Thread started 27 Nov 2012 (Tuesday) 08:59
Focus Stacking to Avoid Diffraction
Garry ­ Gibson
Gallery: 41 photos
Nov 27, 2012 08:59 |  #1
Guys here is a really good article from Naturescapes on a simple way to focus stack to avoid diffraction and increase front to back sharpness. It caught my interest because he uses a Zeiss 21ZE and a 5D MII similar to my kit.
Anyway, take a look I am going to test it this weekend to see if I can duplicate his efforts.
http://www.naturescape​s.net/docs/index.php/a​rticles/536 (external link)
5D SR- 7D Mark II
Some assorted glass
Learning everyday... well.. maybe every other day.
Echo ­ Johnson
Joined Aug 2011
Nov 27, 2012 09:02 |  #2
I never realized focus stacking was that simple. Thanks, Garry.
Canon 5D3 | 17-40 | 50/1.4 | 135/2
...and other stuff.
Flickr (external link) | EchoJ.deviantART (external link)
Bayard
Joined Jul 2012
Nov 27, 2012 09:16 |  #3
great article; only thing that wasn’t clear was what version of PS do you need.
6D / 70-200 2.8ISii / 24-105Lf.4 / 50 1.4
pdrober2
Joined Nov 2010
Nov 27, 2012 14:50 |  #4
very cool.
Fujifilm X-T1 | 23 | 27 | 56 | 90 | 55-200
Feedback
pulsar123
Gallery: 82 photos
Nov 27, 2012 14:58 |  #5
I only used focus stacking for macro work (e.g. the shot below was made out of almost 100 RAW images), but I heard people use it for landscape work as well. One can use free software enfuse to achieve decent results, as described here (external link).
Also, newest Magic Lantern add-on firmware now has a decent support for focus stacking, so it's almost fully automatic. (You need an AF lens, of course; Zeiss won't work.)
IMAGE: http://farm7.staticflickr.com/6081/6108767926_e51d5fb77d_n.jpg
IMAGE LINK: http://www.flickr.com/​photos/syamastro/61087​67926/  (external link)
Portrait of my neighbour (external link) by syamastro (external link), on Flickr
6D (normal), 6D (full spectrum), Tamron 24-70 f2.8 VC, 135L, 70-200 f4L, 50mm f1.8 STM, Samyang 8mm fisheye, home studio, Fast Stacker
Copidosoma
Nov 27, 2012 15:20 |  #6
Bayard wrote in post #15295061 (external link)
I know it works in CS4
Gear: 7DII | 6D | Fuji X100s |Sigma 24A, 50A, 150-600C |24-105L |Samyang 14 2.8|Tamron 90mm f2.8 |and some other stuff
http://www.shutterstoc​k.com/g/copidosoma (external link)
https://500px.com/chri​s_kolaczan (external link)
MMp
Gallery: 46 photos
Nov 27, 2012 21:27 |  #7
Echo Johnson wrote in post #15294992 (external link)
+1...I always assumed it involved a ton of manual work, both with focusing and post-processing.
With the impending forum closure, please consider joining the unofficial adjunct to the POTN forum, The POTN Forum Facebook Group (external link), as an alternate way of maintaining communication with our members and sharing/discussing the hobby.
taemo
Joined Sep 2011
Nov 27, 2012 23:26 |  #8
wow wish i knew about this 2 weeks ago in maui.
will have to try this next!
earldieta.com (external link) - flickr (external link) - tumblr (external link) - gear/feedback
the spirit is willing but the body is sore and squishy
4 digital cameras | 14 film cameras
Mrslinger85
Gallery: 6 photos
Dec 06, 2012 15:45 |  #9
Great article, and very simple. Thanks!
Jon E.
My Flickrexternal link
ejenner
Gallery: 98 photos
Joined Nov 2011
Dec 06, 2012 16:51 |  #10
mannetti21 wrote in post #15297981 (external link)
In the simplest of cases you may only need a few shots (for non-macro) and the PP is very easy (I have Helicon Focus), but as mentioned there are other software.
However, sometimes you really have to consider what settings to use and how to stack. If anything is moving or the near foreground obscures the background you can get a 'dead' zone where you don't have a focused image (and of course the water movement in the example above is easy to deal with). But many times you can indeed go from shooting at f16 to focus stacking at f8.
So it still takes some experience, but I use it a lot.
One thing that is not stressed enough IMO is that even at f11-f16, there is a decent difference in sharpness between something at the focal plane and something at the edge of the DOF. So even in tricky situations, often a focus stack of 2-4 exposures at f11 will yield and overall much sharper image than a single shot, even if the entire scene is in the 'theoretical' DOF. To me it almost looks like that is what the author of the article is doing. In other words the background isn't completely OOF when focused on the foreground. IMO this is a great way of using focus stacking for landscapes - choose an aperture that is not too wide, even if that means stopping down to f11 or even f16 and make 2-4 exposures. Then you will likely have very little problems in PP.
The above is especially true for the corners, which the author also focuses on. I've really surprised with all the attention that corner sharpness gets in landscape lenses that this isn't more widely recognized. Even if you shoot a moving scene at f11 with everything in the DOF, taking an extra shot for the near corners at a much closer focusing distance can really sharpen them up.
Here's a case where with the perspective I wanted and using a FL of 80mm, I couldn't get everything in focus, even at f16. But rather than just use f7.1 for the focus stack, I checked using LV and DOF preview what aperture I needed to have the tree not too OOF when I had the mid-ground in focus. If I used f7-f8 the tree would be so OOF it would obscure the mid-ground resulting in halos. So I actually ended up focus stacking this at f16 (6 exposures) and although I know I have some diffraction, this is stiff very sharp (I know you can't tell in an 800px image).
Although this was with a relatively long FL for landscape, the idea is still the same with wide angles - make sure nothing that is very OOF obscures anything in focus and the process is very, very easy (there was absolutely no manual adjustment with this one because I was careful to use the best aperture). You'll be amazed at how much sharper the corners are with almost any lens than having those parts of the scene near the DOF limit.
The second image is one of the shots (not processed) focused on the tree at f16. I would have needed at least f32 to get everything in focus.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/12/1/LQ_627005.jpg
Image hosted by forum (627005) © ejenner [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/12/1/LQ_627006.jpg
Image hosted by forum (627006) © ejenner [SHARE LINK]
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
MNUplander
Gallery: 10 photos
Dec 06, 2012 22:22 |  #11
How big do you need to print for this to actually matter? I see the theoretical benefits but I print 20x30's regularly and have never needed this...ever.
Lake Superior and North Shore Landscape Photography (external link)
Buy & Sell Feedback
R6, EF16-35 f4 IS, EF 50 1.2, EF 100 2.8 IS Macro, 150-600C
Hogloff
Joined Apr 2003
Dec 06, 2012 22:36 |  #12
MNUplander wrote in post #15336238 (external link)
It really depends on the shot. If you have closeup foreground along with distant background, it is very hard to get everything into focus. Normally the background is not pin sharp as you try keeping the foreground sharp. Focus stacking allows the entire image to be pin sharp. These are just the limits of physics at play here.
aachow
Joined Dec 2012
Dec 06, 2012 23:26 |  #13
I find MF a wide angle can be difficult to catch the proper focus. What would be the best way to focus on various subjects at various distances?
My FlickR (external link)
My 500PX (external link)
Canon 6D | 16-35L ii | 24-105L | 35L | Σ 50 1.4 | Σ 85 1.8 | 135L
Mike ­ K
Joined Apr 2001
Dec 07, 2012 03:10 |  #14
Garry Gibson wrote in post #15294972 (external link)
I also have a 5DII and Zeiss 21/2.8, but I never use that lens or focus stacking for this type of composition. Rather this is the perfect shot for the Canon 24 or 17 TSE lens. By tilting the focus plane downward just above the water's surface the leaves along the stream will all be sharp, from several inches to infinity. There are some tilt shift examples at the end of this article that I posted that demonstrate this application.
http://www.fredmiranda​.com/smallhd/ (external link)
If your have taller subjects in the foreground the lens tilt movement will not buy you the desired effect and focus stacking is much more appropriate.
Mike K
Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
Pax2You
Gallery: 179 photos
Joined Oct 2011
Dec 07, 2012 11:22 as a reply to  @ Mike K's post |  #15
Can this be done in PSE? (I have version 8)
Sony A9, Pentax K1 MKii, Panasonic G9, Sony 200-600, Samyang 12mm F2 NCS CS, 7Artisans 7.5mm f2.8 fisheye, Panagor 90mm f2.8 Macro (OM), , Sigma APO 2x DG EX TC, Tiffen aXent ND 3.0 (ND1000) filter, Olympus OMD E-M5(drown in the Atlantic), Oly 14-42mm, Oly 12-50mm, ZEQ25gt Mount, plus a few other lenses, extension tubes, and general mish-mash
6,986 views & 0 likes for this thread, 17 members have posted to it.
1440 guests, 139 members online
