Thread started 26 Nov 2012 (Monday) 09:35
Soft pictures with 430EX need a softbox for when i need to flash directly at subject
platforminc
Joined Feb 2012
Nov 26, 2012 09:35 |  #1
I was recently at a gathering this week, and the situation was that the living room where most of the subjects were isnt well lit, its at night i.e 11pm on a winter night, and the ceiling is brown painted wooded strips, so not even a flat smooth white ceiling. What I'm trying to say here is that I couldnt bounce off the ceiling and little or no ambient light either.
I find that the pictures come out OK if I point the 430 ex at the subject, I have a plastic difusser, unfortunately I have to shoot from a distance otherwise the light becomes a bit of a mess and too harsh.
I know I need a softbox to widen and spread the light, but I do not want to spend a huge fortune since I'm only an amateur who enjoys taking shots of people especially.
I have seen the following
http://www.amazon.co.u​k …/ref=cm_cr_pr_p​roduct_top (external link)
http://www.amazon.co.u​k …3QADBAW/ref=cm_​cr_pr_pb_t (external link)
The bottom line is that I need something cheap, that works and one that would easily fit into a small bag that I put my kit into.
Any advice would be appreciated.
Camera: Canon 500D, f1.8 50mm, kit lens, Tamron 17-50 f2.8 VC, 430EX flash, Remote control,Tripod, Cleaning kit.
René ­ Damkot
Nov 26, 2012 11:29 |  #2
Bounce of a wall?
Those mini-sofboxes won't do you much good. A big flip-it (or home made version) would be a better option.
http://www.dembflashpr​oducts.com/mega/index.​html (external link)
http://strobist.blogsp​ot.nl …9/well-that-was-fast.html (external link)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
platforminc
Joined Feb 2012
Nov 26, 2012 11:46 |  #3
I just couldn't bounce off the wall, results were shocking, imagine you had 2 parallel Walls, how will you shoot a subject and still bounce off wall.
platforminc
Joined Feb 2012
Nov 26, 2012 12:28 |  #4
Also the card that pops out of the 430ex is almost absolutely useless as I don't see the light bounce back off the pop out card, could be to do with the fact that its glass and the light can go through it.
sdipirro
Nov 26, 2012 12:51 |  #5
I've had pretty good success with the Lumiquest Promax system with the flash on camera. It gives you several options for bouncing the flash. If you want to move the flash off-camera, the Qbox 24 is highly regarded.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
CJCMarquez
Joined Aug 2012
Nov 26, 2012 12:57 |  #6
Similar to the post above, I've seen great results with the Demb Flip + Diffuser as seen in this link.
http://www.dembflashpr​oducts.com/diffuser/ (external link)
Chad or CJ
Gear/Feedback - 500px (external link) - Flickr (external link) - Facebook (external link)
platforminc
Joined Feb 2012
Nov 26, 2012 14:07 |  #7
Any cheaper option you can find for me on amazon.co.UK (:-) thanks
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Nov 26, 2012 14:12 |  #8
platforminc wrote in post #15291756 (external link)
Go to a local hobby shop, they likely carry a product called craft foam. Then do something akin to this with it.
http://www.petapixel.c​om …our-own-free-bounce-card/ (external link)
abbadon31
Gallery: 264 photos
Best ofs: 10
Nov 26, 2012 14:17 |  #9
use a milk jug
I AM SHOM
RPCrowe
Joined Nov 2005
Nov 26, 2012 14:29 |  #10
CJCMarquez wrote in post #15291492 (external link)
+1 for the Demb Flash Diffuser Pro... Using the variable angle FlipIt reflector at about 45 degrees forward will provide quite decent lighting even when there is nothing off which to bounce...
Example:
IMAGE: http://rpcrowe.smugmug.com/Other/Yangshuo-a/i-P35tw2Z/0/L/063%20silk%20weaver-L.jpg
IMAGE LINK: http://rpcrowe.smugmug​.com …914758&k=P35tw2​Z&lb=1&s=A  (external link)
FEChariot
Gallery: 13 photos
Joined Sep 2011
Nov 26, 2012 15:59 |  #11
platforminc wrote in post #15291405 (external link)
The 430 doesn't have a bounce card. That is a wide angle dispersion grid for full coverage when shooting up to 14mm wide. The 580's have the white card that pulls out of the top.
The Rouge Flashbender is pretty nice:
http://www.bhphotovide​o.com …r_Large_Positio​nable.html (external link)
Although I use it more as a flag or a snoot than for trying to enlarge the light source. Ideally for that you are going to want to get some off camera triggers and a shoot through umbrella as a minimum if you want to really soften the light.
Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
1,434 views & 0 likes for this thread, 8 members have posted to it.
1349 guests, 130 members online
