Thread started 11 Dec 2012 (Tuesday) 00:12
Help please producing an enlarged print with a white border
nigpd
Dec 11, 2012 00:12 |  #1
I'm hoping you can help as I'm struggling getting output ready to print
I have a team photo image that needs to be printed 36" x 24" including a white border. The actual image needs to be 32" x 19" and positioned so that the overall print has a 2" white border at the top and sides and a 3" border at the bottom.
I will want to have the names of the team on this bottom part of the border in the normal style
Back row:
Middle row:
Front row:
Because of the slightly less than 3:2 ratio I will need to crop a bit off the image top and bottom before resizing.
I have Perfect Photo Suite 7 that includes Perfect Resize.
I'm a bit stuck as to the workflow order to produce what I need. What is the best order to do the following tasks?
normal post processing, saturation, contrast, levels etc
sharpening
resizing in Perfect Resize
add a canvas size 36" x 24"
Putting the team names on the bottom border
manoever the image on to the canvas to give the borders as above as the image wont be central
I dont know how to do the manoevering bit either :bonk: and I dont know if I've missed something else in this workflow due to my lack of knowledge
Please can you point me in the right direction? Thanks in advance for any help
My flickr (external link)
René ­ Damkot
Dec 11, 2012 06:04 |  #2
Assuming Photoshop:
If you make sure the image has no "Background layer" (simply doubleclick and rename it) when you extend the canvas, the image will be a separate layer "floating" atop a bigger (transparent) canvas.
You can put a layer filled with white (or whatever color) below the image if you want to, and move the photo around all you want using the move tool.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
nigpd
Dec 11, 2012 06:43 |  #3
René Damkot wrote in post #15352394 (external link)
Assuming Photoshop:
Thanks for the advice René, it's much appreciated. Yes, I am using CS6 but forgot to mention that :roll:
I guess it would be wise to use rulers to make sure the image is exactly right on the canvas
René ­ Damkot
Dec 12, 2012 06:12 |  #4
PS can center the image for you (and it will be centered anyhow if you extend the canvas symmetrically) ;)
http://www.webdesign.o​rg …es-in-photoshop.3801.html (external link)
nigpd
Dec 13, 2012 14:32 as a reply to  @ René Damkot's post |  #5
Perfect. Thanks René
914 views & 0 likes for this thread, 2 members have posted to it.
954 guests, 108 members online
