Thread started 21 Nov 2012 (Wednesday) 04:51
5DC or Lens?
richielee14
Joined Jul 2011
Nov 21, 2012 04:51 |  #1
I'm in a bit of a dilemma here.. I can either purchase a used 5DC for £500, or spend that amount on a lens.
Currently, I shoot all sorts, mainly street/urban and also delving into portraits/products/foo​d. I've got an urge to get into FF, but the only have a few lenses that I can use on a FF. Shall I spend money to get a better lens range and then swap to FF later?
I currently own the below gear and feedback would be greatly appreciated.
6D Gripped - 14mm T3.1 - 35 f2.0 - 50 f1.8 - 24-105 f4 IS L - 70-200 f4 L
Website - www.richardlee.co.uk (external link)
TSchrief
Joined Aug 2012
Nov 21, 2012 05:19 |  #2
I just bought a 5Dc a week ago. The only shorter lenses I have for full-frame are 28 2.8, 50 1.8 & 85 1.8. I also have longer zooms: 70-200 and 100-400L. Don't plan on getting any new glass soon. My 'main' camera is a 60D. Each lens is a completely different animal on FF. Get the 5Dc.
Edit: Oops! I forgot that I also have Tokina 19-35 that I use on my 5Dc. You will need something at the wider end. Well, I would. Thanks, melcat.
melcat
Joined Nov 2010
Nov 21, 2012 07:05 |  #3
You'd be missing all focal lengths below 50mm, which is a slight telephoto on full frame. Even if there is some way to use the 11-16 on full frame, you'd still be missing the bread and butter focal lengths from 24mm to 45mm.
Of course everyone is different, but I'd be crippled as a photographer.
I suggest you pick one of your chosen special areas, and then decide whether that would benefit from a lens... and then look to see whether that lens might have a use (typically some *other* use) for you on full frame. For example, 28mm on crop is a "normal" lens that has been a long-time favourite of street photographers, but it is also useful as a beginner landscape lens on full frame.
TBH, for £500 you might have more fun with a good set of used studio lights. The Bowens starter kit isn't much more than that new here.
richielee14
Joined Jul 2011
Nov 21, 2012 12:59 |  #4
I bit the bullet and purchased the 5D.
Melcat, you are right about the wide angle. I already have one strobe and a softbox/beauty dish, which is definitely something I will be using more often.
I did shoot a bit with the 11-16, but like many others have said in previous posts, its a bit soft on the edges.
I'll have a play with the camera over the Christmas period and get used to the camera.
794 views & 0 likes for this thread, 3 members have posted to it.
5DC or Lens?
518 guests, 154 members online
