Thread started 04 Dec 2012 (Tuesday) 02:53
Odd 7D AF point behaviour
match14
Dec 04, 2012 02:53 |  #1
I'm re-writing this to make it a bit clearer. I'm also using firmware 2.0.3
1. If you start off in either P, Tv, Av M or B and select an off centre af point i.e. furthest on the right.
2. Turn mode dial to C1 and then go back P, Tv, Av M or B the af point should revert back to the point selected in step 1.
3. Now press in the multi-controller (I am asuming you have the multi-controller set to af point direct), the centre af point should be selected.
4. Turn mode dial to C1 and then go back P, Tv, Av M or B and the af point does not go back to the centre as in step 3.
Anyone else getting this?
David
500px (external link)
Gear
KhanhD
"I need a grip . . . on my life"
Dec 04, 2012 03:42 |  #2
Theres a setting to set a default focus point.
Khanh Duong | KHDPhoto.com (external link) | flickr (external link) | facebook (external link)
iPhone 5s + Instagram (external link)
apersson850
Obviously it's a good thing
Gallery: 35 photos
Dec 04, 2012 04:15 as a reply to  @ KhanhD's post |  #3
What's the error in this? When you exit C1, it goes back to whatever you had when you entered C1. Which it should.
Anders
match14
Dec 04, 2012 04:26 |  #4
No if I exit C1 it goes to the right hand point, even thought it was at centre before hand. If I push the joystick to select centre point then go back to C1 then exit C1 it goes back to right hand point, I have just discovered if I exit C1 and select any point with joystick then go to C1 and then back again it keeps that point, but selecting centre by pushing the joystick then going to C1 and back ignores this.
David
Gear
apersson850
Gallery: 35 photos
Dec 04, 2012 04:52 as a reply to  @ match14's post |  #5
Aha. Your original problem description lacked a few details, then. What you describe now is exactly the same thing as I see, and I agree - it feels like a bug. Selecting the AF point by moving the joystick or pushing it in ought to have the same authority.
I'm using firmware 2.0.3, so there's nothing newer to apply today.
Anders
match14
Dec 04, 2012 05:41 |  #6
Ah at least I'm not going mad then, I wonder if I should report this to Canon.
Thanks for your help.
David
Gear
KhanhD
Dec 04, 2012 08:12 |  #7
match14 wrote in post #15324023 (external link)
Canon is going to tell you to RTFM.
apersson850
Gallery: 35 photos
Dec 04, 2012 08:21 as a reply to  @ KhanhD's post |  #8
That doesn't help, since it doesn't say it should behave like this.
Anders
KhanhD
Dec 04, 2012 08:24 |  #9
Read post #2?
2n10
Gallery: 81 photos
Joined Sep 2012
Dec 04, 2012 08:34 |  #10
I have not experienced that issue and I keep mine on center focus point. I kind of agree with KhanhD.
John
Equipment
My Portfolio (external link)
match14
Dec 04, 2012 13:34 as a reply to  @ 2n10's post |  #11
David
Gear
KhanhD
Dec 04, 2012 13:36 |  #12
Did you read post #2?
match14
Dec 04, 2012 14:30 |  #13
Yes I did, did you try the steps in post #11?
David
Gear
joeblack2022
Joined Sep 2011
Dec 04, 2012 14:39 |  #14
Just throwing this out there, what is your CFn III-12 set to?
Joel
match14
Dec 04, 2012 14:52 |  #15
Set to 1:Select different AF points.
David
Gear
3,714 views & 0 likes for this thread, 7 members have posted to it.
916 guests, 118 members online
