Sigma 50-500 OS, 3 x 600EX-RT, ST-E3-RT, RRS tripod + BH-55, bags out the wazoo, other crap +++
Aerial Photography (external link)
dmward
Gallery: 29 photos
Nov 20, 2012 15:02 |  #7
aparis99 wrote in post #15268498 (external link)
One objective when doing real estate photography is to capture the mode of the room.
Once you start adding light you are starting down a slippery slope. Especially considering that you want to make money at this venture. (I hope anyway that's true.) That means being able to do the job well in a limited amount of time with minimal post processing.
Do you use Lightroom V4? If you do, then take advantage of the ability to import 32 bit floating point images and process them with the same sliders in the develop module. The difference is that with the 32 bit image yo have 20 stops of exposure range.
You create the 32 bit floating point file by round tripping into Photoshop with 3 bracketed images. According to Eric Chan, the Adobe engineer who was instrumental in developing the capability, the 3 brackets can be 2 or more stops apart. As opposed to the suggestion for most HDR software to have bracketed exposure about a stop apart. His observation was that the algorithm needs blacks with detail, whites with detail and a mid-tone reference.
Use the Photoshop merge to HDR Pro option in Lightroom Edit-in sub-menu. When Photoshop has created the image save the 32 bit floating point file back to Lightroom as a TIFF.
Since there is a feature in the merge function for aligning and eliminating ghosts the bracket can be made hand held if you're careful.
That should make creating acceptable images that capture the mood of the room easier without having to resort to adding light.
Maybe not what you wanted to hear but I think its a better approach.
If you still want to add light, I'd start with a monolight, with a china bowl on it right over the camera and get it about 1 stop brighter than ambient.
aparis99
Nov 20, 2012 16:49 as a reply to  @ alintx's post |  #8
First off, thank you all for the non-harsh words...
To answer some questions.. Yes, I'm using LR. My process right now is taking -2, 0, and 2 EV shots, using software to make an HDR, then bringing into LR to adjust perspectives, WB, clarity/shadow/contrac​t etc.
I've seen the "Photography For Real Estate" group on flickr quite a bit and they all use multiple flashes. I've also got Scott Hargis' book on Interior Lighting so that's why I'm going the speedlight route. I'm just having a hard time with some of the photos coming out like they are supposed to.
I just ordered 2 flash units, so I guess on my next shoot I will do an HDR and a Flashed picture and decide which I, and the client, likes better. I will also post here to get feedback.
dmward
Gallery: 29 photos
Nov 20, 2012 17:59 |  #9
If you have some brackets, try the 32 bit floating point images in Lightroom you may be pleasantly surprised.
Nothing wrong with adding light just creates another complication. :-)
aparis99
Nov 21, 2012 08:11 |  #10
dmward wrote in post #15269699 (external link)
I'll try that. When the flashes come in, I will try both techniques and compare them.
dmward
Gallery: 29 photos
Nov 21, 2012 16:22 |  #11
aparis99 wrote in post #15271823 (external link)
I have Scott's book and just went through some of it as a refresher.
His approach to adding light is consistent with what I do. i.e. just add enough to get the pop and even things out without destroying the ambiance.
He often starts a section by saying start with ambient exposure then add just enough light to get the darker areas up where they need to be without over powering the ambiance.
The one thing that is probably different with Lightroom compared to when he wrote his book is the power built into Lightroom V4 with Process Version 2012. Especially now with ability to get a quick 32 bit floating point file conversion via Photoshop.
I think I'll ask him via his blog. :-)
aparis99
Nov 23, 2012 15:53 |  #12
dmward wrote in post #15273526 (external link)
You mean with the Shadows slider? I was a fan of the Fill-In slider more I think...
dmward
Gallery: 29 photos
Nov 23, 2012 16:24 |  #13
The process 2012 develop module is much better with the exposure, contrast, highlight, shadow, white, black, clarity sliders. The highlight and shadow sliders offer much finer control than fill-in slider.
alintx
Nov 26, 2012 00:04 |  #14
Do you like Scott's book? Have you seen his video series?
Al
dmward
Gallery: 29 photos
Nov 26, 2012 15:19 |  #15
alintx wrote in post #15289682 (external link)
Yes, Scott's book is quite useful. Lots of great suggestions, and he gives a lighting diagram for essentially every shoot as well as discussing how and why he placed the light(s)
5,090 views & 0 likes for this thread, 7 members have posted to it.
1458 guests, 137 members online
