I'm seeing these two different models on their site, but I can only find the Ranger Quadra anywhere else. What is the difference between the two?
dip Member 128 posts Joined Feb 2010 More info | Nov 22, 2012 05:49 | #1 I'm seeing these two different models on their site, but I can only find the Ranger Quadra anywhere else. What is the difference between the two? Canon 6D | 24mm f/2.8 IS | 35mm f/2 IS
djlb Member 171 posts Joined Mar 2007 Location: Hull, UK More info | Nov 22, 2012 15:33 | #2 As far as I can tell, the difference is, wait for it, the transfers
PhotographersWorldWide Senior Member 395 posts Joined Mar 2008 Location: UK More info | Nov 22, 2012 15:46 | #3 Hybrid uses Lithium or Lead Acid batteries. It must have a charging device or circuit to accommodate this. And the transfers are different.
djlb Member 171 posts Joined Mar 2007 Location: Hull, UK More info | Nov 22, 2012 16:08 | #4 PhotographersWorldWide wrote in post #15277069 Hybrid uses Lithium or Lead Acid batteries. It must have a charging device or circuit to accommodate this. And the transfers are different. both my non-hybrid quadra work perfectly well with lithium or lead acid batteries
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Nov 22, 2012 16:17 | #5 The descriptions/specs on the site are identical, word for word (with the exception of the model name). "I think the idea of art kills creativity" - Douglas Adams
Csae Goldmember 3,350 posts Likes: 1 Joined Nov 2008 Location: Montreal, Canada More info | Nov 22, 2012 16:24 | #6 There are some of the older models who will not work properly with lithium, there was a post about which serial numbers would and which wouldn't work. Feel free to call me Case.
Nov 22, 2012 17:19 | #7 Alright thanks guys! That clears up my confusion. Canon 6D | 24mm f/2.8 IS | 35mm f/2 IS
kokakaste2 Goldmember 3,546 posts Joined Jan 2008 Location: Luxembourg More info | Nov 23, 2012 04:14 | #8 Csae wrote in post #15277190 There are some of the older models who will not work properly with lithium, there was a post about which serial numbers would and which wouldn't work. To prevent confusion, they added the naming convention to make it easier to tell that newer models would fact work. Older models would have to be checked via their serial, and i believe there may be a service change possible to them for a fee? I'm not sure of the last part though, so don't quote me. It might of even been the heads... Like i said theres a fair amount of confusion involved. +1 Oskar (Oscar) - stuff I use- Flickr
DutchCorps Senior Member More info | Hi guy's, I've bought a Quadra kit recently and had the same question for the importer here in the Netherlands. He told me the only difference is the battery level indicator on top of the generator. In the hybrid version it is accurate for both lit-ion as for lead batteries. The non-hybrid was calibrated for lead batteries only. An accurate battery level of the lit-ion batteries can be obtained from the level indictor on the lit-ion battery itself. I bought the non hybrid version as this kit was on sale
| Latest registered member is ealarcon 1041 guests, 170 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
