Thread started 25 Nov 2012 (Sunday) 10:19
1d Mark IV Drive Speed
jase1125
Nov 25, 2012 10:19 |  #1
I'm curious, has anyone compiled a list of the custom functions that can impact drive performance. I have some custom function set (unidentified) that is reducing my drive speed to about 8 frames per second. If I clear custom functions, then the drive speed returns to the expected 10FPS. If I set the AF parameters like I normally do, drive speed continues at 10FPS. Battery is fully charged. I shoot raw so ALO, Noise reduction, HTP shouldn't matter. There is ALOT of custom functions for me to go though 1 by 1 so I thought maybe someone has a list compiled already.
Thanks in advance
Jason
JeffreyG
Gallery: 42 photos
Nov 25, 2012 10:26 |  #2
It's probably setting release priority to focus acquisition. The camera will wait to be in focus before releasing the shutter.
Most anything not related to focus can affect how quickly the buffer clears and fills, but will not change the burst speed.
For a quick confirm on my theory, set all of your funtions and then try a burst with the lens set to AF followed my MF. If the speed changes, it is clearly an AF related function.
convergent
Gallery: 34 photos
Nov 25, 2012 11:11 |  #3
The battery charge has no effect on fps.... It's a digital camera. The main CF that will slow it down is prioritizing focus over shutter release, or if you set crazy slow shutter speeds.
Mike
R6 II - RF 100-500L f/4.5-7.1 IS - EF 17-40L f/4 - 24-70L f/2.8 II - 70-200L f/2.8 IS II -
135L f/2 - 100 f/2.8 Macro - Siggy 15 f/2.8 Fisheye - RF TC1.4 - EF TC1.4 II - TC2 III - (2) 600EX-RT - ST-E3-RT
cristphoto
Nov 25, 2012 11:41 |  #4
I haven't noticed any significant difference in FPS rate. There might be a split second for the first shot to lock focus but all following shots don't seem to be affected. Obviously setting different functions will impact the buffer capacity.
1DX MK II, 5D MKIV x2, 24L II, 35L II, 50L, 85LIS, 100LIS Macro, 135L, 16-35LIS, 24-105LIS II, 70-200LIS, 100-400LIS II
koala ­ yummies
Gallery: 33 photos
Nov 25, 2012 12:45 |  #5
convergent wrote in post #15286854 (external link)
According to the manual, it does.
1D4 manual:
"When the battery level is low, the drive mode icon <Highspeed/Lowspeed/sin​gle shot> will blink. If the <Highspeed> icon blinks, the continuous shooting speed will decrease slightly."
Link to PDF of 1D4 manual:
http://www.bhphotovide​o.com/lit_files/13504.​pdf (external link)
From Canon website on the 1DX:
"The maximum continuous shooting speed is restricted to 10 fps when the battery charge is less than 50% or when ISO speed is above 32000. If the camera's internal temperature is low and ISO speed is above 20000, the maximum continuous shooting speed is restricted to 10 fps."
http://learn.usa.canon​.com …s/eos_1d_x/eos_​1d_x.shtml (external link)
Also stated in the 1D4 manual:
"In the AI Servo AF mode, the continuous shooting speed may become slightly slower depending on the subject and lens used"
bobbyz
Nov 25, 2012 13:31 |  #6
JeffreyG wrote in post #15286671 (external link)
Most probably this. All cameras slow down fps based on release priority.
Easy to check, put lens on MF, single shot and see what kind of fps you get. It should be the max.
Fuji XT-1, 18-55mm
convergent
Gallery: 34 photos
Nov 25, 2012 13:44 |  #7
koala yummies wrote in post #15287176 (external link)
If it does, then its got to be because of something to do with the focussing speed of the lenses. There is no logical reason why the body would slow down. Everything in it, except for the shutter, is digital... and will either work completely, or not at all. The shutter also can't "slow down" or the shutter speed wouldn't be correct.
Mike
koala ­ yummies
Gallery: 33 photos
Nov 25, 2012 14:43 |  #8
convergent wrote in post #15287400 (external link)
Where did anyone in here say that it did? Every reference I made was quoted directly from Canon with links, the term Canon uses is "continuous shooting speed". The term 'shutter speed' or even the word 'shutter' isn't anywhere in my post.
I quoted directly from the Canon manual and Canon website, the continuous shooting speed can be affected by the battery charge, you said 'the battery charge has no effect on fps'. I was pointing out that Canon has clearly stated otherwise. That was what my reply was about. Canon has clearly stated the stated continuous shooting speeds of a camera can slow down with certain battery charges, and certain lenses. It's all in those links provided by Canon. There is nothing to argue speculate or debate about here.
convergent
Gallery: 34 photos
Nov 25, 2012 19:24 |  #9
koala yummies wrote in post #15287619 (external link)
I never said that you did say that. I said that. I was just trying to talk through why a digital camera would "slow down" in any way due to a battery not being at 100%. I'm not questioning what the manual says.. obviously I believe you if you say you are quoting the manual.
Having spent many years working in electronics, it makes no sense (to me) that the body would slow down. The only thing mechanical is the shutter, and it can't slow down as mentioned. Everything else is digital, not analog. Digital stuff doesn't usually slow down because of voltage changes. It either works or it doesn't. This is why I was speculating that possibly the motors in the lens are affected... but I thought they were digital stepping motors.
I guess its one of those things that makes you go "hmmmmm". I wonder to what degree this slow down happens... any indication in the manual if we are talking about changes that are so small as to not be perceived?
Mike
jase1125
Nov 25, 2012 20:27 |  #10
I actually did that. It isn't related to AF as far as I can tell. With the camera in one shot the drive speed still is lower than it should be. Thanks for the suggestion though.
Jason
jase1125
Nov 25, 2012 20:31 |  #11
convergent wrote in post #15288694 (external link)
Metering has also been known to slow the drive speed down on the 7D. Battery charge on a number of bodies as well. Takes a good bit of juice to drive the shutter mechanism at full frame rate, capture the image, process it, write to the card and drive the lens motor I suppose. Anyway, I am still trying to uncover the mystery of mine.
Jason
NullMember
Nov 26, 2012 07:53 |  #12
bannedPermanently
jase1125 wrote in post #15286647 (external link)
...If I clear custom functions, then the drive speed returns to the expected 10FPS. If I set the AF parameters like I normally do, drive speed continues at 10FPS...
Well if you have cleared the custom functions and reset the AF parameters and the result of this is a drive speed of 10fps, then surely you have solved the problem.
jase1125
Nov 26, 2012 15:14 |  #13
john crossley wrote in post #15290452 (external link)
What I mean is I configure the af parameters exactly the same when my max drive speed is about 8fps. Only clearing all of the custom functions restores 10FPS. Returning the af parameters to their default values does not.
Jason
NullMember
Nov 27, 2012 05:06 |  #14
bannedPermanently
jase1125 wrote in post #15292033 (external link)
So which "Customm Functions" are you changing that make the drive speed drop to 8fps.
jase1125
Nov 27, 2012 06:16 |  #15
john crossley wrote in post #15294432 (external link)
That is what I am trying to figure out :p :D
Jason
3,101 views & 0 likes for this thread, 11 members have posted to it and it is followed by 2 members.
990 guests, 121 members online
