apersson850 wrote in post #15311600
Green box should select the same values as P mode does. Auto ISO may behave differently between them, though.
P mode is user selectable for the aperture and shutter values though. You spin the dial and it will speed up your shutter and open the aperture one way, or slow down the shutter and close the aperture the other. Green box, as far as I am aware, just selects values and you cannot change them. So, it isn't possible to say that green box should select the same values as P mode, as that would depend on how the user chose them anyway.
I have never used green box mode, simply because it leaves the camera to make every decision from shutter, ISO and aperture to give it's idea of correct exposure, to deciding what the subject should be and focusing on that.
In essence, setting green box mode is telling the camera that you don't care about what settings are used, so it can use what it likes. You get the convenience of not having to think about settings or focusing etc., but take the chance that the settings chosen are not going to be what you want. It is pointless complaining later that the camera chose the wrong settings.
I appreciate the desire sometimes to shoot on automatic and not worry too much about settings, but you can still do that without using green box. Using Av or Tv at least allows you to choose two values (or one if using auto ISO) and let the camera work around that.
In short, yes, full green box auto can be pretty dumb. It is guessing at what you might want with no clues coming it's way by setting at least basic shutter speed, or using a single focus point to tell the camera where to focus. It is far better to at least use a semi auto mode which allows some control and gets you out of all points AF, which is as likely to focus on a small bush to the right and in front of your subject, as your subject itself.
