Thread started 24 Nov 2012 (Saturday) 09:07
Background and the moon, What settings?
DigitalDon
Joined Aug 2012
Nov 24, 2012 09:07 |  #1
Hi all
Back before I bought my Canon T3i I saw the most beautiful seen, I left my house not even thinking about photography and when I took a left onto the main road there it was, the full moon was off to the right of the road over the trees, the road and trees on the left were lit by the moon and the trees on the right side of the road were in silhouette from the light behind them.
I would so love to have a picture of what I saw that night but don't have a clue as to what settings to use in Manual mode, I have the kit lense that came with the T3i not sure which one of them I should use either, I have watched numerous Youtube videos and can't seem to find one that makes it crystal clear for me, some say long exposures others say the moon is so bright that you don't have to use long exposures, some of the videos are more rants and raves, music in the background and other distractions that I can't think straight. So would somebody Please give me some simple settings to try?
Don
(EOS RebelT3i EF-S 18 - 55 IS II Kit) (EFS 55 - 250 mm lense f/4-5.6 IS II) (YONGNUO YN 565EX flash)
Sorarse
Nov 25, 2012 09:22 |  #2
The moon is in full sunlight, so only needs a short exposure to capture it correctly, typically 1/125 at f/8 or f/11 with 100 ISO. The problem with that setting is that it will leave your moonlit street scene severely under exposed. You can either expose for the street scene, which will leave the moon as a bright white blob in the sky, or you can try taking two images on a tripod, one exposed for the street and the other for the moon, and combine the two in post.
At the beginning of time there was absolutely nothing. And then it exploded! Terry Pratchett
http://www.scarecrowim​ages.com (external link)
Canon PowerShot G2
Bernoulli
Nov 25, 2012 09:27 |  #3
Don, it depends on where you want the details to be visible. There is probably no setting where you can see detail on the moon and detail in the landscape. But you can get great pictures still.
For detail on the moon, stop down to f/8, use your highest zoom, and you can shoot fast enough to hold it by hand. Try about 1/200 sec but experiment between 1/500 and 1/100 sec to get an exposure you like. You'll be able to see stuff on the moon and the landscape will be dark but you might get some cool effects like the silhouette of trees and hills. The moon will be pretty small in the picture unless you can zoom out to at least 300 mm, and your kit lens probably stops at 55 mm.
For moonlit landscape, you'll need a tripod. Here's a shot of my house under a full moon (not in the picture) taken with a T2i and a 17 mm lens. But it was a full 15 seconds at ISO 1600 and f/4. This is pretty extreme in that it actually looks like sunlight except for the stars in the sky. Focusing was a bit of a challenge because the autofocus couldn't lock on anything under just moonlight, so I used a laser pointer on the house and focused manually.
This sounds complicated but it's not. Just experiment with exposures but you probably do need a tripod if you want any foreground detail. It's really hard to predict what you'll get and, if you try a bunch of different settings, you might be surprised by getting a great shot.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/11/4/LQ_625282.jpg
Image hosted by forum (625282) © Bernoulli [SHARE LINK]
Rick
rulrich@uark.edu (external link)
StillCrazy
Joined Sep 2012
Nov 25, 2012 09:50 |  #4
Sorarse wrote in post #15286471 (external link)
^^ That's your best bet.
You might also try shooting the moon during daylight. It sometimes rises before the sun sets and you can capture it and the scene without too much trouble. In December you may find the moon rising early.
Here's a link to a moon/sun set/rise tables.
http://www.timeanddate​.com/worldclock/moonri​se.html (external link)
StillCrazy - after all these years.
Canon T3i, Sigma 18-200, Sigma 10-20, Tamron 70-300, Rokinon 14, Yongnuo YN 565 EX
My flickr (external link)
DigitalDon
Joined Aug 2012
Nov 25, 2012 17:41 as a reply to  @ StillCrazy's post |  #5
Thanks a bunch will be trying the suggestions, I'm liking the picture, will have to try that to, Thanks again
Don
mtbdudex
Gallery: 35 photos
Nov 26, 2012 05:11 |  #6
The only thing I'll add to what others have said is I've found the best time is sunset when the ambient light is enough you can see the foreground and still expose the moon correctly so it does not look like a bright blob.
Some images here: https://photography-on-the.net/forum/showthre​ad.php?t=949159
taken with my T1i using the 15-85 lens on tripod, PP done in Aperture 3.1
IMAGE: http://lh3.ggpht.com/_FqTNmgNQHz8/TMM-v2PcwGI/AAAAAAAALFU/_qqFzn8MNsc/s800/IMG_8498.jpg
Mike R, P.E. ...iMac 27"(i7), iPad2, iPhone14Pro, AppleTV4K, MacBook
Canon: Body R5, lens RF 24-105mm L F4, RF 100-500mm f/4.5-7.1L, 1.4 TC, EF 70-200 L f2.8 IS II / TC 1.4x 2x
FEISOL tripod CT-3441S + CB-40D Ball Head
My top 10 in Astrophotography. . .DIY acoustic panels (external link) . . APOD Aug-5-2011 (external link)
DigitalDon
Joined Aug 2012
Nov 27, 2012 07:43 |  #7
mtbdudex wrote in post #15290136 (external link)
Yes, That picture matches what I am looking to do, will try it and see what happens, Thanks to all for your help, sure makes it a lot easier for somebody new to all of the digital photography stuff.
Don
Bernoulli
Nov 28, 2012 15:15 as a reply to  @ DigitalDon's post |  #8
I've gotta admit, I didn't realize you could get both exposed together so well but doing it at twilight makes sense. Thanks for the tip mtbdudex.
Rick
2,289 views & 0 likes for this thread, 5 members have posted to it.
1047 guests, 105 members online
