Anyone had a problem with the canon battery grip , the camera works fine with the battery in the camera but wont work when the grip is fitted with either the 2 in the grip or the AA's in the grip .
Rob.
GyRob Cream of the Crop 10,206 posts Likes: 1413 Joined Feb 2005 Location: N.E.LINCOLNSHIRE UK. More info | Nov 28, 2012 15:52 | #1 Anyone had a problem with the canon battery grip , the camera works fine with the battery in the camera but wont work when the grip is fitted with either the 2 in the grip or the AA's in the grip . "The LensMaster Gimbal"
lannes Goldmember 4,370 posts Likes: 8 Joined Dec 2009 Location: Perth, Australia More info | Nov 28, 2012 16:20 | #2 how tight are you screwing in the grip, sometimes when you make it too tight it affects the connection, I only make mine as tight as I can go using the thumb, back yours off a bit it might help. 1Dx, 1DM4, 5DM2, 7D, EOS-M, 8-15L, 17-40L, 24 TSE II, 24-105L, 50L, 85L II, 100L, 135L, 200L f/2.8, 300L f/4, 70-200L II, 70-300L, 400Lf/5.6
GyRob THREAD STARTER Cream of the Crop 10,206 posts Likes: 1413 Joined Feb 2005 Location: N.E.LINCOLNSHIRE UK. More info | Nov 28, 2012 16:30 | #3 Hi Thanks "The LensMaster Gimbal"
Nov 28, 2012 18:39 | #4 GyRob wrote in post #15301329 Hi Thanks It is a canon one, i just tried backing it of, no diffrence it still wont work and its not in between clicks . Rob. Correct me if i'm wrong, but doesn't the battery grip have an on/off switch? 6D - 24L II - 50L - 85L II - 135L
sonnyc Cream of the Crop 5,175 posts Likes: 36 Joined Jun 2005 Location: san jose More info | Nov 28, 2012 19:10 | #5 interlopr wrote in post #15301814 Correct me if i'm wrong, but doesn't the battery grip have an on/off switch? The on/off only for the switches on the grip.
GyRob THREAD STARTER Cream of the Crop 10,206 posts Likes: 1413 Joined Feb 2005 Location: N.E.LINCOLNSHIRE UK. More info | Nov 29, 2012 03:00 | #6 Yes i have tried the on off switches ,the camera and grip only came yesterday so are new, looks like something is broke . "The LensMaster Gimbal"
Nov 29, 2012 04:15 | #7 I presume you're just going to send one (or both) back for a replacement then? I think I'd just send the grip back first of all so you still have the camera, but I guess it's hard to determine which is at fault Chris Marriott Photography
apersson850 Obviously it's a good thing More info | When I bought a grip for my 400D, several years ago, the first one I got was broken. Genuine Canon, but it didn't work out of the box. No power to the camera, but it drained the battery/batteries pretty quickly. Quick enough for the grip to become noticeably warm. Anders
GyRob THREAD STARTER Cream of the Crop 10,206 posts Likes: 1413 Joined Feb 2005 Location: N.E.LINCOLNSHIRE UK. More info | Nov 29, 2012 04:29 | #9 I have just email the shop and said the first thing to do would be try another grip and take it from there so will see what they say, its just one of those things . "The LensMaster Gimbal"
marcosphoto Member 80 posts Joined Jul 2011 Location: Bradford, Ontario More info | Nov 29, 2012 12:10 | #10 I've got a 3rd party grip which works perfectly, suppose you've got a defective part somewhere. I'd bet that a repair shop would want the grip and body together because there could be a problem with the contacts in the body too.
mchong75 Goldmember 2,927 posts Likes: 5 Joined Jun 2007 Location: Frisco, TX More info | Nov 29, 2012 14:12 | #11 Hopefully you took the white plastic cap off. (Michael) Gears:
Nov 29, 2012 16:03 | #12 lannes wrote in post #15301276 how tight are you screwing in the grip, sometimes when you make it too tight it affects the connection, I only make mine as tight as I can go using the thumb, back yours off a bit it might help. If it's a third party grip, check that the input dial on grip is not in between the click stops as this can also affect the operation. Also check the grip on/off switch you might not have fully selected one or the other Exactly what happened to me. I tightened it and haven't had a problem since. Christian
GyRob THREAD STARTER Cream of the Crop 10,206 posts Likes: 1413 Joined Feb 2005 Location: N.E.LINCOLNSHIRE UK. More info | Nov 29, 2012 17:53 | #13 lol "The LensMaster Gimbal"
| Latest registered member is semonsters 1473 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
