Thread started 02 Jan 2006 (Monday) 11:41
60mm vs 100mm Macro
detzX
Jan 02, 2006 11:41 |  #1
I'm thinking of getting a macro so I can get tripple rebates back(even though I should spend the money) and I had planned on the EF-S 60mm f2.8 macro but then I read reviews on the EF 100mm macro and they seems like a better lense. It is worth the extra $150 to get the 100mm lense?
detzX
Jan 02, 2006 11:43 |  #2
Also, think the EF-S will be harder to sell if I ever need to?
Jon
Joined Jun 2004
Jan 02, 2006 11:51 |  #3
Extra $150? Where are you shopping? The difference at B&H is like $70, and the 100 has a $20 rebate rather than the 60's $15. So if you're getting triple rebates, the difference is even less. I'd go with the 100 - working distance is the most valuable resource for macro work, and the longer lens will give you more working distance.
Jon
Cocker Spaniels
OregonRebel
Jan 02, 2006 11:57 |  #4
You get only two inches more working distance with the 100 mm macro -- significant, but you should also consider the lower price, lower weight, & greater handholdability of the 60 mm one (currently $370 at Beach Camera). See my Flickr page for a few sample EF-S 60 macro shots or click here: http://www.flickr.com …om.gne?id=79543​903&size=l (external link)
Brian N
7D, Rebel XT, G16, EF-S 10-22, EF-S 15-85 USM IS, Sigma 30 f/1.4, EF-S 60 macro, 85 f/1.8, EF 70-200 f/4L IS , Canon 1.4 TC, 430 EX, 270 EX
Bogen/Manfrotto 3001BPro/484RC2
Some pix at www.flickr.com/photos/​briann/ (external link)
kaitanium
Jan 02, 2006 11:58 |  #5
yes it will be worth it. to get 1:1 on my 50mm i have to get within a centimeter of the subject and im sure the 60mm wont be far off either. a 100mm will definetly give you more room
malla1962
Joined Jul 2004
Jan 02, 2006 12:00 as a reply to  @ kaitanium's post |  #6
Go for the 100.:D
jjonsalt
Jan 02, 2006 12:01 as a reply to  @ kaitanium's post |  #7
I can tell you that the 100mm macro is just about as good as macros get.
OregonRebel
Jan 02, 2006 12:06 as a reply to  @ kaitanium's post |  #8
60 mm has 4" working distance at 1:1
100 mm has 6" working distance at 1:1
Using the working distance over everything else argument means everyone should get the 180 mm macro (10" working distance).
Brian N
Canonised
Gallery: 26 photos
Jan 02, 2006 12:10 |  #9
I use the 100mm for all my creative shots and its a wonderful lens that never lets you down.
Have a look at this photomontage - http://harrytan.sg …reguetTradition​/index.htm (external link)
While it does hunt in low lighting, in macro - you should be using manual focussing anyway. I have not used the other macro but judging from those who bought this lens it appears to be a winner for them as well.
Also - it works wonders as a portrait lens and have shot some beautiful photos of my wife and kids using this lens.
Its so sharp - it cuts.
CANONISED (aka Horolographer)
INSTAGRAM - http://instagram.com/h​arrytanphotography (external link)
Horolography blog - http://watchinghorolog​y.com (external link)
Photography blog - http://harrytanphotogr​aphy.com/ (external link)
MrChad
Joined Aug 2004
Jan 02, 2006 12:11 as a reply to  @ OregonRebel's post |  #10
I would also look to use the Macro as a portrait lens, and for me the 60mm would be a much better focal length for portrait use.
I kaNt sPeL...
[Gear List]
Jon
Joined Jun 2004
Jan 02, 2006 12:13 as a reply to  @ OregonRebel's post |  #11
And that would be wrong, why? Bear in mind the 60 and 100 aren't that far apart in price as well.
Jon
Cocker Spaniels
detzX
Jan 02, 2006 12:15 as a reply to  @ Jon's post |  #12
Kind of off topic but is it possibly to get a hood that would work/fit the 100mm macro and my 50mm 1.8 or are they too different? What about a filter?
From what I've read it's a good idea to get the hood with the macro, it's $40 though! :(
Jon
Joined Jun 2004
Jan 02, 2006 12:18 |  #13
Your 50 takes a 52 mm filter; the 100 takes a 58 mm. You could get a 52-58 mm step-up to use a 58 mm polarizer with your 50 as well. Hoods - you're dealing with both different lens diameters and different angles of view.
Jon
Cocker Spaniels
OregonRebel
Jan 02, 2006 12:22 |  #14
The 60 mm macro also takes 52 mm filters, so you could use the same ones as the 50 1.8.
Brian N
ddelallata
Jan 02, 2006 12:22 |  #15
The 100 is an excellent lens. I just sold mine last week, but I plan on buying one again by Spring.
Dr. David de la Llata
_____________
Canon 20D
BG-E2 Battery Grip
Canon SpeedLite 430 EX
Canon EF 1.4X II
Canon EF-S 10-22mm F/3.5-4.5 USM
Canon EF 50mm F/1.4 USM
Canon EF 100mm F/2.8 MACRO USM
Canon EF 24-70mm F/2.8 L USM
Canon EF 70-200mm F/2.8 L USM
Olympus C-2020 (for infrared work)
4,332 views & 0 likes for this thread, 11 members have posted to it.
60mm vs 100mm Macro
1926 guests, 101 members online
