Thread started 07 Dec 2012 (Friday) 15:01
Lightroom Publish
Bob_A
Gallery: 48 photos
Joined Jan 2005
Dec 07, 2012 15:01 |  #1
If I'm editing RAW files in LR and then want to Publish them to a service like Smugmug do I need to Export to an sRGB jpeg first then Publish, or do I just drag the RAW files into the publish folder?
It appears that when you drag RAWs to the Publish folder that all of the settings currently set for an Export (like image format and color space) are also applied. Is this correct or am I missing something?
Bob
René ­ Damkot
Dec 07, 2012 15:41 |  #2
No need to export first.
http://x-equals.com …ish-services-demystified/ (external link)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Bob_A
Gallery: 48 photos
Joined Jan 2005
Dec 07, 2012 16:06 |  #3
Thanks René.
For Smugmug they only have the settings shown below ... with none specifying color space. Maybe they only allow publish as sRGB so don't give the option?
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2012/12/1/LQ_627137.jpg
Image hosted by forum (627137) © Bob_A [SHARE LINK]
Bob
Bob_A
Gallery: 48 photos
Joined Jan 2005
Dec 07, 2012 16:38 |  #4
Solved:
Quote from the guy that wrote the Smugmug plugin ( http://news.smugmug.co​m …/lightroom-3-and-smugmug/ (external link) ):
"We omitted the ColorSpace setting from the UI and default it to sRGB. SmugMug converts all images to sRGB, so it seemed silly to give users the option to select something else, considering that converting from another colorspace to sRGB adds additional processing time on our end."
Bob
René ­ Damkot
Dec 08, 2012 06:02 |  #5
I like their reasoning :)
Bob_A
Gallery: 48 photos
Joined Jan 2005
Dec 08, 2012 13:50 |  #6
So far I'm really liking the switch from ACR/Bridge to LR. I've been using it as an excuse to update to Adobe's latest processing engine (2012) which has also allowed me to get rid of a ton of "intermediate" files that were filling my system.
Here was my original Smugmug workflow:
ACR -> 16 bit ProPhoto Tif (that I kept in folders) -> Small edit's in PS plus sharpening -> convert to sRGB jpeg (that I kept in another set of folders) -> upload to Smugmug
Now for Smugmug it's:
LR -> drag edited RAW to Publish folder -> publish to Smugmug
Now I'll only create Tif's when I need to do any editing in PS.
The only thing I've noticed is that you really need to be careful not to accidentally delete a bunch of files. You can restore then, but you lose all your edits :( I went to delete a single file one time but had about 20 highlighted ... lesson learned.
Bob
tonylong
...winded
Gallery: 60 photos
Dec 08, 2012 18:43 |  #7
Bob_A wrote in post #15342129 (external link)
Glad to know it's working for you!
One great LR feature you can explore is Virtual Copies. You can create several "versions" of a single image without creating file copies. You can use VCs in collections as well, so, for example, a VC for SmugMug, a VC "original", a VC for printing, etc.
Heh! Lesson learned!
Yeah, if you delete an image from the Library (not the disk) you through away all your edits/metadata. At least you still have the original on the disk, although you definitely want to use the appropriate "caution" when Deleting from the disk!
Tony
Bob_A
Gallery: 48 photos
Joined Jan 2005
Dec 08, 2012 23:50 |  #8
tonylong wrote in post #15342991 (external link)
Thanks Tony, I'll check out virtual copies.
Not sure if I should have but after losing my edits the one time I also turned on "Automatically write changes into XMP".
Bob
tonylong
...winded
Gallery: 60 photos
Dec 09, 2012 01:33 |  #9
Bob_A wrote in post #15343686 (external link)
There's nothing "wrong" with that, since the edits/metadata do show up in LR and also can be "shared" with either another installation of LR or with Photoshop ACR, or copied onto an external hard drive and shared with, say, a laptop, nice feature!
The "downside" actually goes back to the "old days" of LR1 -- LR used this as the "default" and we would see significant slowdowns, since every little change got written into a file. It should be noted, though, that computer systems have speeded up since '07 and these days a lot of folks are happy doing the once-default "write to XMP".
Tony
tonylong
...winded
Gallery: 60 photos
Dec 09, 2012 01:34 |  #10
However, I believe that if you Delete either from the Library or from the disk, your xmp metadata will also disappear...?
Tony
Bob_A
Gallery: 48 photos
Joined Jan 2005
Dec 09, 2012 02:11 |  #11
tonylong wrote in post #15343888 (external link)
Thanks again Tony.
When I get a chance I'll do a test.
Bob
1,632 views & 0 likes for this thread, 3 members have posted to it.
Lightroom Publish
1396 guests, 104 members online
