Thread started 22 Nov 2012 (Thursday) 14:24
What would you use to join a Canon 400mm f2.8 IS to a monopod?
nigpd
Nov 22, 2012 14:24 |  #1
I am looking to sit a I am looking to sit a Canon 400mm f2.8 IS II on a monopod for sports photography, mainly wakeboarding, american football and football.
What would you suggest to join the monopod to the lens, if anything? Would you suggest a plate of some sort or a monopod head? If so what sort/make
Thanks in advance for your recommendations
My flickr (external link)
Fricks
Cream of the Crop is, in fact, a title
Nov 22, 2012 14:25 |  #2
If you want a ball head look at markins q20
FlyingPhotog
Cream of the "Prop"
Nov 22, 2012 14:26 |  #3
Nothing...
Screw the pod into the lens foot and go shoot.
A head is just one more thing that can fail at the worst possible moment.
Jay
Wallace ­ River
Gallery: 167 photos
Nov 22, 2012 14:27 |  #4
This is what I use (external link) from Really Right Stuff. A bit pricey, but it's smooth, sturdy, and stable, and I don't have the feeling it'll fail anytime soon. I use it with an EF500 f/4 and 1D Mk IV.
My Flickr (external link).
TC1986
Nov 22, 2012 14:29 |  #5
Have a look at the Manfrotto 393 head.
Shooting wildlife with a 35mm Canon!
Billginthekeys
Billy the kid
Joined Nov 2005
Nov 22, 2012 14:34 |  #6
FlyingPhotog wrote in post #15276823 (external link)
Nothing...
This is what I did when I shot sports with my 300 2.8. Screw it in and go.
Mr. the Kid.
Go Canes!
My Gallery (external link)My Gear
what the L. just go for it.
convergent
Gallery: 34 photos
Nov 22, 2012 15:04 |  #7
You should either screw it directly onto the monopod, or use an arca swiss plate and release made for that lens. It is very, very heavy and needs a solid mount. I would never use any kind of ball head on a monopod with a lens that heavy... asking for a disaster to happen. I used the arcs swiss approach and it was solid as a rock. Had no problem throwing it over my shoulder by the monopod.
Mike
R6 II - RF 100-500L f/4.5-7.1 IS - EF 17-40L f/4 - 24-70L f/2.8 II - 70-200L f/2.8 IS II -
135L f/2 - 100 f/2.8 Macro - Siggy 15 f/2.8 Fisheye - RF TC1.4 - EF TC1.4 II - TC2 III - (2) 600EX-RT - ST-E3-RT
snapperz
Nov 22, 2012 15:37 |  #8
I use the RRS MH-01 too (for the 500 f4II).
Gear
amfoto1
Nov 22, 2012 16:35 |  #9
You can do any of the above...
1. Just screw the monopod directly into the tripod mount. This is solid, but a bit inflexible.
2. Put an Arca-Swiss style platform onto the top of the monopod and use a matched AS type plate on the bottom of the lens. This is fast to install and remove (hence the "quick release" name), and if you use a long enough AD plate on the lens' tripod mount you can slide the lens back and forth a bit to better balance the lens on various cameras. It still doesn't allow as much flexibility as a ballhead, though. There are other quick release types... The reasons I'd recommend the AS type is that it's the most common and it allows for some sliding adjustments.
3. Put a moderate size ballhead on the top of the monopod. It can either have a quick release or not. I use a modified Manfrotto head ballhead with an Arca-Swiss type platform on it (originally it had a Manfrotto type QR platform, but I converted it along with everything else to the more universal AS type). Here's a top of the line head (external link) designed for a tripod at Kirk Enterprises. There are many others possible... just watch that they have an adequate weight support rating. Here is a matching lens plate (external link), designed for the 400/5.6L... but I'd probably get a little longer plate that allows for more sliding adjustments.
A ballhhead allows you to use the lens and monopod at all sorts of odd angles. That's often come in handy for me.
Tapeman
Sliced Bread
Joined Jan 2004
Nov 22, 2012 19:05 |  #10
Gitzo 1558. Monopod with a front to back tilt feature.
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
bobbyz
Nov 22, 2012 19:17 |  #11
convergent wrote in post #15276938 (external link)
^^^This.
I prefer Arca swiss plate over direct connection to the monopod. Much easier to take out the lens. No need to tilt when shooting sports IMHO. If you do tilt the whole monopod.
Fuji XT-1, 18-55mm
SiaoP
Nov 22, 2012 19:33 |  #12
When I had the 400mm f/2.8 IS I hooked it directly on the monopod.
My Flickr (external link) | Gear List
jimewall
Nov 22, 2012 20:08 |  #13
Wallace River wrote in post #15276824 (external link)
I use a variation of this, but not for sports. It is good if you are going to tilt down (next to the monopod) or almost directly up frequently for extended times. Otherwise straight to the monopod would probably be better. For what you described you will not be tilting like that, so IMO it would be an unnecessary large expense.
So either straight to the monopod or by a Arca-Swiss clamp for the pod and a plate for the lens. If you already use A-S go clamp, otherwise your choice. I like A-S.
I personally would not want to put that 8+ pound monster on a monopod with any ballhead. Big lenses and B-Hs on tripods yes, monopods no!
Thanks for Reading & Good Luck - Jim
GEAR
ed ­ rader
"I am not the final word"
Nov 22, 2012 22:13 as a reply to  @ jimewall's post |  #14
Really right stuff plate and quick release is what I now use.
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
nigpd
Nov 23, 2012 03:08 |  #15
Tapeman wrote in post #15277563 (external link)
Looks like this is discontinued as I cant find it anywhere. Is there a recognised successor to this old model that has the front to back tilt feature?
7,526 views & 0 likes for this thread, 18 members have posted to it.
954 guests, 108 members online
