What are you trying to do? Offhand I can't think of a reason for using a F-F threaded coupling, as that could only be used to couple two filters, leaving them unable to attach to a lens (without using a M-M threaded adapter on one side of the combo). A lens reverser ring, allowing you to couple two lenses for use in close-up/macro photography, would be M-M so it could connect to the female attachment threads on the two lenses. If you just wanted to stack two filters, there's no need to use any kind of coupler (unless they're different diameters, in which case you'd want a step-up or step-down ring to connect them; which would depend on what filter size your lens took).
