Okay so my friends have asked me to do a family portrait for Christmas however all I have is a 480exII flash. Is it possible to make a really nice portrait using this flash or would I need a soft box for sure?
tristan Senior Member 322 posts Likes: 2 Joined Feb 2006 Location: Missouri More info | Dec 02, 2012 15:23 | #1 Okay so my friends have asked me to do a family portrait for Christmas however all I have is a 480exII flash. Is it possible to make a really nice portrait using this flash or would I need a soft box for sure?
TheLoftStudios Goldmember 1,072 posts Likes: 9 Joined Oct 2009 Location: Houston, Texas More info | Dec 02, 2012 17:00 | #2 If you're in like a large family room that is located in the house, simply set your flash to E-TTL, rotate it 180 degrees (facing away from the group) so that you are using the back wall and parts of the ceiling as a large light source. Now, using an ISO of about 800, setting your shutter between 1/60 and 1/125 at an aperture around f/5.6, you should get a very pleasing portrait of your family. Of course, this is just a starting point, you may want to do some fine tuning from that point..... MARK
oldvultureface Goldmember More info | I agree with Mark. And if you have walls to either side of your subjects, you can use them also with the ceiling. If the room is suitable for bounce flash, a softbox with more than three or four people may actually be a liability - uneven lighting and fall-off. Wall/ceiling directly behind the camera. Using the ceiling and wall camera right. Two examples from my own experience. Umbrellas either side of the subjects. Bounced flash.
Dec 03, 2012 14:10 | #4 Thanks guys! I appreciate the response!
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Dec 03, 2012 14:57 | #5 Nice samples by Vultureface. "If you're not having fun, your pictures will reflect that." - Joe McNally
dmward Cream of the Crop More info | Dec 03, 2012 16:28 | #6 Its a little hard to see, but there is a benefit bouncing the flash off a wall or wall ceiling corner to one side or the other. It provides a subtle shadow on one side of the face to create shape. David | Sharing my Insights, Knowledge & Experience
ootsk Goldmember 1,154 posts Likes: 13 Joined Jan 2002 More info | Dec 03, 2012 22:09 | #7 What's a good way, in the evening, to get the tree lights to show up?
dmward Cream of the Crop More info | Dec 03, 2012 22:17 | #8 ootsk wrote in post #15323117 What's a good way, in the evening, to get the tree lights to show up? Slower shutter speed. Image hosted by forum (626620) © dmward [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. David | Sharing my Insights, Knowledge & Experience
morph2_7 Goldmember 1,112 posts Joined Sep 2012 Location: Los Angeles More info | Dec 04, 2012 11:52 | #9 Nice picture, David. Out of curiosity, using the same example as your photo, what if I do the following:
gonzogolf dumb remark memorialized More info | Dec 04, 2012 11:54 | #10 morph2_7 wrote in post #15325244 Nice picture, David. Out of curiosity, using the same example as your photo, what if I do the following: - Set exposure to 10 second (let's just say this is the correct exposure for the ambient light or the skyline in the background) - Press shutter button completely to take a picture (flash fires - 1st curtain) - Have the subjects step out of the frame - Wait for another 9-10 second for the exposure to complete What will happen? Double exposure? The lights would certainly record through the dark area of his coat.
morph2_7 Goldmember 1,112 posts Joined Sep 2012 Location: Los Angeles More info | Dec 04, 2012 12:06 | #11 Thanks. That's what I thought.
gonzogolf dumb remark memorialized More info | Dec 04, 2012 12:10 | #12 morph2_7 wrote in post #15325320 Thanks. That's what I thought. If the subjects stand still too long, there's a risk of movement (blurry image). How can I correct it then? Bump up ISO and open aperture to shorten exposure to an acceptable length, for example 1 or 2 seconds? In the case of David's shot the subjects would be in silhouetted against the skyline so the only real risk of blurring is to their outline as their faces would be too dark to record any detail, then the flash fills that in. So the real risk of ghosting/blurring is on the edges of their outline.
dmward Cream of the Crop More info | Dec 04, 2012 12:31 | #13 gonzogolf wrote in post #15325335 In the case of David's shot the subjects would be in silhouetted against the skyline so the only real risk of blurring is to their outline as their faces would be too dark to record any detail, then the flash fills that in. So the real risk of ghosting/blurring is on the edges of their outline. Yep. When I do these shots, there are always a couple with "shadows" on the background. Actually its the ghosting Gonzo mentioned. David | Sharing my Insights, Knowledge & Experience
morph2_7 Goldmember 1,112 posts Joined Sep 2012 Location: Los Angeles More info | Dec 04, 2012 12:31 | #14 Makes sense. Thanks again for your reply.
dmward Cream of the Crop More info | Dec 04, 2012 12:51 | #15 Here is another one from that evening to illustrate what happens with movement. Image hosted by forum (626695) © dmward [SHARE LINK] THIS IS A LOW QUALITY PREVIEW. Please log in to see the good quality stuff. David | Sharing my Insights, Knowledge & Experience
| Latest registered member is Marcsaa 492 guests, 124 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
