Thread started 10 Dec 2012 (Monday) 22:25
POLL: "Best all around wide-angle"
17-40L
28
40%
16-35L
28
40%
24L II
14
20%
70 voters, 70 votes given (1 choice only choices can be voted per member)). VOTING IS FOR MEMBERS ONLY.
BROWSE ALL POLLS
17-40L, 16-35L, or 24IIL
photopr0
Joined Oct 2011
Dec 10, 2012 22:25 |  #1
Need a wide angle for full frame! Mostly for landscapes, cars, and interiors! What's the all around best option in your opinion?
Canon 5D Mark II | Canon 7D Gripped | Canon Rebel xti
Canon 100-400 F4.5-5.6L | Canon 70-200IS F2.8L |Canon 100L| Canon 17-40L | Canon 28-135 | Canon 85 F1.8 | Canon 50 F1.8 II
flickr (external link) | Facebook (external link)
kin2son
Joined May 2011
Dec 10, 2012 22:37 |  #2
If money is a non-issue. Zeiss 21 ;)
I think MF is fine for your intended use.
5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
EOS M / EF-M 18-55 / EF-M 22f2 / Ricoh GR aka Ultimate street camera :p
Flickr (external link) | My Images on Getty®‎ (external link)
nardox
Dec 10, 2012 22:37 |  #3
The 17-40 and 16-35 are very similar optically, so unless you really need the extra stop for interior shots, if you are able to use a tripod for most of your work, I'd go for the 17-40.
The 24L II is great, but it may not be wide enough for your application, and it is significantly more expensive compared to the 17-40.
Canon 60D, EF-S 15-85mm f/3.5-5.6,
Canon 5D III, EF 24-105 f/4L IS, EF 70-200mm f/2.8 L IS II, EF 24mm f/1.4L
oklaiss
Joined Nov 2011
Dec 10, 2012 22:42 |  #4
I'd go with the 17-40 or 16-35, as the 24 might not be wide enough. I've also heard great things about the samyang/rokinon 14mm which can be had for under 400 if you're looking for less expensive options with similar image quality
5D Mark II Gripped, 60D Gripped, 450D, 24-105 f/4L, 85 1.8, 70-200 f/4L IS, Nifty Fifty, 28 1.8, B+W/Lee/Cokin/Hitech filters, 430ex II x2
jerbear00
Joined Mar 2011
Dec 10, 2012 22:43 |  #5
Secret option 4.... 24tse2 :))
5d3 & Lens CoLLector
Gear List/Feedback
Mark-B
Dec 11, 2012 00:02 |  #6
If you get the 17-40 instead of the 16-35, you'll have $900 left over to put toward a good tripod, flashes, or a tilt shift lens.
Mark-B
msbphoto.comexternal link
DucDuc
Joined Nov 2012
Dec 11, 2012 00:06 |  #7
the 17-40 may challenge you with the barreling you get from it in close up shots, like interiors, even in cityscapes can suffer from this. The 24-105L is no where near as bad, but not as wide either. If you are considering 24L save some cash and try the 24-105, it's cheaper than a prime and a great walk around lens on FF. Also there are a lot of 24-105 available used since it's a common kit lens. Save the balance for the 14mmL, not tried it but everything I've read and heard says it's a good choice for interiors :)
spear
Dec 11, 2012 00:38 as a reply to  @ DucDuc's post |  #8
To be honest I am not too happy with my 16-35L. So I would vote for the 24IIL since the Zeiss is not included.
Canon 40D, 5DII, 5DIII, G9,G11,S100,G1X, Canon lenses 600mmL f/4 ,24mm-105L f/4, 16-35L II f/2.8, 70-200L II f/2.8, EF 100mm f/2.8, EF 50 f/1.4,17-85 EFS, 10-22 EFS, 580 EX, 2x 580 EXII, 270EX,STE2, 1. 4x Converter, 2.0x Converter. Nikon 800E w/Nikkor 24-70
Mark-B
Dec 11, 2012 00:40 |  #9
The 17-40 at minimum focus distance will have more distortion than the 24-105 at minimum focus distance, however, the 17-40 has much less distortion than the 24-105 at 24mm.
Mark-B
kawi_200
Gallery: 10 photos
Joined Jul 2011
Dec 11, 2012 00:56 |  #10
Ever since I got my 24mm f/1.4L II I haven't really use the 17-40L at all. I keep debating if I want to keep it or sell it. I don't feel that I really have a use for it any more.
5D4 | 8-15L | 28-135mm f/3.5-5.6 IS | 24L II | 40mm pancake | 100L IS | 70-200mm f/2.8L IS mk2 | 400mm f/4 DO IS
SMP_Homer
Gallery: 29 photos
Dec 11, 2012 06:18 |  #11
I used to have the 17-40, and the main use for it was real estate...
For no real reasons, I switched to a 16-35...
Recently shot a Caribbean villa with it, and for the most part, I don't see any real differences (I had shot the same location 18 months ago, and new renovations/additions prompted a refresh of the shots)
If I could go back a year, I would have stayed with the 17-40... But it's not bugging me enough to want to sell and re-buy...
EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
Sig35A, Sig50A, Sig85A, Sig14-24A, Sig24-105A, Sig70-200S, Sig150-600C
100-400L, 100L, 100/2, 300 2.8L, 1.4x II / 2x II
600EX-II X3, 430EX-III X3
Franz-Olof
Joined Mar 2012
Dec 11, 2012 06:39 |  #12
I had the same question a week ago. Got 16-35ii. Am happy with it indoors mostly but would need also a faster prime.
5Dmkiii ⎟16-35Lii ⎟24-70Lii ⎟50/1.8ii ⎟∑85⎟100-400L⎟Nissin Di866ii
my photo site (external link)
jimewall
Dec 11, 2012 06:55 as a reply to  @ Franz-Olof's post |  #13
I personally don't think 24mm will be wide enough for some of what you described. If it was, then my suggestion would be the TS-E 24mm. If you have the money there is the TS-E 17mm.
If you need the speed get the 16-35L if not the 17-40L. At the moment I do not need a f/2.8 for that range, so I went for the 17-40L.
Thanks for Reading & Good Luck - Jim
GEAR
RudolfG
Joined Feb 2012
Dec 11, 2012 07:01 |  #14
The 24LII is no doubts a great lens...
But for landscapes (where your f-stops will most likely be f/8, f/11 ??) get one of the zooms. I've tried 16-35II and 17-40, I found them to be very similar. Given the price difference, I kept the 17-40 which I really like.
For night-city, street photo, or creative photo, it would probably be the 24LII.
If budget is playing role & wanting to cover all styles, I would go (and I currently go) with a combination CANON 17-40 f/4 L + new Sigma 35 f/1.4.
JustinPoe
Dec 11, 2012 09:03 as a reply to  @ RudolfG's post |  #15
For what you described as what you want to shoot, I think the 17-40L is easily the best choice out of the 3.
However, anybody that is trying to shoot landscape seriously and optical quality is of utmost importance, I strongly recommend taking a look at this guy:
http://www.the-digital-picture.com …lt-Shift-Lens-Review.aspx (external link)
500px (external link)
3,413 views & 0 likes for this thread, 16 members have posted to it.
1352 guests, 174 members online
