Thread started 22 Nov 2012 (Thursday) 18:11
EOS Utility won't connect to 5D MkII
sceee1991
Nov 22, 2012 18:11 |  #1
For some reason my EOS Utility (2.8.1.0) quit connecting to my my 5D Mark II. The computer still connect to the camera, and I can retrieve the images manually, but EOS Utility doesn't even act like like the camera is connected. I tried updating to the latest version, and I have tried uninstalling and reinstalling. I have also tried connecting through a different USB port. Finally, I have tried installing EOS Utility on a different computer, and it worked fine. Any suggestions?
Critique and advice are always appreciated, even when it's brutally honest.
Equipment
~Canon 400D XTi, Canon 5D Mark II, Canon 24-105mm f/4 L IS USM,
Canon 50mm 1.4, Sigma 70-300mm f/4-5.6 DG APO, Kit Lens, Dynatran 858 Tripod, SLIK Pro 700 DX Tripod
grasshopper315
Gallery: 11 photos
Joined Apr 2012
Nov 22, 2012 19:31 |  #2
Are you running Windows 8? I have (had) same problem with Windows 8 and my XTi and 7D. 7D ok after I installed .NET 3.5 and rebooted. XTi still not recognized. When I connect XTi the EOS Utility splash screen flashes but does not open.
Others have similar problem with Windows 8 on the Canon forum. I'm watching for any update.
http://forums.usa.cano​n.com …Utility-problem/td-p/1189 (external link)
sceee1991
Nov 22, 2012 19:58 as a reply to  @ grasshopper315's post |  #3
Thanks for the reply. I am running Windows 7, and this is the same desktop that this has been installed on for almost a year.
Equipment
sceee1991
Dec 08, 2012 09:02 |  #4
I still have been unable to connect to the camera via EOS Utility. I have tried uninstalling and reinstalling EOS utility, but no luck. I can get the pictures off of the camera via Windows Explorer, and EOS Utility will work with the camera on my work computer. At this point, I am about to give up on fixing it.
Does anyone have a recommendation for another software package to use to transfer photos from the camera to the computer?
Equipment
Lowner
"I'm the original idiot"
Dec 08, 2012 12:07 |  #5
All I can tell you is that I use the same arrangement, both the camera and the software and have after a few hicc-ups early on it has been OK (the hicc-ups were entirely my own fault at the time).
I connect the camera to the PC, Eos Utility recognises its required and opens without my having to do anything. Sounds to me as though you have accidentally altered something vital. Easily done on computers sadly.
Richard
LeeRatters
Dec 08, 2012 12:42 |  #6
Mine won't connect when it auto opens so I click ok to shut it down. I then open EOS manually & it's fine.
>> Flickr << (external link)
>> Instagram<< (external link)
sceee1991
Dec 08, 2012 13:01 |  #7
Mine will not autoconnect or manually connect. When I attempt to open it manually, it looks like the camera is not connected.
Equipment
NebrGuy
Gallery: 165 photos
Joined Nov 2010
Jul 20, 2013 13:46 |  #8
Not to revive an old thread, but wondering if you ever found a solution. I've been having problems with my 50d on both Windows 7 and Windows 8 machines.
Flickr (external link) | Gear | Facebook (external link) | Instagram (external link)
- Graflex Speed Graphic w/ Zeiss 15cm, Kodak 100mm & Schneider 210mm
- Argus C3 w/ Argus 35mm, Argus 50mm, and Argus 100mm
- Yashica TL Electro X w/ Accura Diametrica 28mm, Yashinon 50mm, and Pentax Asahi 135mm
- Canon EOS Rebel G II w/EOS mounting lenses used in digital work
3,823 views & 0 likes for this thread, 5 members have posted to it.
884 guests, 130 members online
