Thread started 03 Jan 2006 (Tuesday) 19:01
Macro problem
mknabster
Jan 03, 2006 19:01 |  #1
I have been having this problem when i try to shoot macro or super macro shots in any of the modes P and above that on my G6. Whenever i am holding the camera or it's on a tripod, when i half press the hustter button, the little yellow box comes up, and it won't even focus. This happens w/ every single shot i have tried to take in the past few moths. What's going on?
- Matt
MK Studios (external link)
rpolitsr
Joined Jun 2005
Jan 03, 2006 20:29 |  #2
I am a Pro1 user, but the operation on Macro and SuperMacro modes is very similar for the G6.
The most important thing is to be sure that the subject is within the allowed distance range measured from the tip of the lens:
5 cm. to 50 cm. at wide angle end in Macro mode
15 cm. to 50 cm. at telephoto end in Macro mode
5 cm. to 20 cm. in SuperMacro mode
The zoom must be set to any focal length between wide angle and 86mm maximum
If your subject is beyond the ranges allowed the yellow rectangle warns you that the camera will not focus.
See pg. 74 and pg. 75 of the G6 user’s guide (English version) for a detailed description and for distances in inches.
Good luck
rafael
Canon EOS Rebel XT, EF-S 18-55mm f3.5-5.6 II, EF 50mm f1.8 II, EF-S 55-250mm f/4-5.6 IS STM, speedlite 430EX, basic filters set.
My photo galleries (external link)
Marketplace: PAYPAL GIFT NO LONGER ALLOWED IN POTN
Don ­ Ellis
Joined Sep 2001
Jan 03, 2006 20:53 |  #3
Here's a trick I routinely use with the LCD viewfinder: Point the camera at your subject (within the distance limits rpolitsar mentions), half-depress the shutter, and then move your camera closer or farther until you see the image come into focus.
With the shallow depths of field you can expect with macro and super-macro, this will help you fine-tune your focus and even allow you to decide what part of your subject to bring into focus.
Don
mknabster
Jan 04, 2006 18:54 as a reply to  @ Don Ellis's post |  #4
Well, actually when i had last used it, i used a tripod and they came out all blurry, except i was a few inches away from it, so that's why. But before that, i was using it hand held, and i was as close as i could be, nearly touching the lense to the flower, and it still read yellow. It just wouldn't focus, and it never showed on the LCD that it was a slower shutter speed neither. So i don't whta else i can do.
- Matt
Don ­ Ellis
Joined Sep 2001
Jan 04, 2006 19:19 |  #5
At the risk of saying something obvious, it may be that you're too close.
Don
mknabster
Jan 04, 2006 19:53 as a reply to  @ Don Ellis's post |  #6
Well, i just tried both macro modes, both in the vicinity of 5-10 cms away from my subject, and it still wouldn't focus. The yellow box was all that came up. Any other suggestions?
- Matt
rpolitsr
Joined Jun 2005
Jan 04, 2006 20:19 |  #7
From my experience with the Pro1, low light and/or the lack of contrasted vertical lines in the subjects are common sources of auto focus problems when shooting Macro or SuperMacro.
When this is the case, I switch to manual focus, and after setting the distance to say 15 cm. (6 inches) for SuperMacro I move the camera back and forth as described Don Ellis to achieve correct focus. Remember to measure distances from the tip of the lens, not from the focal plane as in DSLR shooting.
'nearly touching the lense to the flower' is too close as Don said. Distance and zoom settings are critical in macro shooting.
rafael
1,362 views & 0 likes for this thread, 3 members have posted to it.
Macro problem
2460 guests, 124 members online
